biasing field equalizing rotor field
Thanks for the new video, Lidmotor.
Hello plengo and all,
I want to propose a follow-up experiment to the one shown by plengo in his video.
Maybe someone can try mounting a pick-up coil at a fixed position from the rotor (instead of holding it in your hand).
Now, with a load and scope-probe attached to the coil - as done by plengo in his experiment - take the biasing magnet in your hand and slowly bring it nearer the coil. (It will be difficult to do, as the magnet gets sucked towards the core of the coil. Maybe you will have to use some kind of spacers of different thickness to prevent direct contact)
I wonder, if the maximum output voltage is achieved with the biasing-magnet in close proximity to the coil (= directly stuck to the coil's core) or with the biasing-magnet distanced from the core?
romeroUK had the coil and the biasing-magnet distanced from each other.
Maybe we can see that the output voltage will rise, if the biasing-magnet and the coil's core are not directly touching.
Maybe the stronger the biasing magnet, the further it needs to be distanced from the coil's core.
With the biasing magnet being oriented in opposition to the rotor-magnet, there will be a point somewhere between the two, where both magnetic fields have equal strength.
Maybe the field or wave coming from the approaching rotor-magnet must be counterbalanced by the biasing magnet to the effect that both fields are equal within the coil's core. To shift this location of equal field strength to the right place in the coil, the biasing magnet would need to be at the right distance from the coil's core.
