Tesla's Magnifying Transmitter "Replications"
    P.S. the wave drawings will take a while to make understandable.
    P.S. #2 I have a 22 inch computer monitor that doesn't work. Will it have a
    HV transformer of some description in it ?
    P.S. #3 If the primary and secondary resonating frequencies of the receiver
    don't match the output will probably look something like this.
    I'll have to go to bed now so I'll take a closer look at all this tomorrow, but I've updated the post above since.
    Based on my provisional calculation to get the fundamental wavelength of a wire, your new design coil
    160 metres x 1.33 = 212.8kHz
    Your circuit you mentioned
    170 metres x 1.33 = 225.1kHz = approx 1/2 resonant
    Doesn't seem far off [edit #3] Actually it's not kHz at all is it. That's the fundamental wave length
    As for the wave drawing, halve the values and wobble your ruler The ruler should form 1/2 of a wave over 2/3 of the ruler's length, so in order to complete a full cycle it would need to be 133cm as in the diagram, or 1.33 times the length.
    If the monitor is a CRT then yes, if it's an LCD then no
    Thanks for the details, I shall pay more attention after some sleep
    [edit] Since 1/2 a wave fits into 2/3 the length of the ruler, divide ruler length by 3 to get 1/3 value. Then add 1/3 value to total length of ruler = one complete wave.
    [edited again because I wrote the explanation of the diagram completely wrong. Must get some sleep ]
    • OK Some of this is what I see on my scope this is the same with my signal
      generator pulsing the primary or my circuit. Pleas forgive the waves I drew
      them freehand.
      Uploaded with ImageShack.us
      The whole top wave is the transmitter.
      The first half is pulsed at full frequency both primary and secondary have the
      same period and each wave is exactly the same.
      The second half of the top line shows what happens when pulsed at half
      frequency,, when the input pulse is missed the wave form starts to get
      smaller, but the period still remains the same for both, the frequency of both
      does not change. The wave starts to look like a funny kind of M with one
      short arch then is put back normal to repeat but the reduction is small for the
      input saving.
      The first half of the bottom section is what I believe to happen at the
      receiver when both coils have the same period, the receiver I think should be
      slightly out of phase or even 180 degrees out maybe that changes with load,
      I have no way to tell for sure. Because my receiver is wound the same as my
      transmitter the polarity would be opposite, but that should not make any
      difference the output is AC .
      The second half of the bottom section is what I see when the coils have a
      different period, the ring-down wave even has the lopsided look to it.
      The amount the coils affect each other depends on stuff I have yet to fully
      determine. I think coupling factor is one and the primary circuit configuration
      is another as far as I can tell.
      • Now I read some more from that document I linked above.
        I think this says it all.
        From the document.
        It's not the physical length of the wire but rather the velocity inhibited electrical length of the helical coil which must be quarter-wave resonant (i.e., have forward and reflected wave-interference producing a standing quarter-wave resonance)
        I think this means I done good with my coils because I have more wire than I
        should by theoretical calculations should need for the frequency I have. I
        have 240 meters of wire in my secondaries, but the terminal capacitance is
        about 25 to 30 pF which would lower the frequency a fair bit but not that
        much I don't think.
        Therefore the forward and reflected wave interference
        must be faster than light to be able to go through more wire in the same time.
        I think. Anyone have any thoughts on that ? Who knows and
        it really doesn't matter as long as they work. The only difference it will make
        is the frequency I get from my coils will be higher than it should be in
        conventional terms. EDIT; Or is it lower, it's a bit confusing. I need a sleep too.
        Now I know why the online calculators are not quite right.
        Class Notes: Tesla Coils and the Failure of Lumped-Element Circuit Theory
        It makes no difference whether the coil is a cylindrical helix, a conical frustum, or a flat spiral. Tesla clearly understood the velocity-inhibited nature of spiral and helical resonators and taught that, "The length of the wire coil in each transformer should be approximately one-quarter of the wave length of the electric disturbance in the circuit, this estimate being based on the velocity of propagation of the disturbance through the coil itself." [US Patent 645,576; Applied for Sept. 2, 1897] It's not the physical length of the wire but rather the velocity inhibited electrical length of the helical coil which must be quarter-wave resonant (i.e., have forward and reflected wave-interference producing a standing quarter-wave resonance). This was recognized by Tesla, and this is the meaning of the phrase "...this estimate being based on the velocity of propagation of the disturbance through the coil itself." (The consideration could not exist for a lumped element, obviously.) Berkeley physicist David Sloan, ("An RF High Voltage Generator," Phys. Rev., Vol. 47, 1935, pp. 62-70), did not know how to mathematically handle the inhibited velocity of propagation on the helical resonator, and a suitable engineering analysis was provided only a decade ago.
