Ya know Id bet if we could get the A vector field to move into the top of the coil as we discussed earlier we could get it to spin, anytime anything moves in a vortex pattern it experiences acceleration - more kinetic energy-higher energy yield.
I know I keep saying this but Im going to wind the cone bifilar coil tomorrow , if we can spin the A vector field without spinning the coil we're home free. Free energy that is
I just had to post this
Three sets of three the outsides are primarys wound in opposing directions the inside coil is the secondary wound with both wind directions.
All three fire into the secondary in one direction and then all three fire into the secondary in the other direction. Tesla's 369
remember the A vector field runs around the solenoid but inside the toroid
If wired right the bemf from the primary's one direction would fire the opposite primary's in the other direction.
The primary's that werent being fired would be harvesting energy I know Im reaching.
The geometric figure of a tube torus represented by the Seed of Life.
A basic one dimensional depiction of the "Tube Torus" shape is formed by ratcheting the Seed of Life and duplicating the lines in its design. In Physics, the Tube Torus is considered a basic structure in the study of Vortex forms. Some[who?](like: Meru Foundation Research: Secrets of the Hebrew Letters by Cynthia Gage for Atlantis Rising magazine) say the Tube Torus contains a code of vortex energy that describes light and language in a unique way, perhaps as something of an Akashic Record.[4
The golden ratio — an exact 'magic' number often claimed to be observed when taking ratios of distances in ancient and modern architecture, sculpture and painting — has been spotted in a magnetic compound.
What happens when the current passes through a Rodin coil; it creates a spin magnetic flux in it center (see all the experiments on Rodin coil; Shawn's post on this http://www.energeticforum.com/155413-post430.html )
the A vector field of the solenoid would be running the same as the toroid,and both magnetic fields would be running the same too, very interesting idea, will think on this awhile.
I have the toroid in now, will let you know if anything turns up.
the A field of the smith coil will be spinning too in resonance with the toroid, and will give you the third element: the spinning emf Tube Torus (Smith Coil )
Sort of along the same lines of what I was thinking of yesterday. It's funny how, if we humans are advanced antennae -- is it not possible that we can pick up on the same "frequencies"?
Either that, or it seems we all had awfully similar ideas.
Take the both the secondary in this picture and wrap it around into dave's circle. Either a torrid, or a rodin in between the two primaries (pancake bifilar).
MM, I think we could even make the whole thing smaller -- I have been trying a few days to produce this same ice pattern to one of your smith coil's. Your smith coil was wrapped something yellow.
My picture here shows the ice formation that I think I'm looking for -- I know I've seen it before. (couldnt find picture)
The red lines are the "cone" conductor I was looking at growing seperately in a layer -- and attaching above the ice pillar.
A rodin coil around the middle here? (Untested, but I think it might pickup more current, instead of high voltage because of its orientation on the cones)
Speaking of cones -- Russell said he had some coils that produced OU because they worked "with" the life/death cycle of electric current/voltage -- Looked something like this.
So I was thinking -- I think tesla, and russell knew about the way that the electric pressure wanted to flow. Generating the highest pressure at the implosive vortex.
http://i.imgur.com/1TtHf.png
I drew a red square around the center, like russell had a circle around his center.
Opposing cones, in both configurations -- are what I will be testing. Just thought I'd share.
I think there's something to those cones. I'm not sure what yet, as the idea is fuzzy -- but I see potential in all of these configurations.
want to see the Ice Caduceus, take a small plastic tube, wrap a caduceus around (i use my mobius/caduceus coil...but let's start simple ) hook it up to a 9 v battery and freeze...you'll see the vortex
Dave, you are showing people a simple manner to visualize the fields they are working with....you are making the immaterial material ....principle of polarity
and how they can manipulate them; this (ice field visualization ) is applicable to many other experiments, discussed in various threads in this forum
found an old hard drive neo , I'll Smith coil it and hook it up to a battery see what gives.
by the way, a while back i ran an experiment where i shorted not on purpose (bad contact) a mobius / caduceus coil in liquid water, then unhooked the coil...and froze it ... I wish i had taken pictures but very interesting result....next up mag + smith
If we do nothing else Im just thankful and hopeful that we helped in a small way
The vid for the caduceus coil is wrong
The last vid for the magnetic field in a toroidal coil is wrong too.
In the caduceus vid he's just twisting the wires and if you look both winds are the same direction they have to be one right hand twist and one left hand twist. refer to the pics I posted.
In the toroidal coil vid he has it backwards the electric field (A vector field) runs in the toroid.
