  • @ Farmhand, keep us posted mate, glad the book was of some use
      Another way to do this without such a drastic change in system design
      Changing coil wiring around could produce some interesting effects.
      By changing the wiring you could have NN or SS or NS, could be fun.
      I think it would blast any pickup coil around it.
      Dang where did I put that rotor
      • Originally posted by qvision View Post
        "Would you believe each phase winding is only 1.3 ohms but 11.75 mH ! "
        millihenrys not henrys ? Not surprising unless that's Henrys !
        What diameter is the wire ?
        That's millihenrys, that's what the meter says on the 20 mH setting, the wire looks like about .63 mm diameter maybe .7mm, less than 1mm.
        Doesn't seem right to me.
          Oh I will be removing the field from the housing and then removing the wire,
          then I'll separate about 1 inch or so of lamination's and cut all the inner
          projections off to make a nice neat smooth laminated ring. Or maybe I could
          leave four sets of pole projections for the four poles I want. There's about
          six inches of lamination, I just hope there is enough solid outer ring radius to
          make good core's.
          I was just curious about the poles and stuff, I guess I'll work it out. These
          one's have no armature's, if I had an armature to look at I would know a lot
          more.
          Thanks for the download.
          That's a great L/R ratio.
          don't destroy the motor, Try and set it up as a pulse motor. fundamentally all motors are the same its only how you apply them. I bet you could convert it to a dc pulse motor. power up the rotor coils with DC and pulse the stater coils. or the other way around. Turn it into a stepper motor. you will learn so much from it and it my do something unexpected. With that kind of Resistance it would run on 12 volts if pulsed. The back EMF would be very High.
          • Originally posted by toranarod View Post
            Well I've got two of these but they have no armature's or bearing/housing
            ends,
            I've also got a complete 28 Kw one.
            I'll have a good look and a think about it first, before i do anything. If I can
            get or make an armature to fit one they would be worth keeping. I think i can
            get some more of these motors and parts so it would be a shame it I
            destroyed the field then got a rotor and bearings. I do have two but then
            two the same could be useful too.
            As far as I can tell I just need to knock through or pull out some key or wedge
            type inserts around the field which seem to hold the field in the housing.
            I'll see if i can find dismantling some info on them. I'm hoping to be
            able to remove the field from the housing to see how the lamination's are.
            • Rod it was your idea,
              I'm blaming it on you
              • Rod...you are tickling everyone's brain.....
                a bit of info transfer to help out
                You have to make sure that both magnet emit opposite vortex
                why how about this
                Originally posted by shawnnweed View Post
                I can see what you mean. Actually two golden mean vorteces, placed in opposite rotation would eventually form an oblong circle like the one posted. Which of course would form a nearly perfect circle.
                you got it and together they form:
                It is also called a Fermat's Spiral -- from Wolfram MathWorld
                The Fermat Spiral Also respects 936
                Fermat's spiral (also known as a parabolic spiral) follows the equation
                in polar coordinates (the more general Fermat's spiral follows r 2 = a 2θ.) It is a type of Archimedean spiral.[1]
                In disc phyllotaxis (sunflower, daisy), the mesh of spirals occurs in Fibonacci numbers because divergence (angle of succession in a single spiral arrangement) approaches the golden ratio. The shape of the spirals depends on the growth of the elements generated sequentially. In mature-disc phyllotaxis, when all the elements are the same size, the shape of the spirals is that of Fermat spirals—ideally. That is because Fermat's spiral traverses equal annuli in equal turns. The full model proposed by H Vogel in 1979[2] is
                where θ is the angle, r is the radius or distance from the center, and n is the index number of the floret and c is a constant scaling factor. The angle 137.508° is the golden angle which is approximated by ratios of Fibonacci numbers.[3]
                this must be where you got your inspiration
                • @ Farmhand
                  You should try it with my setup, very simple.
                  I use a single tube magnet, a carbon rod as a shaft, two flanged bearings and perspex endplates to mount the bearings on.
                  The drive circuit is really simple, a transistor, a diode and a resistor mounted on a tiny piece of breadboard.
