  • Originally posted by garrypm View Post
    Hi Nolan,
    If you can spare some time and wish to disclose information, would you be
    kind enough to at least describe how you keep the attraction pulse on longer
    and from where are you tapping the output voltage.
    Thanks, Garry
    Garry, Ill draw a circuit tonite, but its just a FWBR connected to the coil all the time.I pulse the HI and LO side of the coil so it is isolated from the power source, very similar to what Toranado does. My pulse width is done by a encoder wheel on the shaft, the closer sensor is to the center of the wheel the longer the pulse,the further from the center the shorter the pulse. The trigger magnets run most of the radius of the wheel. And I move the timing so the pulse extends past the TDC of the coil.
    • Thanks so much.
      Garry
      • Hi Woopy,
        So nice to see you around again.
        My daughter left Australia on Wednesday and is now looking for work
        and accomodation in Paris. She is hoping to spend about 12 months there but
        I am not so sure that things will work out for her.
        Any good replications lately?
        Thanks, Garry
        • Originally posted by Shadesz View Post
          Not sure how I missed this. Unfortunately the circuit is still sitting on my shelf waiting for me to give it attention. There are only a couple of more weeks until the semester is over, hopefully I can get it built before the next semester starts. I hope all is well my friend.
          Hello Shadesz
          I have updated a user manual for that circuit now. I have lost you Email address
          because my computer crashed.
          other question what is going on with Romero? I received an email about a solid state device.
          any body know what this is about?
          nice to drop in and see you all. been very busy with HHO stuff
          cheers Rod
          • Rod,
            You gotta try Nolan's system.
            Have not been able to stop playing with it.
            Garry
              Rod,
              Garry
              So are you having any luck getting the higher output?
              Nolan
              • For a long time I try to understand what could cause overunity in motors and transformers. Are motors and transformers the same? The final conclusion is yes, they are the same.
                Pulse motors are just like resonance transformer. It takes time to raise rotor speed with each pulse. This is resonant rise. Resonance is just a process of adding energy in correct direction result in a build up of momentum. Each pulse in succession is an addition of momentum while the energy of the wheel after each pulse increase exponentially. If the failure was to recognize the frame of reference which give extra energy, then every motor and transformer has always been capable of going OU if it is efficient enough. The Muller dynamo is just an... efficient dynamo.
                • Originally posted by kajunkreations View Post
                  Thanks wizard! Yes it is noisy, but only when the "attractive" coil is being pulsed and I sure my tolerances arent NASA approved. Ive had it running at 12,000 rpm and she held together, but you are right built better would yield better performance.
                  My build isnt like Romereo's at all other that being "muller" style dynamo. I think that I am closer to what Bill Muller was doing but who knows.
                  Wow! 12000 rpm is impressive. I had forgotten that something about this design does tend to make some noise even with a really well balanced setup. I think it's inherent in the nature of the magnets bumping each others fields and I remember now Romerouk said something about the unusual noise if yours has some similarity in that respect. I bought most of the items to build this and got started but got stalled out before even getting it assembled due to some other projects. I still hope to give it a try but was also somewhat less enthusiastic after seeing how much trouble other very talented builders were having in getting good results. It's very encouraging to see your results. Looking forward to more results with your setup as you get more coils on.
                  • Ok guys, My new INLINE current meters came in today and the results are a bit
                    different as expected. I will say that a clamp meter is NOT accurate enough for
                    small measurement. The results arent that far apart, but apart enough not to OU.
                    CLAMP METER-
                    INPUT- 22.5v x 3.75 amp = 84.3 watts
                    OUTPUT- 125v x .83 amps = 103 watts
                    INLINE METER-
                    INPUT- 22.5v x 3.1 amps = 69.75 watts
                    OUTPUT- 125v x .4 amps = 50 watts
                    So, IT's not OU yet but I'm not too disappointed. It is really efficient and
                    I'm not doing anything special for recovery, or any type of pulse out circuit. I
                    have ordered more switches so that I can move forward, but I will be trying
                    different things until they get here.
                    Nolan
                    • That is a good result anyway!
                      • I've been testing the new setup, with occasional pauses for sleep and food ;+}
                        It seems that it generates more power than it uses but i will have to wait until i get a scope (new year).
                        Here's a vid :
                        New setup to explore acceleration-under-load. - YouTube
                        Thanks for reading,
                        QV.
                        • ''with occasional pauses for sleep and food''
                          sounds like me!!!!!!!!!!!
                          • LOL Marius, is your break over already ?
                            • Been a while since I posted here. But I've been wondering somethin lately. Is Romero's work and Thane Hines work related? If you look at thanes new vids he has motor driving a rotor over coils. he used to show shorting the larger gauge wire of the combined coil. I thought I heard him say they found a way around that in a video where he was showing the progression of his machine. Anyhow. Just asking.
                              • Originally posted by redrichie View Post
                                Hi richie,
                                yes exactly the same principle at work. But, wheras Romero had seperate drive coils and genc coils, Thane has a hybrid drive/gen coil. It's thick, so high current, but many turns so high induction, that's why his coils are so bloody big !
                                I've been following Thane's work for a while now and am making good progress myself, though on a smaller scale.
                                Check out my youtube channel,the OUG archive isn't me it's a collection of OverUnityGuide's who isn't active at the moment becuse he's started a new job.
                                All the best,
                                DC.
                                deepcut66's Channel - YouTube
