The research of Callum Coats takes us on a journey through the life and inventions of Austrian ecologist Viktor Schauberger (1885-1958). Now, for the first time, you can view the evidence in this detailed, three-hour illustrated lecture presentation on this two video set. Viktor Schauberger was a genius whose ideas were far ahead of his time. He worked as a "forest-master" in the Austrian Alps
“Signs and symbols rule the world, not words nor laws.” -Confucius.
Excellent sucahyo ; a nice addition to our research
The question is, how would you go about building such a contraption, for testing?
We made it horizontal. We use copper pipe to twist the water output to counter clockwise rotation, then to use the output to make a big clockwise water vortex on a bucket with small hole in the middle. Some people who try this report effects usually associated to m-state.
Thank you sucahyo , i will definitely explore this set up , do you happen to have a link on this with pics included?
In the meantime, I would like to add the following on water capacitor and pulsed-power systems:
Pulsed power is the term used to describe the science and technology of accumulating energy over a relatively long period of time and releasing it very quickly thus increasing the instantaneous power.
transfered info from the tree as radiant antenna thread:
Kelvin water dropper
The simplest setup for this is as pictured at right. A reservoir has two holes that drip water (or other liquid). The streams of dripping water each pass through a conducting ring (replace with one or two mobius strip), and land in a bucket. The buckets must be electrically isolated from each other and from their environment. Similarly, the rings must be electrically isolated from each other and their environment. The left ring is electrically connected with (wired to) the right bucket. And the right ring is wired to the left bucket. It is essential that each ring be placed around the point at which the stream of water passing through it first breaks into drops.
If the buckets are metal (conducting) the wires may be attached to the buckets. Otherwise, the bucket-end of each wire can just sit in its bucket, as long as it is contacting the water in the bucket.
you could try also a water/methanol mixture Kelvin Experiment
each drop of water/Methanol Mix is a tiny capacitor that will discharge its energy when it hits the bucket
(see: Velocity Compression in Cylindrical Capacitor Electrospray of Methanol-Water Mixtures)
or just a water/methanol Capacitor to charge the energy produced by the electrostastic created by water (or water/methanol) drops
Have you tried the Kelvin Experiment on your M state Water?
the point I am making here, is that besides Schauberger, people tend to overlook the nature of water.
Have you read that Schauberger use the Kelvin water droplet output for its M-state kind of effects too? To the point of even increase combustion property of petrol?
We believe that the m-state (ORMUS) materials dissolved in water are superconductors which respond to magnetic fields. (perfect for a water capacitor ) We have observed that most water, when swirled in the presence of a magnetic field can be separated into two components; a magnetically responsive component and a non-responsive component. Magnetic traps of various designs have been devised to take advantage of this property in order to concentrate a form of the ORMUS elements. This concentrate tends to be "oilier" than ordinary water, it also tends to be lighter than ordinary water especially when it is moving in relation to magnetic fields. A more detailed look at this theory can be found in my article "Patterns of Motion".
Trap designs:
There are a number of magnetic trap designs. These designs take advantage of the magnetically induced properties of the ORMUS elements in a variety of different ways.
The Storage Trap was my first attempt at trap design. It is designed to repel the good water downward into the bottom of the trap. It is a good design and probably is capable of concentrating ORMUS more than any of the others but the down side is that it works on a batch basis. It is expensive but fairly easy to build and operate.
The Storage Trap
The Vortex Trap was my second design and it works quite well but it does not lend itself to unattended operation or indoor use. It was designed to repel the good water into the center of a vortex in horizontal operation. It is cheap and easy to build in its PVC format and quite expensive and difficult to build in its clear acrylic format.
The Vortex Trap
Additional images of an improved version of the Vortex Trap can be found at:
vortrap2.htm
In kelvin experiment, i think that each drop of water act as a rapid charging tiny capacitor that will discharge its energy when it hits the bucket
What we are trying to do here is not to recreate M state water but to test it in the Lord Kelvin Experiment and see what it does. Read post#7 to 10: http://www.energeticforum.com/142840-post7.html
also I would note also that if you are going to create Mstate Water or test it in the kelvin experiment try using as a 1st step the collapsible bladder (it may facilitate the creation/concentration of ORM in water ex:your heart ):
Though in video water flowing from tap is shown it works same way if there is a reservoir at starting of the collapsible bladder and if small pipe is connected to it.
