Harvesting Energy From the Sun Using Crystals
    got a very bad connection today....
    they are overloaded just trying to stay up with you
    I meant that in a good way
    • That is what my friend keeps on telling me, stop strip searching the internet
      • One thing i would like to add, after you have read all the info on water, you are now quite knowledgeable on the subject ...now to show you the multi dimensional application of :
        "As above so Below, from within so without" = Water
        • Originally posted by IndianaBoys View Post
          MonsieurM,
          The thought occurred to me about homeopathic and fractals being connected in some fashion.
          IndianaBoys
          IndianaBoys,
          Throughout my research, if there is one thing i can say for sure...Water and Fractal are intimately linked (Principle of Gender )
          ps: the Universe is Fractal, see http://www.energeticforum.com/152835-post117.html
            MonsieurM,
            Of all the years observing SOHO (Solar And Heliospheric Observatory), never have seen an event such as what is happening today with the sun.
            Here is that database for researching the suns activity:
            Search and Download SOHO Near Realtime Data
            Select:
            Image Type = LASCOC3
            Resolution = 512
            Display = Movie
            Start and End Dates:
            Start = 2011-07-23
            End = 2011-07-23
            Then click search.
            You can also change the dates to see other time frames such as this Mercury in Retrograde event:
            Type in the date range of - 2001-01-01 to
            2002-01-31
            This will be 1,285 pictures for January 2001.
            IndianaBoys
            You are changing, and it is out of your control, welcome to a new era....enjoy the ride
            Piezoelectricity ( /piˌeɪzoʊˌilɛkˈtrɪsɪti/) is the charge which accumulates in certain solid materials (notably crystals, certain ceramics, and biological matter such as bone, DNA and various proteins
            from: http://www.energeticforum.com/renewa...llector-9.html
            DNA could act as an antenna in electromagnetic communications
            A theoretical physicist has presented research that shows bacteria might transmit electromagnetic signals to produce species-specific wavelengths.
            According to research presented by Northeastern University physicist Allan Widom, based on existing knowledge of DNA and electrons, bacteria can indeed communicate.
            As i said before, we are all "Fractal Antennas" amongst other things
            DNA could act as an antenna in electromagnetic communications | TG Daily
            The sun is our primary natural source of UV radiation
            Principle of Rythm:
            "Everything flows, out and in; everything has its tides; all things rise and fall; the pendulum-swing manifests in everything; the measure of the swing to the right is the measure of the swing to the left; rhythm compensates."
            • Now, would it be so crazy to consider a magnet like a Fractal Antenna
              Electrons on the brink: Fractal patterns may be key to semiconductor magnetism (w/ Video)
              Just as the heartbeats of today's electronic devices depend on the ability to switch the flow of electricity in semiconductors on and off with lightning speed, the viability of the "spintronic" devices of the future -- technologies that manipulate both the flow and magnetic "spin" of electrons -- will require similarly precise control over semiconductor magnetism.
              Solid-state physics: Golden ratio seen in a magnet
              The golden ratio — an exact 'magic' number often claimed to be observed when taking ratios of distances in ancient and modern architecture, sculpture and painting — has been spotted in a magnetic compound.
              Access : Solid-state physics: Golden ratio seen in a magnet : Nature
              • Originally posted by bhaas View Post
                Here's another good video: Water Bottle Video
                Maybe write free energy secret revealed on it.
                Print out all the things you want and tape it to the bottle???
                If you are going to print something, i would suggest printing geometric figures, just like the ancient alchemists.....
