[ Moved here from http://www.energeticforum.com/renewa...tml#post140897 ]
Maybe there is a thread about this, if not, there should be:
When replacing batteries with capacitors and/or vice versa
just keep in mind they are not the same.
In its basic form caps are plates storing charge and batteries are chemical.
It is my belief that batteries charge from voltage and capacitors from current
so their behavior is quite different and they can not replace each other in every situation and give the expected result.
If it is the case, that batteries charge from voltage and capacitors from current, then, if possible,
caps should be charged in series and batteries in parallel,
which means the TS work well with batteries but not so well with caps.
If it is the case, it also means that the chant
"to prove OU replace the batts with caps or its a hoax"
is just plain stupid (or just a smart way of diversion).
/Hob
/Hob
