Harvesting Energy From the Sun Using Crystals
  • this got me intrigued, it was posted over at: http://www.energeticforum.com/renewa...d-true-21.html
    Could you guys have a look and and let me know what you think
    Dave, petar113507 you are the electric connoisseurs in this group
    Originally posted by Dfortune View Post
    After studying tesla plans, I think something is missing in Don's device(clever man) look carefully at is primary coil tube ,there is a space to put another coil in there!That would match tesla design for is transmitting tower.As for the placement of the diodes,SG and caps I havent figured it out for now.
    I think Tesla plans are more appropriate to study Don's device.Tesla is saying that a variable cap should be used in the primary circuit to tune the secondary,
    go figure.
    • Here's whats happening in the Don Smith device
      the A vector in the primary is coupled to the secondary through resonance
      The secondary is wound in such a way as to allow both spin directions to flow from the A vector of the primary into the secondary
      Please respond if you dont understand what Im saying and I'll try to draw a model
      The wiring direction of the primary is of importance in this setup, in other words you need the A vector field to be moving in the right direction as its related to the secondary-- if you have the right hand spin side of the A vector faceing the left hand wind of the secondary this system will not work.
      • being as you noticed a visual person, drawing would greatly help me grasp the set up, sorry
        • I just wanted to add that as you go from a planetary scale where you can see the Efield , to a scale of a magnetic rod, the E field becomes a subtle force (invisible) but you have also to consider the fact by going to a lower scale we have also gone to higher scale of frequency (principle of polarity )
          (lifespan of planet vs lifespan of a crystal / human )
          the good news is you have in water a subtle energy detector (see the doc http://www.energeticforum.com/152708-post377.html )
          as you go up the size scale , you also go down the frequency/vibration scale
          you vs an atom
          • The A vector is produced by the primary, the primary is not shown in this pic just the A vector of the primary.
            • Thanks Dave, this i can understand and looks familiar 6 3 9
              • The A vector field and how it couples to the magnetic field
                The magnetic field is a neutral field until its coupled by the A vector field which gives it a spin direction
                  The magnetic field is a neutral field until its coupled by the A vector field which gives it a spin direction[/QUOTE]
                  This is a model of a galaxy if we are on the left side of the equatorial plane you can see what will happen as our solar system crosses over the equatorial plane, the gravitational forces and spin direction will be flipped.
                    I read you dave.
                    and that "A vector" when it couples through to the other energy transfer happens.
                    It is also that high potential field which gives those ice its sharp cracks, and structures the ice as it is freezing. This is where the magnetic opposites (N/S) void each other. With an electromagnetic coil, I have only given it a constant voltage, and it gave me a pretty consistent structuring of the dissolved gasses.
                    With all the pizeo crystals, they produced a much different pattern. After seeing 5 of them freeze -- I saw they hold a record of how they freeze. I left the crystals half sticking out of the water, and some even completely submerged.
                    The ice freezing from the outside, in -- produced a steadily progressive pressure -- until the pizeo had a strong enough voltage potential to "crack" the ice, and force a dissolved gas layer to form (I think mostly oxygen layer, but cannot verify). The electric pressure from the crystal is dispersed through the gas, and and thus the it feels a lower potential/"pressure". It builds up to form different densities of dissolved gasses as it froze -- starting from very little gas, building up in denser layers, until a sharp "crack" happened in the ice.
                    the crystals ice told the story of how it was crystalized.
                    Really awesome
                    will post pictures tomorrow.
                    Will be trying breaking up some crystal freezing tomorrow.
                    I think we will soon realize your goal dave.
                    ==Romo
                      [IMG]
                      If i understood correctly it is a sliced up version of this:
                      see the whole animation frame by frame in the time warp album, a whole lot of the figures we 'll be familiar to you
                      time warp standing wave pictures by MonsieurM - Photobucket
                      images from : Freeenergyinventions
                      • I edited the model a little to make it clearer
                        • A comparison of Fomalhaut System and Solar System
                          compare the solar system (if you turn it 90 degrees ) to the following (first figure, the sun being the focal point )
                          • Originally posted by petar113507 View Post
                            I read you dave.
                            Yes when the A vector couples with the magnetic field there is an energy transfer to the magnetic field.
                              Dave, did you notice; Tesla's Double cone is the "solid" version of Don's Set up....It's mirror image on the vibrational scale (solid vs emf )
                              the bi cone emits high energy
                              Don's set receives high energy
                              Principle of Mentalism: Universe is all Wave
                              • Yes I noticed
                                you understand
                                And this may work to a certain extent, but is still way to complicated for the average Joe to build (me), there is a simpler way and I aim to find it.