        Is there any question that Tesla is speaking of a distributed transmission-line resonator? Well, if so, listen to his correspondence to the US Patent Examiner on November 15, 1897. He is explaining what happens if the resonator excitation-frequency is raised (i.e., the wavelength shortened). As every electrical engineer knows, a grounded quarter-wave transmission-line resonator possesses a Vmin at the base and a Vmax at the top. If the frequency is lowered, the structure is too short for quarter-wave resonance, and if the frequency is raised, then Vmax positions form down in the resonator. The same is true for both helical coils and spiral coils. Concerning the latter, Tesla wrote,
        "If the transmitting and receiving coil were made longer than the quarter of the wave-length of the electrical disturbance in the wire, then the points of highest potential would not fall at the inner ends of the coils ... as required, but nodal points would form, as the case may be, somewhere in the middle of the coils ..." [Dr. Nikola Tesla - Selected Patent Wrappers, compiled by J.T. Ratzlaff, Tesla Book Company, 1980, Vol. 1, p. 150.]
        This phenomenon is decisive. It occurs only on distributed resonators: it is impossible with any lumped circuit element! (The current has the same value at every point along a lumped-element.) To understand what is happening, consider a cylindrical helical coil of height H. The base is always forced to be a voltage node (it's grounded). The top is always a relative voltage loop at the odd quarter-wave resonances and a voltage node at the even (half-wave) resonances. These boundary conditions constrain the mode patterns on the structure (called spatial harmonics). We assert that velocity inhibited partially coherent forward and reflected RF traveling waves form interference patterns on the coil.
        Now I see what the odd resonant overtones means. The fundamental quarter
        wave frequency is odd but there are no Voltage nodes on the coil only a
        V-max loop at the top. At the odd resonant overtones there is V-min "Nodes"
        on the coil.
        At the fundamental (quarter-wave) resonant frequency there is a Vmin at the base and the Vmax appears at H (the top)
        At all the odd resonant overtones, there is always a Vmax at the top and a Vmin at the base
        • Hi all, I did a quick test with my small HV coils using a neon, I held it with the
          glass touching the coil and moved it up the coil to the top, as I get to the top
          the coil arcs around the glass of the neon to the leg of the neon I am holding
          showing a fairly steady increase in voltage up the coil to maximum at the top.
          I had the input just so the sparks won't jump to the metal leg of the neon
          until near the top. The test wont really work unless I either hold the leg of
          the neon or presumably connect the leg of the neon to ground.
          I filmed it so here is the short clip. Voltage test on coils.wmv - YouTube
          Even though the gap only seems to be running slow the voltage is still at the top
          and significant as compared to the input. This was with the two primaries in
          series, though I don't think that will make much difference, I think because my
          HV source is spongy and the coupling fairly close the oscillations of the
          secondary are determining when the gap fires most of the time, when i put my
          hand near the coils it affects the frequency of the secondary and so too the
          spark gap. It's not ideal but it'll tick over just fine till I get some more wire on
          the HV supply transformer secondaries, and speed up the gap and build some
          better gaps than spark plugs..
          These coils have about 100 meters of .5 mm wire in the secondaries by
          calculation. I'll redo the calculations when I count the turns properly. For both
          sets the LV one's too just be sure of the amount of wire.
          This pic shows the sparks "if you click on the thumbnail", the neon is glowing
          yellow and orange, cool. And it looks like the sparks leave the neon and go the the coil.
          • Unless I'm mistaken or making wrong calculations it appears the wire length
            should be estimated based on a velocity of propagation of the disturbance
            through the circuit of about 1.5 times the speed of light.
            For me this would give me a wire length of 255 meters for 440 Khz not (170 meters)
            a bit less when the toroid capacitance is taken into account.
            And so it's about 246 meters of wire is what I have. EDIT; This is for my
            Low voltage setup, Coils "A" and "B" combined.
