What you said is true. Many areas of what we are all researching here do have connections which are quite often overlooked.
I'm off to Sydney for a few day for the boat show so I will be getting back to this "tree business" next week.
I was watching some of Bedini's youtube vids regarding his concrete beer can battery experiments and found them to be quite interesting. Would be a little easier to carry around than a tree battery.
Cheers,
Steve
quite true , but i don't think your concrete batteries would be able to emit, transfer energy from one place to another, while you contact your friends using a tree....this is the point i have just discovered, that is a fractal construct has an 'efficient function', it has, as my friend Slider2732 calls it, a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
what better fractal construct than a tree
Signs and symbols rule the world, not words nor laws. -Confucius.
Plasma astrophysicists at the University of Warwick have found that key information about the Suns 'storm season is being broadcast across the solar system in a fractal snapshot imprinted in the solar wind. This research opens up new ways of looking at both space weather and the unstable behaviour that affects the operation of fusion powered power plants.
As scale decreases, the number of dimensions of k-Minkowski spacetime (red line), which is an example of a space with quantum group symmetry, decreases from four to three. In contrast, classical Minkowski spacetime (blue line) is four-dimensional on all scales. This finding suggests that quantum groups are a valid candidate for the description of a quantum spacetime, and may have connections with a theory of quantum gravity. Image credit: Dario Benedetti.
Dr Tony Roberts and PhD student Christophe P. Haynes, from the School of Maths and Physics, showed the fractal-Einstein and Alexander-Orbach laws can fail in some instances, and have derived a new law to replace them. (maybe this is the 6th law of this fractal universe see post: http://www.energeticforum.com/148789-post127.html )
Dr Roberts said this new discovery had implications for predicting material properties; how disease spreads through society; mapping how wild animals forage for food; and improving the internet.
On Friday, Emory mathematician Ken Ono will unveil new theories that answer these famous old questions.
Ono and his research team have discovered that partition numbers behave like fractals. They have unlocked the divisibility properties of partitions, and developed a mathematical theory for "seeing" their infinitely repeating superstructure. And they have devised the first finite formula to calculate the partitions of any number.
Nanoantennas work in much the same way as regular antennas, except they collect light instead of radio waves and are millions of times smaller.
The reason that Professor Juodkazis nanoantennas are so unique is that they are fractal that is they consist of repeating patterns, with the shape of the smallest feature replicated to make identical, yet larger structures.
Researchers at the University of Warwick have found what could be the signal of ideal wave "surfing" conditions for individual particles within the massive turbulent ocean of the solar wind. The discovery could give a new insight into just how energy is dissipated in solar system sized plasmas such as the solar wind and could provide significant clues to scientists developing fusion power which relies on plasmas.
At this particular scale they saw that the levels of turbulence switched from being mutlifractal to single fractal pattern. This single fractal pattern turbulence appears just right to create and sustain waves that can interact with the individual particles in the solar wind
Just as the heartbeats of today's electronic devices depend on the ability to switch the flow of electricity in semiconductors on and off with lightning speed, the viability of the "spintronic" devices of the future -- technologies that manipulate both the flow and magnetic "spin" of electrons -- will require similarly precise control over semiconductor magnetism.
The model takes in basic meteorological data such as average annual temperature, precipitation, humidity and solar radiation and computes how tall a tree is likely to grow under those conditions. The concept sounds simple enough, but lead author Chris Kempes, a PhD student in MIT's Department of Earth, Atmospheric and Planetary Sciences, says it took an understanding of plant mechanics, as well as fractal geometry, to accurately link tree height with meteorology.
One thing I keep coming back to within all the great research you are posting...is about thoughts on forests.
All those 1/4 wave transmissions and receptions going on ! Bunched up they may seem to be, but the germination and actual placements of each tree, their success or failure at exact points on the forest floor, may be due more to resonance than the luck of where a seed may land.
If that were the case, then the expectation would be linear grids of uniform distance all across the forest. However, every tree constructs slightly differently, soil conditions are a factor, some have to deal with placements like the apple tree above, some are on uneven ground. Perhaps, therefore, that's why a forest does not have the appearance of a conventional grid system and yet may work as one - like a closed loop self runner always aiming for a COP > 1 hehe.
I haven't made a Starship coil yet, but if you look at one, the energy lines cross each other, creating impressive grid lines of conductivity. Does a forest work in the same way ?
Imagine you are walking through a forest. All around you are trees of different species, age, size and height. It looks pretty random, right? Wrong.
In research funded by the National Science Foundation, Brian Enquist of the department of ecology and evolutionary biology at the University of Arizona and his team have discovered a secret in the trees: Hidden among and within the architecture of the branches are fundamental rules that link the size, shape, age and in fact everything about a single tree to all the trees in a forest.
This rule or code reoccurs as the tree grows, creating a fractal a repeating pattern like a spiral of daughter branches emanating from the mother branch or tree trunk.
enjoy...
DNA could act as an antenna in electromagnetic communications
A theoretical physicist has presented research that shows bacteria might transmit electromagnetic signals to produce species-specific wavelengths.
According to research presented by Northeastern University physicist Allan Widom, based on existing knowledge of DNA and electrons, bacteria can indeed communicate.
