Yep Zooty
They come out easily enough, being fridge magnet type of stuff, but it's very useful to keep it where it is.
I use that strip to attach magnets for power tests. Small neo's just clip on to the outside of the hub, with enough force to stay where they are (up to and including 12V) yet can be moved around too.
I'm not sure whether full out speed is what's needed, but that's how I set mine up.
Interestingly, with having the relay coil off center from the rotor, if you move the magnets around you can have it run in attraction or in repulsion.
An LED with suitable resistor on the output allows tuning too. You can make sure that the Hall sensor switches on and off, by watching the LED go on and go off.
Building one up now that I hope shows flexibility of build. It uses a KN2222A, a 1N4148 diode instead of the LED across Emitter and Base and a Hall sensor that came off the very fan assembly that formed the rotor.
Just 'tuning' it now. It runs perhaps quicker than the original. I had 2 square magnets and 2 long thin magnets..so broke one of the long ones in half, with the internal cutter of a pair of pliers. Many folks in the R/C community swear that ruins the magnets, but it never has for me. Got a few 6 gram planes flying around with bust apart magnets in their rudders
If nothing else...these things are very quick to build and teach us much about tuning magnets, effects of flux change, speed to power out differences and more.
