How to build a water coil
  • The data reveals the shift of the resonance is positively correlated to the number of elements in the fractal form.
    Fractal Antennas
    If you think out of the box, the shift of the resonance is positively correlated to the number of elements in the fractal form can also be applied to how you set up coils (strands and positioning), crystals etc...
    It applies to fractal forms you try to build
    • new info on use of water:
      Drug Discovery with Computational Chemistry - Technology Review
      A startup is banking on new software that incorporates the energy of water molecules into chemical models.
      just a reminder, for those interested in this thread you can print each page in pdf using a pdf printer (search google)
      • one more little detail that must be known about Water, is that it is the only molecule that exist on earth in all three forms: Liquid, Solid and Gazeous
        Water facts
        I just wanted to add a comment here, in reading the above mentioned article, i found this interesting:
        - The fact that H2O can exist as a solid and gas as well as a liquid at Earth's surface is important in regulating the climate of Earth.
        and it got me thinking about the Moe Joe Cell, and if actually starting with a small block of ice ( alkalized water) would not yield higher energy?
        • I found a little piece of jewel kind of information
          there are ten thousand molecules of water per molecule of protein.
          Quantum electrodynamics calls for the existence of long range electromagnetic fields that can be transmitted by large - hundreds of angstroms -coherent domains present in water (adapted from E. Del Giudice & E.Preparata, 1994, Journal of Biological Physics, vol. 20, p. 105).
          Such long range EM fields would be capable of transmitting the EM message coming from molecules, thus generating a long distance specific attraction between two molecules with matching spectra, excluding non-resonating, unwanted random events. The field resulting from the aggregation of the two coresonating molecules would obviously exhibit a different frequency which would then coresonate with the next molecule or cluster of molecules which intervene in the next step of the biochemical reaction, and so forth and so on..
          Water facts
          • Just had my first Eureka moment at http://www.energeticforum.com/renewa...tml#post148371
            OMG, i can't believe i forgot to check but i already posted in the thread http://www.energeticforum.com/new-me...dic-table.html two experiments that would prove your suspicions Dave and mine as well Water + Quartz is the KEY
            starting from post #79
            Now for those wanting to move on to the next level, i would like to propose matching 3 components i have been talking about (i'll try it first on seeds)
            the Caduceus Coil (see these two posts: http://www.energeticforum.com/143400-post85.html , http://www.energeticforum.com/143721-post92.html )
            Quartz Test Tube
            and Water
            i intend on repeating the experiment i ran a while back, but connected to a low voltage battery (see:http://www.energeticforum.com/143784-post94.html )
            maybe add fast growing seeds to see the effect it has on them
            feel free to try your own variant but share with the rest (nobody likes a leech ), try to test it using Pacific ocean water, and see if it diminishes the radiation level...a simple experiment that can be tried for many application....also it could act as a salt water capacitor
            I don't have the apparatus to check, but you could check if two water filled (alkaline maybe like moe joe cell) quartz test tubes with similar caduceus coils wrapped around would resonate in unison
            respect the open source protocol
            • I am currently reading this article:
              Oleg GRITSKEVITCH
              Hydro-Magnetic Generator[
              I conducted the work on the theory and creation of the electrostatic generator-converter ‘hydro-magnetic dynamo’ about 20 years.....
              My hydro-magnetic dynamo is a large-scaled emission-free electrical generator, which does not require external fueling. The dynamo is capable to power larger transportation vehicles such as buses, trucks, ships, locomotives, and airplanes. Doubt remains about making dynamos compact enough to power automobiles.
              While three experimental prototypes have been built with Russian and Armenian expertise and equipment, a fourth demonstration prototype needs to be built with more modern Western engineering expertise and equipment to verify dynamo performance claims and to further explore the dynamo’s potential capabilities. Performance claims are as follows: Dynamos are scaleable fro 100 kilowatts to 1,000 megawatts. One 1000-megawatt dynamo is about the size of a two-car garage. For comparison, Hoover Dam’s 17 generators have a total capacity of 2,000 megawatts. A dynamo can run continuously for about 25 years or more with little or no maintenance, no external fuel source, and no pollution. If a dynamo’s output is 1 megawatt, its’ total input power is approximately 10 kilowatts; therefore the dynamo’s energy efficiency is about 10,000/
              Schematically, the dynamo is an electrostatic transformer, or in other words an electrostatic voltage multiplier.
              you know that an invention has potential if it is scalable (one of the principles of fractal )
              Oleg V. Gritskevich (Gritskevitch): Hydro-Magnetic Dynamo -- A patented, prototyped over-unity electrical generator
              • I just want to comment on what i just posted previously:
                ...even economically talking
                Ok, let's take that backwards, if you know that some inventions such as Tesla's Transmission etc... are Scalable, well you actually have a major clue in your hands...Indeed, it is scalable that means one of the pillar of fractal design has been respected..now all you have to do is find the other fractals...
