Harvesting Energy From the Sun Using Crystals
  • Originally posted by shawnnweed View Post
    At what voltage range does this effect begin? And how effective is this method of cooling? To be honest this is a new one on me.
    ,Shawn
    Its a new one on me too, but ties in well with what we'r trying to do.
    Im going to try a closed system this time, will probably bust the cell but Im going to give it a try.
    • Hopefully I'll get it wound today it gets hot fast in Texas
      • I put the Smith coil in the freezer yesterday, check it out, it fractured the ice everywhere, thats a good thing I think thats energy trying to go somewhere and since the ice doesnt conduct it shatters the ice.
        Its hard to see I outlined it in white but it created a long column down to the bottom of the container, something is definitely going on with this type of coil
        It condensates so fast its hard to get a pic
        • is there a way to put a light source behind it so the fractures maybe more apparent (don't put on top of a light bulb, did this and shattered the bulb ooops )
          just a side note: i was reading through this thread and i found an info quite interesting
          Something R-Frequency and E-Class this way comes!, page 1
          So what I can gather from this is that E class asteroids are flat im shape, are very rare, and have the ability to hold water and absorb materials. Sounds almost like an aircraft. They are basically Enstatite (which is similar to all that talk about (44) Nysa years ago...Now Enstatite is made of Magnesium and is one of the few silicate minerals that have been observed in crystalline form outside our Solar System, particularly around evolved stars and Planetary Nebulae such as NGC 6302. Enstatite is thought to be one of the early stages for the formation of crystalline silicates in space and many correlations have been noted between the occurrence of the mineral and the structure of the object around which it has been observed.
          Now this HAM radio is the use of designated radio frequency spectrum for purposes of private recreation, non-commercial exchange of messages, wireless experimentation, self-training, and emergency communication.
          after you read the whole thread on ATS
          you can also checkout Zilano posts on Crystal radio
          http://www.energeticforum.com/renewa...od-true-8.html
          • Here's a better pic of the column it extends from the end of the coil to the bottom of the container, thats 4 to 5 inchs , wish the container were deeper just to see how far it would extend from the coil
            This is a very small coil maybe three and a half inches just a single wrap like in the diagrams, its sure putting out a strong field.
              there seem to be a pattern to the fractures....
                No not really but it is definitely ordering the ice in that column
                  Speaking of asteroids we will get hit in the last days its written.
                    with a fractal construct which i believe the Bible is, you have to look at it more positive and less literal (or first degree ) (my opinion )
                    report on the double coil,
                    i took it out of the ice and connected it to home plug, enough to say that i shorted the whole thing...interesting enough i took some picture to show what happened...fractures and all ...i'll post them later
                    i'll try a single mobius smith coil....much simpler...first i have to buy some batteries
                    • the black part is were it shorted
                      ps: dave try using photobucket to host your pics, it's much easier
                      Pictures by MonsieurM - Photobucket
                        Ezekiel's wheel within a wheel
                        this is probably one of my favorite albums :
                        Louis Armstrong and the Good Book
                        Ezekiel Saw de Wheel_ Louis Armstrong.wmv - YouTube
                        Louis Armstrong - Nobody Knows the Trouble I've Seen (1962) - YouTube (this one truly cheers me up )
                        • Got an account, will give this a try
                          cool thanx
                          • here is an interesting info as i was reading Randall Cole Roffe: Harmonic Resonance
                            The 6th Octave B Natural Superconductor Motor Resonance Range
                            (Suboctave 20)
                            490 Hz --- 20th suboctave sound of H-alpha wavelength, approx .6912 m
                            B natural (246.9, 493.8 Hz)
                            499.2 Hz --- sixth octave of Schumann fundamental
                            500 Hz --- one type of measured human energy field range
                            500-900 Hz --- estimated rpm of Podkletnov superconductor & Moray motors
                            • Impulse Gravity Generator Based on Charged YBa2Cu3O7−y
                              Superconductor with Composite Crystal Structure
                              Evgeny Podkletnov / Giovanni Modanese
                              The detection of apparent anomalous forces in the vicinity of high-
                              Tc superconductors under non equilibrium conditions has stimulated an experimental research in which the operating parameters of the experiment have been pushed to values higher than those employed in previous attempts. The results confirm the existence of an unexpected physical interaction. An apparatus has been constructed and tested in which the superconductor is subjected to peak currents in excess of 10^4 A
                              , surface potentials in excess of 1 MV , trapped magnetic field up to 1T , and temperature down to 40K
                              . In order to produce the required currents a high voltage discharge technique has been employed. Discharges originating from a superconducting ceramic electrode are accompanied by the emission of radiation which propagates in a focused beam without noticeable attenuation through different materials and exerts a short repulsive force on small movable objects along the propagation axis. Within the measurement error (5 to 7 %) the impulse is proportional to the mass of the objects and independent on their composition. It therefore resembles a gravitational impulse.The observed phenomenon appears to be absolutely new and unprecedented in the literature. It cannot be understood in the framework of general relativity. A theory is proposed which combines a quantum gravity approach with anomalous vacuum fluctuations
                              The walls of the chamber were made of non-conducting plastic composite material, with a big quartz glass window along one of the walls which allowed to observe the shape, the trajectory and the colour of the discharge.
                              The old fashioned Van de Graaf generator used in the previous stage of this workwas replaced by a high voltage pulse generator as shown in Fig. 4. This pulse generator is executed according to the scheme of Arkadjev-Marx and consists of twenty capacitors(25nF each) connected in parallel and charged to a voltage up to 50-100kV using a highvoltage transformer and a diode bridge. The capacitors are separated by resistive elementsof about 100
                              kΩ.
                              In signal processing, the term pulse has the following meanings:
                              A rapid, transient change in the amplitude of a signal from a baseline value to a higher or lower value, followed by a rapid return to the baseline value.
                              just like a ringing bell : http://www.energeticforum.com/151139-post274.html
                              And when you keep throwing small stones onto bell at interwals that match it's own resonance- them mamma mia....
                              Podkletnov 2001 Paper with Giovanni Modanese
                              http://www.americanantigravity.com/d...-Interview.pdf
                              see also post: http://www.energeticforum.com/151484-post313.html
                              Podkletnov: Yes, it produced a strange kind of non-focused radiation that was very harmful to biological tissue -- fortunately for us; the impulses were very short in time. It was very harmful to living organisms; we also observed a melting or molecular-juxtaposition effect of biological tissues with plastic materials, and even with metals to some extent.
                              see experiment : Three Soviet scientists, S. STSCHURIN, V. P. and L. KAZNACHEJEU Michailova, confirmed after more
                              than 5 000 experiments that living cells transmit information through photons:
                              http://www.energeticforum.com/136258-post21.html
                                the design looks like earth magnetic field
                                Dave have you tested the special coil you made earlier or is it the one you showed us in the ice
