from http://www.energeticforum.com/new-me...c-table-3.html
i 'll refer you to this thread: http://www.energeticforum.com/renewa...phenomena.html
i did a research on magic square and ended up in a site, hold and behold, talking about fractals in nature
"Patterns of Nature" Sacred geometry, Phi, Fibonacci Number
Indeed, As i mention in all my post, in layman terms "everything is fractal", considering this simple statement, you would imagine that behind every apparent law that controls the universe are just an effect example:spatial resonance, lies the true cause: ie Fractal Resonance.
see also: http://www.energeticforum.com/renewa...-crystals.html
Now let's consider this the electromagnetic spectrum is also a Fractal/Constructal system
in that case it should obey the same law as all fractal/constructal system:
in other words, it should obey the
E=M3/4
watch this video
YouTube - ‪Fractals: frequency, the heart, and cancer‬‏
the same holds true for the table of Elements
see post#23 http://www.energeticforum.com/147095-post23.html
Magic Squares
Another source of transcendent proportion is based upon an arrangement of numerials within adjoining squares such that their total adds to the same value in each column; vertically, horizontally and diagonally.
A combination of longitudinal frequencies can create complex geometries and structures. Remember that each chemical has its own "scalar signature".
The constructal law puts forth the idea that the generation of design (configuration, pattern, geometry) in nature is a physics phenomenon that unites all animate and inanimate systems, and that this phenomenon is covered by the Constructal Law stated by Adrian Bejan in 1996: "For a finite-size (flow) system to persist in time (to live), its configuration must evolve such that it provides easier access to the imposed currents that flow through it."
E=M3/4
It is called Kleiber's Law.
It states that the energy needed by an organism at rest (not doing any specific exercise), is not proportional to its mass, but sub-linear.
It can be attributed to many factors and one of them is that the more massive an organism/element/wave is, the less surface per volume it present. If the organism is represented par a sphere of diameter D, volume scale with D^3, but surface scales with D^2. But energy produced by the body is proportional to volume, while energy lost is proportional to external surface.
To sum up, a little body loose a lot of heat and its little body can not sustain it. Therefore there is a lower limit to the size of hot blooded animals, which is bigger than the one for cold blooded ones.
