A monumental law in Pure and True Physics that Albert Einstein did not realize is that equations that are not reduced to their smallest possible factors will always include and enable an equal yet inverse half-correct solution. Here's an exact example. The formula for the kite below is;
Flight = kite x Velocity of wind
The equation above and the image that portrays it, possesses two whole and separate solutions because the equation has not been reduced to its smallest possible factors. This equation can either portray;
1. A stationary tethered kite with air moving past it. or
2. A moving kite being propelled through stationary air.
One of the above is the true "realm" of the Physics and the other is the inverse half correct solution that occurs as a result of the equation not being reduced to (Acceleration x Time). Yet both produce the same solution of Flight.
We cannot tell whether the kite is tethered or whether it is being propelled. We cannot tell if the air is moving past the kite "or" if the kite is moving past stationary air.
Due to the fact that the equation has not been reduced to its smallest factors, the specific "realm" of the physics is not determined and so the equation then enables two possibilities. However the Flight (the left side of the equation) the numerical answer to both possibilities will be the same for both realms 1 and 2. Flight occurs whether the kite is moving or whether the air is moving past the kite. This is why Einstein's equation gave a correct "numerical" answer for energy and yet an incorrect "realm" answer for the very Physics of Energy.
And it's because of this fact that un-reduced formulas provide two equal yet opposite possible realms that Albert Einstein's error has been hidden for so long. The error has been hidden because E=mc2 gave a correct answer for the numerical value of energy and yet it gave a completely in-correct value for the realm of the actual Physics.
However now when we reduce the equation and write it in its true format;
Flight = kite x (Acceleration x Time)
the Acceleration is now directly connected to the kite. The above equation absolutely declares that for a period of Time the kite Accelerated. And when we write the equation in this manner the image, the specific realm of the physics, is then transformed into this;
We now know for fact that the kite is moving past the stationary air as opposed to the line being tethered and the air moving past a stationary kite. If the kite was tethered the equation would be;
Flight = Kite x (Air x Acceleration x Time)
With the Pure and True equation of the Acceleration of the kite we can then unify the Flight of the Kite with the Boat in a way that we were unable to do in the first image. Albert Einstein could not unify his energy equation with Gravity because his use of Velocity kept the very "realm" of the physics of Gravity a mystery.
When the two kite equations are then placed beside the two Energy equations we can clearly see how their compared realms of Physics are exactly parallel.
The incorrect equations that also provide inverse possibilities.
Flight = kite x Velocity of wind;
(possesses the inverse possible realm of air moving past a tethered kite)
Energy = mass x Velocity2;
(E=mc2 possesses the inverse possible realm of Mass being Energy)
The correct equations that portray the true physical realms.
Flight = kite x (Acceleration x Time);
declares for certainty that the kite is moving past stationary air.
Energy = mass x (Acceleration x Time)2
(declares for certainty that Light "within" Mass is Energy)
Unification Of Electricity Finally Discovered?
GB
GB
