When current moves through a wire it creates a magnetic field around the wire.
What is that magnetic field composed of ?
Where did it come from ?
Is it composed of particles ?
Do they come from the aether ?
Is there an electric field as well as a north and south magnetic field ?
A few observations.
As of now we pulse a coil or magnet to get the electricity from our source.
If we could get the electricity from the source without pulsing it we would essentially be removing the heat from the source, I believe it would cool itself to ............who knows.
Is there an electric field as well as a north and south magnetic field ? I noticed when moving a magnet from a cathode tube (computer monitor) that the least amount of field lines were three, I could not get it to two or one only three then the field lines just faded so that indicates there are three fields
I will continue to post my idea's and observations on this thread if they help someone or help in any way consider it open source, and I thank the Lord that He has used me to help others in some way.
I have to be honest I do have some idea's that I wont post, I think free energy is a good thing, but as with anything it would be used for evil as well as good. Im not trying to mislead anyone, can I make free energy at this time - No. Im just a garage tinkerer with some nutty idea's
Ill give you my thoughts.
Two opposing spins. One spin is cw and the other ccw. If you take a cueball and use right english or ccw,then the ball it hits is cw.
In a wire the current which was pushed by voltage or force sets the electrons or particles in motion.
The magnetic field itself to me is a gravitational force exerted by the spin.
The aether is composed of both waves and particles.
Apparently you cant have one without the other.
All energy to me deals with something in motion. If the Earth spun at 100,000 mph then a spaceship would have to be close to the same speed in order to land. The landing would have to be in the direction of spin. Trying to land in the opposite direction would result in a force much greater than one. I assume this same analogy applys to subatomic particles or waves.
a tattoo gun configuration would make a good mechanical switch, also this vid is very interesting YouTube - возбуждение ВЧ трансформатора на собственной частоте If we ran current through the core and used the tattoo gun configuration as a switch could we pick up this current as well.
Iv been using a flasher relay out of a car to pulse my coils, it has a make and break switch but its not adjustable, but the bemf off the coil is very high.
Iotayodi great to hear your thoughts on the subject I believe we can over complicate the situation sometimes that's why Ed's observations were so interesting he looked at it in simple terms.
