  • Originally posted by qvision View Post
    Hi Rod,
    what did you do to minimise vibration/noise ?
    Muller Motor Driven by Out Runner to 8000 RPM - YouTube
    here is the Video of my Out runner powering the Muller. Better late than never
      Am i the only one waiting for a massive explosion in that video?
      Great vid, T!
      Be carefull. Maybe some safety shields? When the rotor breaks down, you will be down too, and we dont want that to happen.....
      • Wow Rod ! Shweeeet My cat ran away when it started to get louder LOL.
        That's great, i'm going to order one of those motors next week.
        What was your volts/amps input at 8000 RPM ?
        QV.
          QV.
          I am in the process of installing new magnets and new coils.
          you will get a full report on all the specs. I never with hold information that can help others. to all
          What was your volts/amps input at 8000 RPM ? the few measurement I did take at that speed where around 3.5 to 4 AMP at 8000 RPM at 12 volts.
          at that speed the current is High but it can be controlled.
            That is a bit frightening. Double check everything on your rotor, and also make sure that your magnets ARE NOT TOO TIGHT on the mounting slots of your rotor, because they put extreme pressure on your rotor, and it will break suddenly. I suggest you put it vertically, so that if an accident happens, you be safe. Or at least mount some plexi around it.
            I have felt how it will be if it explodes, plz take precautions.
            I drive it upto 6000 RPM, by using 35V at about 2A. Your motor is quite small and efficient!
            Will be doing some tests soon, and eager to hear about yours ...
            Elias
            http://blog.hexaheart.org
            • Rpm
              I get this one going to 7K RPM @ 6 volts .5 amps while it is charging a battery.
              in the vid it is only going 4100 RPM because I have 3 generator coils attached.
              http://www.youtube.com/watch?v=7tFTyYsB1QY
              @ 12volts .9 amps while charging a battery it gets going to 20K RPM. it charges the secondary battery very nicely replenishing about 80% of the energy expended from the primary. this is not including the output of the generator coils. never had a problem with flying magnets on this build, they are pretty small though.
              Patrick
                Rod is a lot faster when he gets on a motor bike
                Ash
                • Originally posted by minoly View Post
                  Patrick
                  I would like to view your video but it says sorry its private, how can I get access?
                  • ^ same question from this Mark over here too
                    • Originally posted by Mark View Post
                      Sorry bout that, I put a several on private some time ago. I just edited it as link only - should work now
                      3PM Energizer on 6 Volts super-charging 12volts - YouTube
                      Patrick
                      • Question to all:
                        I have made 2 bifilar driving coils. Like Romero, i have put them in serie.
                        Does anybody have collected BEMF out of such setup?
                        I can charge up a cap with the BEMF, into hundreds of volts, but i fail in re-using it into the driving proces.
                        Any suggestion is helpfull....
                        • Originally posted by stevie1001 View Post
                          Question to all:
                          this will provide you with a clue
                          from http://www.energeticforum.com/renewa...tic-field.html
                          http://www.eh-antenna.com/EH_HZ.pdf
                          It is possible to design antennas which will form only space waves due to the НZ vector. For this purpose it is obviously necessary that coils with counter inclusion of the field cause only a dominant rotary electric charge and eliminate linear motion electrons (current). This will allow the antenna to provide clean НZ radio communication. This antenna has the ability to communicate with other HZ antennas or with a EH Antenna. However, it can not communicate with a conventional Hertz antenna. This antenna consists of two coils and a cylinder
                            Question to all:
                            Try putting a load on the cap for accelleration. Using the back emf should make the rotor accelerate. Load cant be too large. I used a small 4led bulb and it gave me acceleration.
                              Question to all:
                              You could pulse it back into the system through regulator. If you describe the driving system I would be happy to outline a solution for you.
                              The biggest issue is how you collect it. How are things hooked up. You may need to disconnect the system input, you may need to disconnect the output capacitor before putting it back into the system.
                              But for instance you have 100 volt in 5000uf coil if you were to pulse that through step down mechanism you could drive a bit of amperage back into the front end. The cap most likely would NOT stay at 100 volt if were done faster than was being made but you can set the discharge rate to match the charge rate.
                              You could use an inductor as another coil so the process would contribute to the drive system.
                              There is alot possibilities but, knowing the existing configuration your running is key.
                                Question to all:
                                Take a look at this.
                                Bit's