Clearly the processes of suction and pressure need to be examined.[No beneficial, natural exchange can take place solely under conditions of pressure. . Viktor Schauberger
Remember what Tesla said:
Experience is made before the law is formulated, both are related like cause an effect. Nicholas Tesla
2nd "law" violations > Heat to mechanical energy conversion
Victor Schauberger
(1/3) > >>
allcanadian:
In another thread I had mentioned that I had just finished reading "the energy evolution" by callum coats on Victor Schauberger. You guys have got to read this, Its everything I was hoping it would be. His terminology is cryptic at times, but you can easily get the drift of what he was doing.
Here are some very interesting things that fall in line with conventional science, that you won't normally find in a textbook.
Outgassing:
-water vapor in air will spontaneously release CO2 and O2 under conditions of low pressure/high temperature increasing it's volume
-water vapor in air will absorb CO2 and O2 under conditions of high pressure/low temperature decreasing it's volume
If you think outgassing has no power see Lake Nyos: plan for degassing lakes Nyos and Monoun, Cameroon. Gas disaster at Nyos: mitigation of a natural hazard at Nyos. - notice the 60 foot geiser powered by outgassing-tesla and schauberger proposed this idea in the 1920's
-so outgassing coupled to other effects has tremendous power
Charge Seperation:
-Like charges repell(- -) unlike charges attract(- +)
- the atmosphere has a (+) charge growing by 100 volts per meter vertically, the ground has a (-) charge
-water vapor from a nozzle pushed through a charged ring can produce over 20,000 volts - (see Lord Kelvin water drop static generator)
- If water vapor/air with high negative charge moves through a pipe in a swirling motion, and the pipe has a high negative charge then there is no frition because the center flow repells from the pipe- thus no boundary layer interactions especially if the flow is cooled reducing its volume as it moves(centripital inward flow)
- If a vortex of cold (+) charged air/water vapor under centrifugal pressure has a flow of warm (-) charged air/water vapor enter from below into the low pressure core, the core will implode and outgass simultaneously producing an upward flow and suction at the base of the vortex, the opposite charges of outer vortex and core will produce an inward centripital motion, centripital motion=increased outer vortex velocity
- In water(H2O) Oxygen has a (-) charge and 4 electrons, 2 of these electrons are paired to two Hydrogen atoms of (+) charge. The two unpaired electrons of the Oxygen atom will turn the H2O molecule to face any (+) charge.
-Under extreme conditions(centripital motion/thermal gradient/charged state) it is possible that Hydrogen could disassociate from the H2O molecule, Hydrogen (+) would move to the (-) vortex core and upwards with extreme velocity, Oxygen (-) would accelerate downward the the outer vortex.
O- Oxygen= pressure force-seperation actuates centripital force
O- transverse potential=electricity
H- Hydrogen=suction force-combination actuates centrifugal force
H- longitudinal potential=magnetism
This is the "Original" structured water device that is
used by "Joe Cell" and "Moe-Joe Cell" inventors
to create highly energized water for their hydrogen cells.
krypt013:
I have read reports of some water fuel cell researchers that have reported
1)That the material composing the white powdery coating of a conditioned water fuel cell exhibited similar properties such a the David Hudson ORMES material. Such as when the material is subjected to heat it loses some of its mass and volume which returns the temp normalizing. A definate sign pointing to the presence of ORMES in the material sample.
2)Reports of researchers adding small amounts of sea salt to the water and noticing that the cells gain a white precipitate alot more rapidly, as well as more precipitate forming.
