Resonating resonator circuit
  • Resonating resonator circuit
    This is for anyone who would like to build it as I do not have time at the moment, but it should work even if I need to make a few adjustments.
    enjoy
    Mike
    http://www.energeticforum.com/attach...or-circuit.jpg
    a little explination
    I thought I would give a little bit of explination to the circuit.
    The first part is as the Prof: has but with a few alterations that I think will make it work better. This is our frequency generator which is very low power consumption, this then feeds the pulse "pump" to the decoupling cap C2. Feeding in after C2 is our bias voltage which all goes to a parametric amplifier, the Faraday loop is our LC which is also part of our special transformer/antenna system and feed back and power load output.
    This is "by design" to resonate with the ambient and draw in extra energy, the output coil setup should be temperature measured before and after starting the circuit, a temperature difference should be seen if the circuit is running as by design.
    A neon and not a led should be used on the secound output as there will be quite high voltage there.
    The Faraday loop is place exactly in the center of the 15T coil and the two pick up coils are either end of the 15T coil. The 15T coil should be of a dia: of 1.5mm and the pick up coils half this size.
    Mike
      coil setup
      http://www.energeticforum.com/attach...ransformer.jpg
      The coil setup
      Mike
        boy you are on a roll sir
        I will take a look!
