This carburetor is built with a plastic floatation device designed to quench the liquid gas supply. It is made from a soft plastic as is the end of the metal stopper pin, thus propane could deteriorate them and they would have to be removed, and the option of gasoline would go with.
Preferrably a 'snorkel' device would be obtained or constructed to fit between the metal air cleaner case and carburetor air intake like a gasket with a tube leading into the carburetor past the choke valve. The engine regulator component also would be attached in order to provide fuel only when there is demand by the engine. Working pressure is supposedly quite low, thus a needle valve or low pressure regular supplies it from the tank.
Forseeably the plasma ignition method would then reduce the amount of gas pressure required even further.
