this is a follow up on the thread i opened on Trees as radiant energy collector (this is also an open source project
http://www.energeticforum.com/renewa...collector.html
I am branching out (no pun intended) to start this separate thread on how to build a water coil, I'll transfer some info i already posted but are directly related:
From Slider2732
James H. ROGERS
Underground & Underwater Radio
side note
Another version of this "water" high frequency generator:
the Jet Turbine by Viktor Schauberge with the direct current passing through the cone-shaped rotor
James H. Rogers: Underground & Underwater Radio Antenna
is this set up is relevant to our subject:
http://www.energeticforum.com/renewa...r-circuit.html
replace coils with water coils
Magnetic Induction of Water
template
I was just reading through this thread:
http://www.energeticforum.com/renewa...variation.html
and i also read the info on pesn:
Dr. Steven E. Jones' circuit gives evidence for 8x overunity
I would like you to check out the following image, it is a "google map" of Brigham Young University (marker B)...
...Indeed the Great Salt Lake is close by (here is your large coil)
from the same thread
http://www.energeticforum.com/142754-post40.html
I hope you guys would contribute your knowledge because I'm sure this would inspire some great design ideas...for instance wouldn't be great to be able to test a water coil made for the Bedini Motor
From Slider2732
A coil made of water appeals as an idea
If water was pumped, at the resonant frequency of the tree, in a spiral pattern at the base of the trunk, could it be imagined that energy would literally flow ?
It would be somewhat analogous to a battery circuit.
The Rogers laboratory, which comprises several large rooms, is lined on all sides with glass cabinets containing electrical apparatus which he has invented from time to time through his studious career. A novel and original high frequency generator was another of the devices that greatly interested the writer. It employed a jet of water shunted by a large capacity, the stream of water being connected to a high potential source of direct current. High frequency currents of any range up to the limit of audibility, or about 30,000 cycles per second, could be readily obtained with this apparatus.
Supposedly any conductive material can be made into a generator in one of these ways. Now as I pointed out liquid conductors do have different properties than metal conductors, primarily in how they transmit a charge as I pointed out in the Experiment #1 paper. I can't find any information that would suggest that you COULDN'T use water as a generator if you followed the basic rules of building and operating such a generator. There are many possibilities along those lines which I plan
to deal with separately. In this posting I just wanted to look at generators in general....
... In thinking about this in relation to water I decided that it would be interesting to think about weather or not water, used as the coils in a generator, would work. We already know that the Hydrogen Bond in water is weakened by the proximity to an electromagnetic field and we know that water (with an electrolyte) acts as a conductor. The fact that it is a conductor satisfies the main requirement for induction of electric current and the weakening in the presence of an EMF would suggest that, as above, a charge could be inducted by proximity. With these two factors in favor of the idea of water as the coil in a generator would seem to indicate that it would be possible to construct a mechanism which would exploit this and cause an electric current to be generated.
Retired Physics Professor, Steven E. Jones is working on a simple overunity circuit that he has seen go as high as 20 times overunity; documented on a state-of-the-art Tektronix 3032 oscilloscope at Brigham Young University producing eight times as much energy as was required to run the solid state circuit. One of his friends, Les Kraut, has replicated the circuit and also achieved eight times overunity...
..."I don't know where the energy is coming from, but it's coming from somewhere," he said.
