(Reply to mr cleans post last page.)
Yeah the many turn coils those guys use to get the big arcs chew power like candy,
the resistance of the wire would lower the "Q" quite a bit. So they will make a lot of
voltage but the wire will get hot with extended use.
The less turns and resistance the better for long use. For Arc displays with long
arcs a lot of voltage and power is needed.
A true Magnifier should be able to run 24/7 except for maintenance to the spark gaps ect.
One of those would catch fire or melt the insulation after some time unless cooled somehow
and waste a lot of power. They are like big doughy bells hit with several sledge hammers to make them ring loud.
My transformer has 1 mm wire in the secondary and the Extra coils which
gives it about 4 Ohms resistance if that. The primary is two 6 mm tubes in
parallel basically no resistance in the primary coil.
The power wasted as heat I think could be calculated by the resistance, the oscillating current and the frequency.
Can I ask, what is your input power ?
Can you use an energy meter before the variac to see the power factor and the input power ?
How much voltage are you using on the primary ?
Is your spark gap a multi tube design in the canister ? Sounds nice the gap.
Stay safe.
Stay safe.
