Originally posted by MonsieurM
Harvesting Energy From the Sun Using Crystals
so the crystal formation of the ice is perpendicular to gravity....
excellent test Dave, Thank you
-----if you want to expand a little on water, the following doc is an important source of info:
Water, The Great Mystery - YouTube
it is essential that you watch the doc, if you want us to advance....
because you will see the potential of what i am talking about
note: 85% of the brain is made of ....Water
Quite different conditions exist in my system in which the electromagnetic waves or radiations are designedly minimized. the connection of one of, the terminals of the transmitting circuit to the ground having, itself, the effect of reducing the energy of these radiations to about one-half, Under observance of 'proper rules and artifices the distance is of little or no consequence, and by skillful application of the principle of "individualization," repeatedly referred to the messages may be rendered both non-interfering and non-interferable. This invention, which I have described in technical publications, attempts to imitate, in a very crude way, the nervous system in the human body.' Nicolas Tesla"If you only knew the Magnificence of the 3, 6 & 9; you would have a key to the universe."-Nikola TeslaLast edited by MonsieurM; 08-20-2011, 05:55 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by Dave45 View PostAmazing vid, maybe we need to program the water beforehand.
Maybe write free energy secret revealed on it.
Print out all the things you want and tape it to the bottle???
Originally posted by bhaas View PostHere's another good video: Water Bottle Video
Iv thought of this but havent tried it yetHalf of the Answer is knowing the right Question
I just wanted to add a little piece of info as a complement to the documentary :
this was posted a while back by IndianaBoys
Reflection of Mind Projected Thought into Water Photographed
LAB NOTES
now you know, what can be done with water“Signs and symbols rule the world, not words nor laws.” -Confucius.
for instance the geometric form of a ferromagnetic ice than hit it with UV light (see http://www.energeticforum.com/renewa...gnetism-4.html starting with post#98
btw: if the universe is all wave, then what you write is too...think about it(also known as principle of mentalism )
Last edited by MonsieurM; 08-22-2011, 12:19 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
from a link i already mentioned: http://www.energeticforum.com/149708-post95.html ; read the post , watch the doc
Originally posted by petar113507 View PostYou have my attention with part 4, but I found parts 2 and 3 much more insightful. It seemed to be visually displaying some of the fractal functioning of some atomic structure. If you know walter russell's books, this seems to be showing atomic functions (along very similar lines). Very good share. Please let me know if you have any more info about this video series.
After seeing that guy play with the shape resonance of those structures -- It makes a whole lot more sense why "orgonite" in water, also affects the freezing structure of the ice -- much like your most recent coil, MM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Which reminds me Bashar's coil or Walter Russel coils
and
Third Prototype: Insulated Copper Tube Antenna « Bashar Space-Time Antenna (construction detail included )
in ice
If you look closely at these coils ....Smith (Caduceus ) Coil variationLast edited by MonsieurM; 08-21-2011, 02:10 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by Dave45 View PostThis coil, which is the classic Smith coil
You can see how the gravity is effecting the field, Im sure it doesnt have the same effect on the field alone but Id bet it is having an effect.
freetoshare“Signs and symbols rule the world, not words nor laws.” -Confucius.
Now i think you guys are familiar with the power of water,
read the following: http://www.energeticforum.com/136258-post21.html
Three Soviet scientists, S. STSCHURIN, V. P. and L. KAZNACHEJEU Michailova, confirmed after more
than 5 000 experiments that living cells transmit information through photons (in 1981).
We can describe the experiments simply as follows:
- Cells are bathed in a nutrient solution in two spherical flasks made of quartz. The two flasks are touching
each other. If a cell culture is affected by a virus, or poisoned, the cells in the adjacent flask become
impaired every time and always have the same symptoms, whereas they should be protected from the toxic
influence of other cells by the quartz sides.
- If you use glass flasks, the second cell colony is protected.
- The transmission between the two colonies is made by ultraviolet radiation.
*** These same three Soviet scientists measured the cell radiation using a photomultiplier. "Normally living
cells emit a constant stream of light rays. When a virus enters cells, radiation changes: it first increases -
then silence – then new increase, then gradual attenuation of radiation in multiple wavesuntil the cell
dies. This recalls the cries of pain of an animal.
*** In 1974, Simon STSCHURIN, said: "The cells affected by different diseases have different radiation
characteristics. We are convinced that photons are able to inform us long before the onset of pernicious
degeneration to disclose the presence of a virus ".
Today, scientists worldwide are exploring this phenomenon:
- In Australia, the correlation between cancer and ultra-hight- throuhput radiation is under study.
- In Brazil, fundamental studies are being conducted to understand light transport in cells.
- In China, the action of light on cells is currently studied.
- In Japan, research is trying to make an early diagnosis of cancer from cell radiation
Light biology - quetanglais
and we know now that certain UV can transfer information to water....
see also Shawn's post: http://www.energeticforum.com/152432-post75.html
Originally posted by MonsieurM View PostThree Soviet scientists, S. STSCHURIN, V. P. and L. KAZNACHEJEU Michailova, confirmed after more
I read somewhere sometime ago that scientists impregnated a frog with light thru petri dishes. Sperm in the bottom one and a frog in the top one; or frog eggs. I've been trying to find that article again. If anyone knows what I'm talking about I'd appreciate a link.
This of course gets me thinking. Why couldn't we put gasoline in a dish and water in another dish, shine light up thru the two and convert the water to gasoline. Once converted, couldn't we just use a few drops of the converted water to make large quantities of gas by mixing it into barrels of water???
I may be dreaming here.
Originally posted by bhaas View PostI read somewhere sometime ago that scientists impregnated a frog with light thru petri dishes. Sperm in the bottom one and a frog in the top one; or frog eggs. I've been trying to find that article again. If anyone knows what I'm talking about I'd appreciate a link.
Francis E. WILKINSON:High-Frequency Transformations
Dancing electrons, whipped to a jitterbug frenzy, are performing miracles of modern alchemy in a backyard laboratory at Glendale CA. Racing back and forth through coils of wire at frequencies up to 100 megahertz, they transform water, natural gas, cottonseed waste, and potato peelings into new and useful substances for industry.
Francis E. WILKINSON -- High Frequency TransformationsLast edited by MonsieurM; 08-21-2011, 05:10 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
