Harvesting Energy From the Sun Using Crystals
  • Are you suggesting that electrons enter the magnet at the a vector?
    Trust your own instinct. Your mistakes might as well be your own, instead of someone else's ~BW~ It's kind of fun to do the impossible ~WD~ From now on, I'll connect the dots my own way ~BW~ If I shall be like him, who shall be like me? ~LR~ Had I not created my whole world, I would certainly have died in other people’s ~AN~
    • Yes this field moves into the magnet.
      Are they electrons at this point, still thinking on that one
      • you should send it over at the guys behind the electric universe theory and Dr Laviolette, he is awesome and takes the time to answer you...at least he did when i emailed him
        • I see.
          To my limited knowledge, I believe it is electrons. But that's just opinion. Good work keep plugging along
          • Dave check your pm
            • MM gotcha , the field is electrical in composition, it cracks the ice, electricity will not propagate through ice therefore it cuts through the ice.
              • I pulled the cell this morning the bucking magnets make the A vector field chaotic, might be easier to catch in this mode.
                Mags if you read this try to put bucking magnets on top of the one's you already have, it wont be easy
                • Im going to put the cell in with the magnets in attraction mode with a small distance between them to see if the A vector fields are attracted to each other, we could probably guess on that one but want to see the interaction.
                  • Thunderbolts Forum • Index page
                    • Here's a link to the pics with the bucking fields
                      bucking permanent magnet pictures by Dave45_bucket - Photobucket
                        Electricity will move through the structured column of ice, the magnetic field created
                        • Look what I found
                          “If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe.” -Tesla .
                          The symbol of 6 and 9 are simplified version of :
                          more on this here: http://www.energeticforum.com/renewa...netism-20.html
                          a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
                          • JLN Labs - The TEP Project - Bifilar VS Bucking coils
                            I have conducted some tests to understand better the working process in the TEP.
                            The main goal of these series of tests is to compare Bifilar coils and Bucking
                            coils for their inductive and Back EMF effects.
                            I have used :
                            - a BIFILAR coil L1,L2 ( interweaved ) which has a calculated inductance
                            of 0.59 mH ( each )
                            - a BUCKING coil L1,L2 ( in serial ) which has a calculated inductance
                            of 0.75 mH ( each )
                            The tested coils are switched through a transistor BDX53C by a square wave
                            generator..
                            The inducted signal is received through a coil L3 ( wounded around the bifilar ).
                            Calculated inductance : L3 = 7.6 mH
                            • It seems a star also has an A vector field and a large one,
                              The Kuiper Belt is a huge region of the Solar System forming a ring around the Sun just beyond the orbit of Neptune. It is much like the asteroid belt between Mars and Jupiter, the Kuiper Belt contains millions of small rocky and metallic bodies, but it’s 200-times more massive. It also contains a large quantity of water, methane and ammonia ices, the constituents of cometary nuclei originating from there (see #4 above). The Kuiper Belt is also known for its dwarf planet occupant, Pluto and (more recently) fellow Plutoid
                                you reminded me of this news i posted a while back...
                                Underground river 'Rio Hamza' discovered 4km beneath the Amazon | Environment | guardian.co.uk
                                Scientists estimate the subterranean river may be 6,000km long and hundreds of times wider than the Amazon