            (The HV setup only has 107 meters of wire in each secondary Coil "A" and "B" combined.)
            This seems easy to calculate by just multiplying the 170 meters for a 1/4
            wavelength of 680 meters (440 Khz) by 1.5. So 170 x 1.5 = 255 meters
            however to get 440 Khz a bit less wire is actually needed because of the
            toroid terminal capacitance I need 246 meters or so, so the terminal
            capacitance shortens the length of wire needed by 9 meters.
            I think this all checks out as me having accomplished one goal already.
            I would seem to have broken the speed of light. Is there no comment ?
            One does not need to know they have broken the speed of light to have done
            it. It already happened before I worked it out, if it did happen.
            So do I give myself the speeding ticket for working out I did it, or for doing it.
            Not to worry back to the experiments. I've broken plenty of speed limits and
            laws before so it's no big deal to me.
            It doesn't make any sense for nothing to be faster than the speed of light.
            Not to me anyway, the speed of dark is faster
            I don't think the MIB's will be visiting the house of everyone with a resonant
            Air Cored Tesla Transmitter/Transformer. I think everyone is safe.
            P.S. going by the 1.5 times the speed of light propagation velocity my small
            HV coils should be resonant at about 1 Mhz for 107 meters of wire. Not the
            700 Khz the online calculator tells me, I think.
            Frequency Wavelength Calculator
            Still this will only determine the frequency for a given length of wire or the
            length of wire for a given frequency, all the tuning still needs to be done.
            • Thinking of my new coils.
              Using the 1.5 times the wire the online calculator says I need for 208 Khz gives
              me 540 meters of wire required for 208 Khz rather than 360 meters the
              calculator says.
              So if it works out that way the new setup will be resonant at 300 Khz or so
              with the terminal capacitance added, and using 360 meters of wire for the
              secondaries. The calculation says 312 Khz but it'll be less with the terminal.
              To actually make it resonant at 208 Khz. I would need a few meters less than
              1.5 x 360 meters = 540 meters of wire in the secondaries.
              I'll go with the 300 Khz, darn it no wonder it is difficult to get the frequency down.
              I knew there was something funny going on because things didn't add up, but
              I just wound bigger resonators to get the frequency down to what I could
              pulse with my circuit.
              P.S. It should kinda work out in a strange numbers way, I'll have a 300mm
              diameter Coil "A" a 300mm tall Coil "B" and I will pulse the primary at 300 Khz
              about, that's 3 - 300's. I'm not overly numberstitious though.
              EDIT:
              This calculator works out the wire length for the frequency quite well.
              It tells me for 246 meters of wire I get 438 Khz with 6.5 pF toroid capacitance
              which is almost spot on. Obviously it is factored into this one.
              OLTC Calculator
              This one seems wrong it tells me for 246 meters of wire I get 304 Khz
              which is much lower frequency with no added capacitance.
              • Hi all I would recommend anyone interested in this stuff to read this document linked below.
                Nikola Tesla On His Work With Alternating Currents -- Chapter IV
                After reading it more I can see I have made some assumptions that are not correct. So I advise people read it for themselves.
                Here is one thing i assumed when skimming through the document, I quoted above where Tesla used 44 000 volts to his primary but now I read at the bottom this quote below.
                Counsel
                Was the method you used there [in Colorado], a spark? -- an arc? -- or what was the method where you got continuous generation?
                Tesla
                The method was this: I had a 550-volt current with which I charged the condensers. These condensers I discharged through a primary in the form of an arc, sometimes I also introduced in this arc a mechanical break of several thousand per second. And I obtained a perfectly continuous train of waves as has been described in my patents. The reason why I show the condenser here [Fig. 83] is that that is synonymous with undamped waves. If I had shown the whole apparatus as arranged there, then I might still have damped waves; but whether I use an alternator or some other way of getting energy to that condenser, the condenser is usually there. For instance, if I use an alternator, I shunt its terminals with a condenser in order to magnify the current in the primary. I then tune this circuit to the alternator, and magnify the current in the primary in the ratio of the inductance to the resistance. Therefore, this condenser here stands for either method, and simply means that in this system, as is obvious from the description in the patent, the waves are undamped because high rises of potential would not be obtained otherwise. Whenever I wanted to obtain a high potential, I had to observe these rules in order to force the potential up to that value.