Now remember from the David Hudson lecture that is found at http://www.eskimo.com/~billb/freenrg/hudson.txt that Mr.Hudson had to use a very unique form of chemical analysis to even identify the presence of the ORMES in the material. I russian method in fact that had been buried in a trade journal that he decided to give a try after since dumping millions of dollars and years of time into trying to identify this mysterious substance that seemed to thwart all conventional methods of chemical analysis. So unless the free energy researchers currently working in the field of water fuel cell research had used the same analysis technique as David Hudson then they wouldn't even of seen the presence of ORMES in the sample, and they would still be scratching their head wondering how some inert substance must be affecting the process. Perhaps the white powdery coating having a high dialectric constant does play a part in the reaction, but I feel that exploring the possibility of whether ORMES might play a role would be a worthy set of experiments to conduct. Unfortunately I cannot personally fund this endeavor at the moment, and do not have a WATER FUEL CELL to conduct experiments with. But if I had the funding I would try having one water fuel cell running distilled water verified not to contain any ormes what so ever as a control group, and several other wfc's running synthetic ORMES, sea salt extract ORMES, magnetic vortex trap water, etc and I would 'condition' them per Ravi Rajus method, and examine the data to determine if in fact it is having an effect upon the process.
Very interesting vortex apparatus: looks like a miniaturized version of the vortrap. It comes from japan so far the best I've seen
Once again, great information you bring to the table!
!! N E W !!
Riverforest Corp. proudly announces additional Micro-Nano Bubble products to serve rapidly growing applications. We believe these new products will support your projects better than ever!
!! N E W !!
I just remembered a small info that most people dismiss but through what i have posted; this would make complete sense now:
Dowsing
Finding Water With A Forked Stick May Not Be A Hoax
Usually, the boundary between science and science fiction is as distinct as the difference between the 6 o'clock news and "The Simpsons." Wherever the line blurs, you're bound to find contentious debates. One of the longest-running of these disagreements centers on dowsing, a supposed sixth sense that enables people to find underground water using a forked branch, pendulum or pair of bent wires. There is no scientific reason why dowsing should work. Yet, it apparently works well enough and reliably enough to keep the practice alive.
The success of dowsers doesn't surprise the people who know the most about finding underground water, hydrogeologists for the United States Geological Survey (USGS). They point out that the United States is so water-rich you can get wet drilling just about anywhere, if you drill deep enough. Far harsher criticism of dowsing and dowsers comes from outside the mainstream scientific community. Two organizations, the Committee for the Scientific Investigation of Claims of the Paranormal (CSICOP), CSI | Skeptical Inquirer Index, and the James Randi Educational Foundation (JREF), James Randi Educational Foundation, are actually working to discourage the practice, which they both dismiss as paranormal nonsense. To make their point that dowsing is a sham each has staged demonstrations in which dowsers were asked to find buried pipes. Dowsers did no better than the laws of chance predict. JREF is so confident of its position it promises to pay $1.1 million to anyone who can "prove" dowsing works.
The nanoheterogenous structure of water can be determined by interactive phenomena such as epitaxy (the transmission of structural information from the surface of one material to another without the transfer of any matter), temperature–pressure processes during succussion, and formation of colloidal nanobubbles containing gaseous inclusions of oxygen, nitrogen, carbon dioxide, and possibly the remedy source material.
Preliminary data obtained using Raman and Ultra-Violet–Visible (UV–VIS) spectroscopy illustrate the ability to distinguish two different homeopathic medicines (Nux vomica and Natrum muriaticum) from one another and to differentiate, within a given medicine, the 6c, 12c, and 30c potencies
Very interesting info, It is true that the use of crystal to help tune an oscillator maybe the fastest way of getting results. We do use quartz to run our watches, why not use other type of crystal to help tune a water coil
Capacitance Antennae In a device known as a capacitance antenna, the conductor or coil serves to give rise to a magnetic field by briefly conducting or consuming an electric charge. As the electric charge is consumed it flows through the coil and creates a magnetic field with magnetic forces moving through the field lines. A dielectric or condenser is placed in the magnetic field. The dielectric is composed of many inner layers of an insulating substance like silica. As the magnetic current moves through the dielectric it creates weak electric fields in the many layers of the dielectric where the layers cut across the magnetic field lines. As a result an electric field is created around the dielectric when a capacitor is placed into a magnetic field. The electric field in turn is once again taken into the coil for a brief conduction which once again creates a magnetic field around the coil.