                as I posted here: http://www.energeticforum.com/renewa...-circuits.html
                But what i can tell you for sure is once your mind realizes the true meaning of fractal, and that it is not just in the shape of nature but also in the process/engine...well let's put it this way, the shape becomes the engine
                A fractal is "a rough or fragmented geometric shape that can be split into parts, each of which is (at least approximately) a reduced-size copy of the whole,
                and if it is fractal/scalable, that means it imitates a process found in Nature
                • and if it is fractal/scalable, that means it imitates a process found in Nature
                  I found the "natural process" example for the Hydro-Magnetic Generator...found in here: http://www.energeticforum.com/142700-post67.html
                  • Note: the Oleg GRITSKEVITCH Hydro-Magnetic Generator , carries similitude to the famous symbol
                    Ouroboros - Wikipedia, the free encyclopedia
                    The Ouroboros (or Uroborus)[1] is an ancient symbol depicting a serpent or dragon eating its own tail. It comes from the Greek words oura (Greek οὐρά) meaning "tail" and boros (Greek βόρος) meaning "eating", thus "he who eats the tail".[2]
                    this a really nice vid on it: as a bonus the music is quite nice
                    ‪What's behind Ouroboros?‬‏ - YouTube
                    more can be found on youtube
                    also watch this video , doesn't it remind you the musical scale
                    ‪3D Water Motion Simulator‬‏ - YouTube
                    • Astronomers Find Largest, Most Distant Reservoir of Water
                      MonsieurM,
                      Astronomers Find Largest, Most Distant Reservoir of Water - International Business Times
                      By Elvira Veksler | July 23, 2011 11:09 AM EDT
                      Astronomers found a reservoir of water measuring 140 trillion times the earth's ocean water in space. The reservoir of water is the most distant ever discovered in the universe, said two teams of researchers.
                      The water surrounds a giant feeding black hole called a "quasar" and is located more than 12 billion light-years away. The giant black hole powers the quasar which gradually counsumes a surrounding disk of gas and dust. It also emits enormous amounts of energy.
                      Astronomers studied a quasar named APM 08279+5255, where the black hole is 20 billion times greater than the sun and discovered water vapor around the black hole extending hundreds of light-years in size.
                      NASA scientist Matt Bradford said, "The environment around this quasar is very unique in that it's producing this huge mass of water. It's another demonstration that water is pervasive throughout the universe, even at the very earliest times."
                      The water was discovered by Dariusz Lis, senior research associate in physics at Caltech using the Plateau de Bure Interferometer in the French Alps.
                      "[The finding] is another demonstration that water is pervasive throughout the universe, even at the very earliest times," said Matt Bradford, a scientist at NASA's Jet Propulsion Laboratory in Pasadena.
                      IndianaBoys
                        MonsieurM,
                        IndianaBoys
                        One more great piece contributed by IndianaBoys
                        Thank you for advancing the subject
                          MonsieurM,
                          IndianaBoys
                          Makes it the Biggest known hydro magnetic coil
                          • MonsieurM,
                            NASA - Quasar Drenched in Water Vapor
                            This artist's concept illustrates a quasar, or feeding black hole, similar to APM 08279+5255, where astronomers discovered huge amounts of water vapor. Gas and dust likely form a torus around the central black hole, with clouds of charged gas above and below. X-rays emerge from the very central region, while thermal infrared radiation is emitted by dust throughout most of the torus. While this figure shows the quasar's torus approximately edge-on, the torus around APM 08279+5255 is likely positioned face-on from our point of view.
                            IndianaBoys
                              MonsieurM,
                              IndianaBoys
                              Even if it is just an illustration, it is beautiful
                              There is very likely a presence of Quartz in that system:
                              Silicon is the eighth most abundant element in the Universe; it is made in stars with a mass of eight or more Earth suns. Near the end of their lives these stars enter the carbon burning phase, adding helium nuclei to carbon to produce oxygen, neon, magnesium and silicon.
                              Silicon
                              and also if there is water there is oxygen
                              Quartz: SiO2
                              • Quasar:
                                Some quasars display changes in luminosity which are rapid in the optical range and even more rapid in the X-rays. Because these changes occur very rapidly they define an upper limit on the volume of a quasar; quasars are not much larger than the Solar System.[4] This implies an astonishingly high energy density.[5]
                                Quasar - Wikipedia, the free encyclopedia
                                If quartz is proven to exist within the toroid system (which i think there is , Si being the 8th most abundant element in the universe and the size of the Quasar)
                                we end up again with:
                                Water + Quartz + High Frequency