                for instance the geometric form of a ferromagnetic ice than hit it with UV light (see http://www.energeticforum.com/renewa...gnetism-4.html starting with post#98
                btw: if the universe is all wave, then what you write is too...think about it (also known as principle of mentalism )
                bhaas, Dave you are going to like this, i posted it here:
                http://www.energeticforum.com/147048-post190.html
                • From: James Y Johnson -- Dipolar resonance -- Anomalous dispersion bands
                  Abstract -- Changes in the energy content of dipolar substances are produced by exposure to a concentrated electromagnetic field having one or more frequencies corresponding to wavelengths between 3 mm. and 6 metres approximately and equal to characteristic periods of the substances treated. The process applies to naturally dipolar substances and to those in which dipoles can be induced by a field. The characteristic periods of the substances are of three kinds depending respectively on (1) the relaxation time of the dipoles when orientated by the field, (2) the natural oscillation-period of the dipoles, (3) the term-difference frequencies of the atoms. They are associated with anomalous variations in the optical and dielectric properties and can be found by examining those properties in a field of varying frequency. They can be varied within limits by changing the temperature, pressure, concentration, &c., and may thus be adjusted to correspond exactly with a field of approximately correct frequency. The fields may be standing ones produced between conductors such as concentric tubes or the plate resonators described in Specification 417,564, or radiated fields concentrated by reflectors. They may comprise several different frequencies and constant electrostatic fields may be superimposed on them. The exposure may be continuous or intermittent and different frequencies may be applied in succession. The invention is not concerned with the production of merely transitory effects and temperature changes, but with more permanent physical and chemical effects of which the following are examples
                  ....Crystallization is stimulated by the use of a varying field
                  Electrets may be produced by subjecting a fluid dielectric to a field and then solidifying it by freezing,
                  as you said Dave
                  The growth of crystals, as well as of organisms, can be stimulated by the process according to the invention, if the mother liquor is exposed to a varying field of suitable frequency during crystallization. Of course it is not implied that the cause which promotes inorganic growth is precisely the same as that which promotes the organic growth. (the cause is the same, principle of polarization )
                  so this is how you control the formation of ice to turn it ferromagnetic + a printed fractal figure
                  see my proposed Mother Liquor for a crystal power cell http://www.energeticforum.com/149699-post204.html
                  • from the same article:
                    With water for example it is shown in Figure 2, wherein the curves shows the course of the dielectric constant when using varying wavelengths for observation, and exhibiting a band of anomalous dispersion at a wavelength of about 1.5 centimeters.
                    The course of such functions has already been theoretically explained by Debye and brought into mathematical form. In the description, the time lag appears as a substantial constituent of the conception, i.e., the time which the molecules require in order to come into equilibrium with an external field. The time lag is, inter alia, dependent on the internal friction constant and the temperature. In order to tune the irradiation alternating field and the natural fequency of the substance to be treated to each other, the external frequency may be altered while keeping the time lag constant until resonance is attained, or the time lag may be altered while keeping the external frequency constant. The latter may be conveniently attained by altering the internal friction, i.e., by alteration of the concentration and/or temperature.
                    Resonance dispersion appears in all conducting dielectrics, i.e., in electrolytes. it is of special importance for the processes in living organisms
                      water is the key to all
                      Wow, this thread has been moving along since I last posted... really need to catch up!
                      Just wanted to throw this in, to add to your post:
                      Genesis 1 (KJV)
                      1 In the beginning God created the heaven and the earth.
                      2 And the earth was without form, and void; and darkness was upon the face of the deep. And the Spirit of God moved upon the face of the waters.
                      ‎"It's all in the MIND"
                      • Genesis:
                        "6 And God said, "Let there be a firmament in the midst of the waters, and let it separate the waters from the waters." 7 And God made the firmament and separated the waters which were under the firmament from the waters which were above the firmament. And it was so. 8 And God called the firmament Heaven."
                        • Waters
                          (see image above)
                          • The waters below heaven are gathered unto one place, and dry land appears.
                          • Dry land = Earth, gathered waters = Seas
                          • Lights are created in the firmament (heaven) to divide day from night
                          • The greater light is for day, and the lesser for night. Stars are also created.
                          The circle represents the waters above being separated from the waters below.
                          I do not see the waters above being mentioned in the first chapter.
                          Disclaimer: Please do not accept this as the truth. It is my interpretation only.
                          As above, so below? Waters are above, and below.....
                          How does this fit into the current physics model? And Aether?
                          What am I missing?
                          • hint: http://www.energeticforum.com/147486-post197.html
                            you are almost there
                            • Originally posted by StweenyA View Post
                              [ATTACH]8820[/ATTACH]
                              What am I missing?
                              from http://www.energeticforum.com/psychi...tml#post152850
                              SEEK YOUR OWN TRUTH...I AM ONLY SHARING WITH YOU MY TRUTH
                              a fractal construct has an 'efficient function', it has a fractal ergonomy to it, they function on multiple levels and in multiple dimensions:
                              Fractal Constructs when joined together will adapt to enter resonance...my resonance is not the same as yours.... (when two people meet for instance)
                              Truth is also Fractal if the All is Fractal
                              or if you prefer your interpretation of the absolute...and some truth are absolute in one plane and relative in another
                              • Hey, water's on the sun.... that's not exactly the same thing!
                                As in my post:
                                waters are separated, firmament goes in-between, and sun (greater light?) goes in the firmament!
                                waters above
                                (firmament (sun) firmament)
                                waters below
                                I'm not sure if we must even take these waters in this chapter literally (Seas we could take literally), maybe it's referring to something else, like matter, Aether particles....
