Leedskalnin said the south field pulls more and the north field push's more,
the north field needs to point down toward the aluminum plate
good thinking
the kybalion:
principle of polarity
-the positive corpuscles seeming to exert a certain influence upon the negative corpuscles, causing the latter to assume certain combinations and thus "create" or an atom. This is in line with the most ancient Hermetic Teachings which have always identified Masculine principle of Gender and Feminine Poles Electricity
“Signs and symbols rule the world, not words nor laws.” -Confucius.
If the vortex coil was made using the Fibonacci scale, and you used the copper screen to shield the sides of the coil and move the lenz field up and into the top of the coil it would be like water down a drain
This is the answer, I can feel it.
Yes in this vid they speak of the A vector, the A vector is the energy moving into the coil that feeds the magnetic field, this is the field we need to move into the top of the vortex coil.
Use pure water the dielectric properties of the water is what we want.
Folks I have to admit Im more than a little nervous, if this works the implications are astronomical,
There are several people who know who I am and if harm comes to me or my family they have been asked to spam the net with that information.
Please keep us in your prayers.
May God bless you and draw you close to Him
In Jesus Name
Thank You
thats the coil Im using , I want to use a normal coil and see the difference just havent had time, to much going on with theory
This is what I've been doing for the past few days.
I've noticed thast the bubble tips form like tornadoes -- from the 'top down' so to speak. From the widest-to narrow point. All of the bubble configurations have been created by the dissolved gasses, in various concentrations (M-state water, or 'oxygenated'/vortexed water). (You can still get bubbles without M state, or spun water)
I used two wine bottles, and magnets in a vortex bottle configuration to spin the water. I'm not sure if it produces M state water, or oxygenated water, nor am I sure it matters. Oxygen is influenced by magnetism, isnt it? If it is, the idea I have on how the bubbles form in their vortex configurations still works.
When we are freezing the water, the dissolved gasses orient themselves, with the apex pointing towards the blotch wall, or towards the 'neutral center' -- where by virtue of winding a special coil, have aritifically cancelled the fields.
Think of how there is a big plastic island in the middle of two ocean currents. The little floating bits (plastic/dissolved oxygen) are rammed against each other, where we would observe no 'net movement', but are quite 'forced into place' and held in thier respective positions by the balanced current.
Thank you for being brave, dave.
I think it is the structured gasses which you can strike with the voltage spike -- and similar to how the shape of trees behaves like a Tuned LC circuit -- I think the shape in which we force those dissolved gases (oxygen, being the dissolved gas with the most importance for superconduction -- essentially the crystaline lattice structures the oxygen to 'receive' the high frequency)#
Inside the air spirals, I think that the oxygen is very close to being 'conductive'. (Say, isnt ORMUS a gas? More conductive dissolved gasses that would orient themselves in the 'cancelled region' towards the blotch wall) I have not struck them with a High voltage power supply yet -- I need to buy more MOSFETS for my flyback transformer.
I have recently had a very similar idea, wrapping the coil in a cone according to phi, as the receiving, 'Step down' coil. It reminds me very much of russell's cone coils, which he said produced OU based on a 'power multiplication principal'.
Are you talking about moving lenz (the counterbalancing force to our EMF) to the apex of the coil spiral? Do you have the second receiving coil wound in a 'cancelling' way (bifilar and the other cancelling fields)?
I do not have a cancelling coil to 'receive' the impulse. I think it would be better to capture the HV
I think the receiving coil would work very similarly, if you were to use a tesla coil as a receiving antennae. (By the way MM, the idea about using spray on glass, to induce dielectric breakdown around the tesla coil HV out -- very clever )
Specifically, the relation between the secondary, and the primary -- using a primary wound around the high voltage center (trapped, or conducted through the secondary).
Ice seems to freeze in an egg shape. From the outside in.
here is an easy coil to build, and once made it can be turned into a vortex shape: (used by orgone builders ) How to make an SBB coil
The Winding of the Cosmic Clock Spring Walter Russell