As i said before, we are all "Fractal Antennas" amongst other things
"My second discovery was of a physical truth of the greatest importance. As I have searched the entire scientific records in more than a half dozen languages for a long time without finding the least anticipation, I consider myself the original discoverer of this truth, which can be expressed by the statement: There is no energy in matter other than that received from the environment." Nikola Tesla
I would like to show you a little something i found out today through re-reading my posts, the following are various info I posted that would lead you to conclude what a tree/forest is ....
Needless to say that Trees are Fractal in shape...and more
from a 2002 article. Unlike so many other promising breakthroughs this is one that has been widely implemented.
To further quote from the article: "The innovation, called Fractal Structure Circuit(TM) (FSC), uses fractalized conductor paths to replace the capacitors, inductors, and resistors in "RLC" circuits."
And another quote: ""Virtually every electronic device uses coils and capacitors to form RLC circuits. These discrete components are arranged by tried and true rules to get the circuit to perform as needed. What we've done is ask: can a fractal pattern, with its self-capacitance and self-inductance, be used to eliminate components and still get the equivalent RLC circuit? We've found that the answer is yes; and in most uses, especially at microwave frequencies, all components can be replaced by conductive fractal patterns or 3D structures."
And one more blurb from that article: " Looking at the Fractal Structured Circuit(TM) one sees, for example, a beautiful etched copper pattern replacing the usual traces connecting button or canned shaped capacitors and coils (or their SMT counterparts). "
Here is the link to that article. Fractal Antenna Systems, Inc.
"Grants Pass, Ore. (AP) - Physicist Ed Wagner says he has found evidence that trees talk to each other in a language he calls W-waves.
"If you chop into a tree, you can see that adjacent trees put out an electrical pulse," said Wagner. "This indicates that they communicated directly."
"Explaining the phenomenon, Wagner pointed to a blip on a strip chart recording of the electrical pulse.
"It put out a tremendous cry of alarm," he said. "The adjacent trees put out smaller ones." .....
"People have known there was communication between trees for several years, but they've explained it by the chemicals trees produce," Wagner said.
"But I think the real communication is much quicker and more dramatic than that," he said. "These trees know within a few seconds what is happening. This is an automatic response."
"Wagner has measured the speed of W-waves at about 3 feet per second through the air.
"They travel much too slowly for electrical waves," he said. "They seem to be an altogether different entity. That's what makes them so intriguing. They don't seem to be electromagnetic waves at all."....
Comment. In addition to the above discovery, Wagner, who holds a PhD in physics from the University of Tennessee, has detected electrical standing waves in trees. The voltage measured by electrodes implanted in trees goes up and down as one goes higher and higher up the trees. Wagner's work has been published in Northwest Science, but we have not yet seen it. Incidentally, electricity does seem to affect plant growth, as described in our handbook: Incredible Life.
last but not least:
Oh did I mention a fractal antenna is: a tuned LC circuit
David Wilcock points to some studies showing that DNA is a biological receiver of information from the fractal field of information emanating from source in his recent blog: The Source Field Investigations -- Full Video!
It is not "a one way communication", It receives and emits see post http://www.energeticforum.com/136257-post20.html ...however the point i was trying to show is that if you read the previous post on tree is that a forest is a Multiple LCR resonance Circuits, learn from it and you'll have your resonance (and vice versa to turn a tree into radiant energy collector with Multiple LCR resonance Circuits )...
A Fractal set up to collect from a fractal universe....like DNA
This is not quite the case.
Two tuning forks, share each others energy. The problem with the situation lies in the fact that the reaction (what we call BEMF in electrical terms) from the pick up tuning fork is in phase with the source. Any work used on either fork has a reaction in phase with the source. I have seen this countless times electrically, and acoustically it works out in very much the same way, except that the inverse square law is modified. Look up inverse law for acoustic phenomenon)I can show the math behind this, and I have several demonstrations which talk about this.
What IS very interesting that the tuning forks will have a preferred distance from one another for power transfer. There will be a radial distance around the source of vibration which will constitute the point of maximum power transmission, and the greatest ratio between high coefficient of restitution (Q in electrical) and energy transferred.
This means that around a resonance point, there is a circle drawn around it that represents the best possible spot to place a receiver of the same tune, which will subsequently have its own circle drawn around it. If you want to use more than one receiver, then you must realize that each additional receiver has its OWN preferred distance, or radii, or circle drawn around it which represents its transmission points for all other receivers and the source. Placing all of the resonant structures at these points creates nifty geometric patterns, one of the most recognizable being a 6 pointed shape much like the star of David.
To see this happen,
1)draw a point, now draw a circle around it. This represents your resonant source, and its circle of preferred transmission.
2)Pick a point on the circle, this will represent your receiver, placed on the circle of preferred transmission. Because our receiver is resonantly the same as our source, it too will have a circle of preferred transmission, which is the same size as our source, meaning they will have circles of equal circumference.
3)Draw a circle around your reciever the same size as the circle from your source. Because they have the same radius, and each is a radius distance separation, the circumference of each cycle will touch the center of the other circle.
Now if you want to add more receivers, they should all have preferred transmission points which intersect at logical geometric spaces, for example here are two receivers and one transmitter.
If you follow this geometric pattern around the transmitter, you will end up with 6 places where a receiver should be placed. If I were to draw this out with the transmitter and 6 receivers it would look like this...
Which brings photos like Edwin Muller photographs of cystaline elements atoms into perspective.