                  The drive coil i wound by hand using my drill and a simple winding jig, just two rods mounted opposite each other.
                  Total cost (i am in the UK so USA should be cheaper) is £50.
                  The advantage is that very little work is needed in construction and the tube magnet goes up to about 30,000 RPM.
                  If you want to go for it i can give you more detailed info and all the help you need via email or PM.
                  Here's my video :
                  Acceleration under load - replicating the Heins Effect ... - YouTube
                  • Rod, isolating and investigating each principle independently is a good idea. So far, what different principles do you see that are related? Do you have a list?
                    Ps, I was the one that requested a scope shot. Just a shot against a small resistor or something so we can see the waveform on a normal pickup coil's circuit.
                    Trust your own instinct. Your mistakes might as well be your own, instead of someone else's ~BW~ It's kind of fun to do the impossible ~WD~ From now on, I'll connect the dots my own way ~BW~ If I shall be like him, who shall be like me? ~LR~ Had I not created my whole world, I would certainly have died in other people’s ~AN~
                      ends,
                      This is how I would approach the project. Just isolate one winding on the stator and one on the armature. Put the motor back together and line up the two coils and put power in the coils. When you power the coils the armature will rotate a few degrees as the magnetic fields attract or repel each other.
                      Then I would find all the other coils taking notes on where they are and how many there are. You can decide how many you want for drive coils and how many you want for generator coils. I bet you could turn it into an Adams type motor.
                      Please keep us informed.
                        why how about this
                        Hello MonsieurM
                        you are heavily into geometry and symbolism I have had a similar interest over the years. I believe the ancient Egyptian and other cutlers created structures to harness power.
                        Have you ever been a Mason? do you a Mason they are into symbolism.
                        • I guess I learned to see through their eyes...I have always had a knack at finding Patterns...seeing the unseen
                          Weren't the Masons originally Gaea's Artisans .....
                          a Famous Artisan: Jesus Christ
                          I posted this in the beginning of this research; and it fits perfectly
                          I was just reading through A thread on Above Top Secret on
                          The most accurate prophecies i have ever seen., page 1
                          Mitar Tarabich, (1829-1899) was an illiterate peasant from a small Serbian village called Kremna, he occasionally had prophetic visions of "seeing into the future. Being very religious and his godfather being a local Serbian orthodox priest, he told the priest about his visions.
                          The priest, Zaharije Zaharich (1836-1918), wrote down mitar's visions in a small book, which got damaged by fire in 1943 when his family home was destroyed by the Bulgarian army. This text is now in the possession of the family of Zaharich's great-grandson, Mr. Dejan Malenkovich.
                          "People will drill wells deep in the ground and dig out gold, which will give them light, speed and power, and the earth will shed tears of sorrow, because there will be much more gold and light on its surface than in its interior. The earth will suffer because of these open wounds. Instead of working in the fields, people will dig everywhere, in right and wrong places, but the real power will be all around them, not being able to tell them, 'Come on, take me, don't you see that I am here, all around you.'(sounds like water/emf, no? ) Only after many a summer, people will remember this real power, and then they will realize how stupid it was to dig all those holes. This power will also be present in people but it will take a long time before they discover it and use it. Thus man will live for a long, long time, not being able to know himself. There will be many learned men who will think through their books that they know and can do everything. They will be the great obstacle for this realization [self-knowledge], but once men get this knowledge, then people will see what kind of delusion it was when they listened to their learned men. When that happens, people will be so sorry that they didn't discover it before, because this knowledge is so simple ( 6 3 9 ) .
                          • Hey guys over at overunity chalamnan sorry about the spelling, has just released a video of more power out than in his theory is that the hall sensor when positioned just right will cause resonance in not just the drive coil but all the coils and get more power out than in??????
                            soory forgot the link http://www.youtube.com/watch?v=aIlndSDIyGc
                            • If you connected the rotor ends like Ed Leedskalnin's pmh you would only have to charge the coils one time, as long as the magnetic field was connected the E field would replinish itself, energy for free, free E field.
                              Almost looks like a gyroscope doesn't it.
                                could not help it, look closely
