Ya know when I was looking at the cell with the copper screen it seemed to move the field down away from the coil, the crack looked like it went all the way to the structured field but didnt crack the structured field.
I wonder if we could move the field totally away from the coil the bemf would go into the structured field and not the coil.
What I think the bemf is, the electrons(either) sets up the spiral then when there is a pulse or the electricity is shut off the residual electrons crash into the coil windings.
If we could do this we could build an electron pump it would be just a matter of timing, with no bemf to the coil
If we got no bemf to the coil we would know we were on the right track.
the best shape for a drain is the one found by Victor Schauberger, a drain optimized to create a vortex
and thus we keep coming back to the Smith coil...
If we could get the horizontal field to move to the top of the cell we could create the drain as in this pic. This is the way to go, then we would have a strong drain and may not have to pulse the field
from what we have seen so far quartz has been a major player, in our research it could definetely have an impact on the freezing process
have you considered using powdered quartz with the water...it will sink in to the bottom of the container where your alum plate is and get frozen....you end up with a vortex ice leading to a layer of frozen powdered quartz
Note: water expands when it is frozen , with the piezo electric properties of quartz and the memory of water + structure water sounds like a "Thunderfull" mix for an ice battery
Yea I was thinking the quartz would allow the either to move into the cell with less restriction whereas the acrylic is a dielectric.
But then again if we get the either field flowing from the top it wouldnt matter "
remember that info i posted a while back :
USU geophysicist links quartz deposits to mountains and faults
Geophysical measurements collected in the western United States reveal correlations between high concentrations of quartz and high temperatures deep in the Earths crust. USU geophysicist Tony Lowry says quartz is key to rock cycles resulting in large-scale deformation of continents. Image courtesy Tony Lowry, Utah State University.
you could even layer Dave, you freeze one layer to shape it, add some more water re-freeze etc.... could be also done with the quartz powder or other (my choice is on quartz ) and ice
I never thought of layering the ice I'll think on that
Im thinking of moving the either field up so it inters the coil from above like the drain you posted, will make a screen tomorrow, I have a taller container that I can use for a cell.