                Counsel
                He would have to get very much more inductance in the system than he has today, relatively?
                Tesla
                It is just like this: In an enterprise of this kind, you have to start with certain fundamental propositions. If you are to build a commercial plant, the question comes up how much money is it to cost. Now, you go to specify before your capitalists the various parts of the plant, and you will find that your machinery and the aerial structure will cost so much. If your capitalists are willing to go deep into their pockets, you can put up a tremendous antenna because, as you know, as I pointed out in 1893, that the effects will be proportionate to the capital invested in that part; but you will find great limits there.
                I designed a plant [Wardenclyffe, referring to Fig. 83] years ago with a large capacity and put it before certain architects. They figured that the antenna would cost $450,000 and I had to modify my plans. As you see, you are limited by cost as to the size of the antenna; that is, you are limited as to the capacity and, furthermore, you have selected the frequency. In order to lower the frequency so that there would be no wasteful radiation of energy, you have to employ a large inductance. You have to employ a capacity as large as permissible, and you must use a large inductance in order that you may reach the low frequency which is economical.
                Counsel
                What low frequency is it that is economical?
                Tesla
                In a patent which appeared in April 1905, the application of which was filed on May 15, 1900, I have enunciated the law of propagation, which I have explained, and have stated that the frequencies should not be more than 30,000 or 35,000 cycles at most, in order to operate economically.
                He dispels a lot of myths in the document linked above.
                • In this patent.NIKOLA TESLA - Google Patents He talks of a speed of
                  471,240 Kilometers per second which is unless I'm mistaken about 1.57 times
                  the speed of light which is about 299,792 kilometers per second according to wiki.
                  And also mentions the Earths diameter should be an odd multiple of the 1/4
                  wavelength. And the frequencies again, along with talking of the nodes.
                  I should be able to post a scope shot showing the nodes, they show up on
                  the scope, but I'll have to put my coils back together, I've had them apart
                  counting turns. There is actually 273 meters of wire in my LV secondaries.
                    them freehand.
                    input saving.
                    Well I'm going to have to take a closer look again at the new stuff you posted, I know the "ruler effect" won't apply physically to the coil, but I will be thinking about it more to see how it all might fit together, just in case The "extra wave" when pulsed at 1/2 frequency could be a sort of "ringing" effect. As for the ruler, that at least tells me something about how a wave "wants" to express itself naturally over a free object. The end needs to be tied down in order to force the wave to fit or reflect. But I at least find it interesting that it's not how I thought it was, that a 1m object would have a 1m wave length.
                    My new "extra coils" will be (about) the same height as they are wide. At least the frame will be, the wire "should" end up somewhere around the right place. I hope
                    "the velocity inhibited electrical length of the helical coil"... What does this mean? "velocity inhibited electrical length"?
                    I don't know but I might play around with the geometry as well, basically designing the frame like a drum or acoustic instrument, so the shape will resonate at a certain frequency. That's why my "extra coils" will be as wide as they are high. They will also have 2 closely wound turns then a bigger gap, same amount of wire as the spiral secondary. I can then also replace the 1.5mm primary with 3mm to match the primary weight, but I don't have any wire for that so it won't be immediately.
                    • Hi dR, I think you are onto something with the ruler. It sure did cause me to
                      think a bit more about it. And do some more study, so it helped me a lot already.
                      I think that means it depends on how the wire is wound into a coil as to the
                      inductance it will have and with distributed capacitance and so forth.
                      My thinking is ( and I need to test this ) with the secondary, that when the
                      coil turns are spaced the self capacitance of the coil is increased and the
                      frequency lowered but to use the same amount of wire the coil must be much
                      bigger because of the spaces and then the terminal will lower the frequency
                      again. I need to do some experiments with some spaced turns.
                      I'll make three test coils, One with no turn spaces. (control) One with the
                      same wire but spaced turns. And One the same height and diameter as the
                      control but with spaced turns, shorter wire. That should tell me something to
                      go by. And imprint the result on my noggin mush. Experiments have a
                      way of doing that.
                      Like Tesla Said, If we base our designs/machines from experimental data they
                      will work, that's engineering.
                      • Another thing I considered dR is that the connecting wire if an odd multiple of
                        the 1/4 wavelength could work better as Tesla says the Earth should be a 1/4
                        wavelength and the receiver should be far enough from the transmitter so that
                        the transmitter does not directly impose it's vibrations on the receiver
                        capacitively or otherwise.
