For instance I counted the turns in my coils and calculated the wire length of
the secondaries, it turns out to be approximately 273 meters and it's
inductance is roughly 8.6 mH from memory and with the three different terminal
arrangements (capacities) I get three different resonant frequencies with the
smallest terminal capacitance I get about 485 Khz add another ring to the
terminal and it's 470 Khz another one which causes a big increase and its 430 Khz
to keep the primary resonant I adjust its charging inductance and capacitance.
To keep the receiver resonant it gets the same terminal and the same primary tuning.
The 275 meters is a lot more wire than the regular calculator would say for
that frequency range. Working it out on the highest frequency I get with the
smallest capacitance it is say 480 Khz this calculator says the 1/4 wavelength is 156 meters but I need at least
273 with 5.6 pf or so added by the terminal. If I used only 156 meters the
frequency would be higher and could be worked out roughly by this calculator
using the method i described above.
So for a given frequency say 480 Khz I need to use more
than the wire length indicated by the regular calculator and it is dependent on
the way the coil is wound as well as the added capacitance of the terminal
and/or surroundings.
Going back to the 20400 Hz frequency I said above 20400, is a multiple of 60
and 12, and much more of course, 6800 is 1/3 of that and 4080 is 1/5, so
there are a lot of options. We shouldn't limit ourselves except to what we
want. Those two frequencies 6800 and 4080 are favorite roundabout
frequencies for me they seem to work well with my other stuff which is a
coincidence I hadn't thought of till just now.
As the input frequency is lowered the Overtones or harmonics or whatever
show up and can be easily tuned to. By scope and output at the receiver.
