The Magnetman MEG release Date 5/11/11
  • #91
    I made my setup in order to replicate Flynn's parallel path (solid state version). My core is not metglas, it's about the same size but ferrite for high efficiency and hi freq. applications up to 1 KW. I have tried different magnet strenghts, freq and also tried taking only the collapsing part of the output as explained in the attached paper. Still no luck. Without magnets it works as a standard high efficiency transformer I could easily move the coils for MEG type arrangement. My question is, do you actually see more out than in with your metglas setup?
    Did you try only one side of the magnet facing the core?
    Honestly I have no way of knowing if the MEG is OU right now. I would assume yes by the looks of it. My pick up coils were wound on this MEG i bought from someone. I would hate to take it apart. But as of right now its not JNL labs specs. The actuator coils are to spec.
    We want the core to hold B field and A field comes from the environment. It might take a small magnet to prime the core a little.
    Is it funny that the guys that know what is going on with the MEG have nothing at all to say. I wonder how they look at the world right now. I can't stand my neighbors but I certainly do not want them to suffer. Are the knowledgeable really scared of the powers that be or deep down do they feel like they want others to suffer?
    I ask this because I see avenues that are not being taken. If we remove the money and the fear from the scales of balance what do we have left?
    • #92
      Something to consider
      To buy a metglass core you need to sign forums and let them know what it is being used for. They want to make sure you are not making weapons of mass destruction. Call and ask them if you don't believe me.
      I could not of even made that one up..
      • #93
        With a resistive load my maximum resonant frequency is 480hz.
        • #94
          Could I ask why your are trying to generate power with the Flynn device?
          Article:Joe Flynn's Parallel Path Magnetic Technology -- by Tim Harwood - PESWiki
          • #95
            Hi Pengrove. Why do you call it resonant frequency? Are you driving it as a true LC tank circuit? Are your coils resonating at 480 Hz?
            About your question why I want to make power with the Flynn device... the answer is pretty obvious no?
            Or did you mean to ask why I didn't go for the rotored version? In that case the answer is that I much prefer solid state setups, although I've done a lot of research on pulse motors.
            Mario
            • #96
              Mario
              When the device starts to sputter I back the frequency down. So I balance whats going in vs what is coming out. It resonants and rings when its tuned to its sweet spot.
              She purrs at 22 watts 480hz 50%DC
              ITs really an amazing little device. I am very impressed. I have to be the first to get the thing to actually work in over a decade.
              • #97
                I used the IRFZ34N transistor instead of the Buz11
                • #98
                  I agree with this PDF. But you must remove the magnet stack to make it work.
                  Metglass third component
                  • #99
                    That's an interesting document, thanks for sharing. But I'd say the magnets are essential, else all you have is a transformer.
                    • Originally posted by Mario View Post
                      Very good point. Lets sit on that point for a second.
                      How can we say that the bedini SG is anymore than a transformer?
                      The MEG does operate as a typical transformer with a 50% duty cycle.
                      The DC should be between 4% and 28%. Then what Happens?
                      • The MEG is a solid state bedini device. Using Bedini Tech is the only way that it works. One magnet with the North pole in. No were in the patent do they say south pole flux enters the core from the magnet.
                        And never does south pole magnets enter the bedini SG.
                        People in the past tried to turn the MEG into a high frequency device with a bar magnet across the core. Neither of these techniques apply with bedini tech.
                        I went to the Class of Bedini. I know these things.
                        But I never graduated I got expelled.
                        • I still need to get the drivers but I thought I would share for criticism.
                          • Comment
                            • still trying to find the time
                              for some ****ed up reason my electronic supplier had no magnet wire.now ,so I butchered a micro wave for its magnet wire. now im going to try a joule thief circuit, just because its the easiest to build. will post results
                              cheers ztec2002
