If you look at the picture, it mention that both object have to resonate to the same frequency; well you don't have that problem with trees:
see post 75 and 76
http://www.energeticforum.com/143047-post75.html
The Magnetic Resonance Amplifier (i think if you replace the coil with a caduceus coil, you'd get a whole lot more juice)
Joel McClain & Norman Wootan: Magnetic Resonance Amplifier ~ Collected Papers
With low-level ultrasonic input signals, the Magnetic Resonance Amplifier (MRA) produces usable direct current power at levels above unity. This circuit is based upon the work and theories of John Ernst Worrell Keely, and is offered into the public domain in his memory.....
....In the MRA schematic below, there is a tunable low-power oscillator which supplies a signal to one side of a barium titanate transducer. The opposite side of the transducer is connected to a primary coil which is wrapped around a barium ferrite magnet core. The opposite end of the primary goes back to the oscillator.
.....The MRA is a series resonant LC circuit in which power gain is attainable as a result of the increase in effective impedance under certain operating conditions. When the series impedance increases, primary current is reduced. When the power available from the secondary coil either remains the same or increases as the primary circuit impedance increases, a power gain occurs.
Note: the application of a coil inside a coil design is again being used in this experiment
The caduceus coil illustrated in Fig.1, basically consists of ordinary insulated copper wire wound in a double-helix around a ferrite core. THIS COIL HAS REPEATEDLY BEEN FOUND TO VIOLATE ESTABLISHED LAWS OF ELECTROMAGNETICS AND HERTZIAN WAVE THEORY WHEN A HIGH FREQUENCY CURRENT IS INJECTED INTO IT....
....First. This apparatus has zero impedance - unlike an ordinary coil. when fed electrical energy the wire in the Tensor coil does not get hot.
Secondly. It has infinite resonance - unlike an ordinary coil which will resonate chiefly at its natural fundamental frequency and weakly on the second or third harmonic, the Tensor coil is capable of resonating strongly on any number of frequencies randomly spaced in the spectrum. The signal pumped into such a coil strangely enough cannot be quantified (detected) by standard RF (radio frequency) detection apparatus. Many "Ham" radio operators and electronic technicians who have used these coils, are completely baffled by them
update:
In the The Magnetic Resonance Amplifier, a barium titanate transducer is used here, you can replace it with tourmaline
tourmaline
cheers
