Hi Guys, I'll link a few building picture's here for those who may be putting together some setups, I just joined some drainge tube and discovered a trick so I'll put any construction picture's here and edit more in later maybe.
I use quick and practical methods that do not require special tools wherever possible.
First the simplest way I've found to get a straight square line around a pipe or cylinder is to use a square piece of paper or similar, wrap it around the pipe and line up the edges while it is all tightly wrapped if the paper is square or rectangle the end makes a perfecly square "level" line around the pipe, just draw around it, this is helpfull for cutting the pipe and for marking start and end points and whatnot.
Like this.
https://skydrive.live.com/?cid=32a91...1247&sc=photos
Here's the coil winding video links.
Part 1
YouTube - ‪AlternateFarmhand1's Channel‬‏
Part 2
For the toroid terminal so far I just use slotted drainage pipe, I found if I cut the end down to the first slot on both ends I can fit them one inside the other by squasing one in and cliping the lip of one into the groove of the other.
https://skydrive.live.com/?cid=32a91...1293&sc=photos
Makes a good join.
https://skydrive.live.com/?cid=32a91...1295&sc=photos
I just taped the joins for now
https://skydrive.live.com/?cid=32a91...1296&sc=photos
These ended up rough with not a smooth surface I need better materials. But adding the second torus to the terminal decreases the resonant frequency about 50 Khz to 442 Khz it was about 492 khz so maybe I can work out the capacity from that roughly using the coil design app.
Increased capacity terminal.
https://skydrive.live.com/?cid=32a91...1297&sc=photos
Like this.
![Embarassed Smiley](http://www.energeticforum.com/core/images/smilies/embarrassed.gif)
Part 1
Part 2
Makes a good join.
![V Peace sign Smiley](http://www.energeticforum.com/core/images/smilies/v-peace.gif)