                        So I would need a wire at least 170 meters long to be 1 x 1/4 wavelength.
                        Your's would be a lot shorter I think but you'll need to determine the resonant frequency of your coil to be able to do that.
                        • Originally posted by dambit View Post
                          Hi Mate,
                          No I haven't read that book. I'll have to get a copy.
                          I don't have anymore info about the setup apart from the witness descriptions contained in Margaret Cheney's book "Tesla - Man out of time". The guests to his laboratory describe the light as "strange and beautiful", so I suppose that would fit the description of aurora type lighting. He also had at his disposal in that lab a 2 million volt + power supply. I'm sure that helped some what.
                          It's the possibility of generating these high frequencies that interests me. Much of Keeley's work required combinations of ultra high frequencies. I imagine the coil Tesla used for this setup was reasonably large due to the windings required.
                          Steve
                          P.S In case you were interested, Keeley charted visible light beginning not in the low THz like I said, but at approximately 140.7 THz (140,737,488,355,328 cycles per second) and ending at approximately 1.1 PHz (1,125,899,906,842,624 cycles per second). Just to put those into real numbers.
                          Hi dambit, I found a reference to the effect you were interested in. in this
                          book Here Page 218 He is talking of a similarity to the aurora's.
                          When the necessary
                          adjustments in the length and distance of the wires above
                          the oil and in the arc of discharge are made, a luminous sheet is
                          produced between the wires which is perfectly smooth and textureless,
                          like the ordinary discharge through a moderately exhausted
                          tube.
                          I have purposely dwelt upon this apparently insignificant experiment.
                          In trials of this kind the experimenter arrives at the
                          startling conclusion that, to pass ordinary luminous discharges
                          through gases, no particular degree of exhaustion is needed, but
                          that the gas may be at ordinary or even greater pressure. To
                          accomplish this, a very high frequency is essential ; a high potential
                          is likewise required, but this is merely an incidental necessity.
                          These experiments teach us that, in endeavoring to discover novel
                          methods of producing light by the agitation of atoms,
                          or molecules, of a gas, we need not limit our research to the
                          vacuum tube, but may look forward quite seriously to the possibility
                          of obtaining the light effects without the use of any vessel
                          whatever, with air at ordinary pressure.
                          Such discharges of very high frequency, which render luminous
                          the air at ordinary pressures, we have probably occasion often to
                          witness in Nature
                          . I have no doubt that if, as many believe, the
                          aurora borealis is produced by sudden cosmic disturbances, such
                          as eruptions at the sun's surface, which set the electrostatic charge
                          of the earth in an extremely rapid vibration, the red glow observed
                          is not confined to the upper rarefied strata of the air, but
                          the discharge traverses, by reason of its very high frequency,
                          also the dense atmosphere in the form of a glow, such as we ordinarily
                          produce in a slightly exhausted tube. If the frequency
                          were very low, or even more so, if the charge were not at all
                          vibrating, the dense air would break down as in a lightning discharge.
                          Indications of such breaking down of the lower dense
                          strata of the air have been repeatedly observed at the occurence
                          of this marvelous phenomenon ; but if it does occur, it can only
                          be attributed to the fundamental disturbances, which are few in
                          number, for the vibration produced by them would be far too
                          rapid to allow a disruptive break
                          . It is the original and irregular
                          impulses which affect the instruments ; the superimposed vibrations
                          probably pass unnoticed.
                            on the coil.
                            Yes that makes sense "Overtones" being frequencies above the fundamental frequency, and "undertones" being below. So the higher ones would be shorter wavelength so there will be these V-min nodes.
                            Well I'm not really sure what's going on here Until I get my head around it all I think I'll just have to build different things and experiment and see what happens. If everything is measured and weighed and all that, and by seeing the actual effect, then I think it will all make a lot more sense. I suppose making things small scale is ok just to see what happens, but bigger is apparently more powerful. But the small scale version first might be good for deciding what to make bigger.
                            So the primary and cap is tuned to the power supply? In that case if you were using an NST off 50Hz mains, the primary circuit should be tuned for 50Hz.
