mosfet joule thief
  • mosfet joule thief
    has anyone built a joule thief using mosfets instead of bi poler transistors . seems like mosfets are the golden boy of bemf circuits. i would love to build one if anyone has a circuit diagram ?
    cheers ztec2002
    Yes
    cheers ztec2002
    The MOSFET JT is even simpler than a conventional JT - it does not need the resistor, so you need just a FET, a LED and a coil. Other than that, the circuit is identical. The turns on the feedback winding can be increased to give a more optimum output. You can read more about my experiments with MOSFET JTs here and at the links at the end of the blog.
      Just keep in mind that unlike a bipolar transistor that can switch on with 0.7V, a low side mosfet switch needs at least 10V on the gate with reference to the source to switch properly.
        Here's a thought Watson, after reading your blog entry.
        You say about getting a boost from a button cell to start it up....
        Could you use jonnydavro's trick to start the circuit. that of firing a (gas stove) piezo lighter next to the coil ?
          mosfet
          If you scope the battery, do you get a spike back to the battery on each
          cycle using the mosfet?