                            But is he talking here about the primary or the secondary? Sounds like the secondary, because he is talking about the size and construction (capacity) of the antenna? If so, then it sounds like the primary circuit should be tuned to 50Hz (for example), and a secondary ("circuit") of a large inductance, tuned to 30KHz? But 1/4 of what wavelength? 120KHz discharge?
                            Back to this
                            So if you increase the inductance of your primary (like spaced turns), the current would be magnified greater than the same amount of wire that isn't spaced?
                              Ah, well I posted the above before reading this. But I think that is something good
                              • Originally posted by dR-Green View Post
                                Back to this
                                That's the secondary yes, Tesla had chosen his frequency and I presume the
                                Large Metal Toroid terminal he had planned originally did not fit in the budget.
                                So he had to design a different terminal out of necessity not choice, this
                                meant if the new cheaper terminal had a lower capacitance he would then
                                need to increase the inductance to keep the frequency at the pre-chosen
                                one.
                                He had alternators that could work at 20 Khz, not that I'm saying that is the
                                frequency he used. He did things a lot of different ways he had no real set
                                rule as to how everything should be always, it depends on what you want to
                                do.
                                It complex. The coil can be wound in an infinite number of ways. It's the L/C
                                ratio of the coil and the terminal which will actually determine the frequency.
                                Which I think is what this means below. Without doing complex calculations
                                some feel is required or experience, exactly like you say, we can get our feel
                                different ways. Or a java calculator can be used but they are only so useful.
                                If the If the chosen frequency was say 20 400 Hz the full wavelength is
                                14706 meters the 1/4 WL is 3676 meters. So to work at 20 Khz the secondary
                                should be approximately 3676 meters.
                                By using that length of wire in the online calculator I use,
                                I can see very close to what close wound coils will end up. But it can't do the
                                "A" and "B" coils combined, so I wing it by finding the inductance of each and
                                adding them together, so then I just design a coil in there with about the
                                same inductance and wire length as my two coils added and it gives me the
                                resonant frequency, but, at least 1 pF must be entered in the toroid
                                capacitance box.
                                Here's an example take the above 1/4 WL wire length from the regular calculator above 3676 meters.
                                Go to this calculator OLTC Calculator
                                And enter the following list of numbers in the boxes with white text next to them top to bottom.
                                Secondary
                                880
                                0.5
                                700
                                Primary
                                20
                                10
                                750
                                200
                                2
                                Toroid capacitance
                                1
                                Click in one of the boxes in the results section and you should see 25.886 Khz.
                                Which is higher than the 20.4 Khz used to get the 1/4 WL wire length and
                                the inductance is higher, then there is also distributed capacitance and
                                resistance, it's very complex to work out but very simple by "feel".
                                Then change the toroid capacitance to 21.4 the frequency becomes 20.398 Khz.
                                Note the primary capacitance. It changes. Change the primary turns and such to alter the
                                primary capacitance required if desired anytime later is ok.
                                Now enter in the Bangs per second box
                                20398 and the voltage you desire to use in the next one, click in a red box
                                and the results are displayed. (I used 1000v)
                                This just gives an idea of how everything interacts it's a very useful tool even
                                if just to play with and see the different results. Try changing some things to
                                see the resultant changes. It tells a lot of what does what.
                                Back to the primary capacitance if the primary is made with more inductance
                                it requires less capacitance but the input and output will be less.
                                Change the primary to 40 high and 4 turns and it goes from 2 joules per bang
                                to 0.5 joules per bang. The average current in the tank goes from 186 amps
                                to 48 and the terminal voltage goes from 278 Kv to 141 Kv double the primary
                                turns and have 1/4 the input 1/3 the amperes in the tank and half the
                                terminal voltage. Going by this calculator, I won't say that part is 100 %
                                correct but close. (EDIT; I fixed a mistake with amps above)
                                (EDIT: As primary capacitance is made less the input and output is lessened)
                                And
                                (The amount of current that can be displaced/caused by the terminal is
                                relative to the Potential and the capacity of the Terminal.)
                                As I see it anyway. Just like a regular capacitor kinda.
                                I can do the same thing with the wire length in my coils the unknown is the
                                value of my various forms of Terminal I use to alter the resonant frequency of
                                the secondary, I can change it by almost 50 Khz from 480 to 430 Khz.
                                That calculator , what I see on my scope and the way the coils check out
                                with the function generator and experimenting and some calculation give me
                                my "feel".
