Harvesting Energy From the Sun Using Crystals
  • From: Floyd Sweet: Space Quanta Magnifier / Vacuum Triode Amplifier ~ Collected papers, diagrams, photos & videos
    just to have it referenced in this thread
    The Motional E-Field
    Of all the known fields --- electric, magnetic, gravitational and motional E-field --- the only ones incapable of being shielded are the induced motional E-field and the gravitational field. The nature of the motionally induced electric field is quite unique; in order understand it more fully we must start by parting with a few misleading paradigms. When magnetic flux is moved perpendicularly across a conductor an electromotive force (emf) is electromagnetically induced "within'' the conductor. "Within" is an artifact of the commonly used analogy comparing the flow of electric current within a wire to the flow of water within a pipe. This is a most misleading model theoretically. The true phenomenon taking place has little been thought of as involving the production of a spatially distributed electric field. We can see that the model's origins likely arose from the operation called "flux cutting", a most deceiving and misleading term. A better term, "time varying flux modulation", does not imply any separation of lines of flux. Truly, lines of flux are always in closure upon themselves and are mathematically expressed as line integrals. It is fallacious to use the term "cutting", which implies time varying separation which does not in fact ever occur. A motionally induced E-field is actually created within the space occupied by the moving magnetic flux described above. This field is present therein, whether or not a conductor is present in the space. In terms of a definition we can say that, when magnetic flux of vector intensity moved across a region of space with vector velocity, electromagnetically induced electric field vector BxV appears in the space at right angles to both and. Therefore,
    (1)
    It is this field that is related to gravity, it is virtually unshieldable. This field may be called the Motional E-field. According to T.E. Bearden, "It seems that the charged particles in the atom (electrons and protons) act like tiny magnets. Their motion in the space surrounding the atom would create this motional E-field". The field created by both the positive and negative charges would cancel to some degree, but due to the high orbital velocity of the negative electron relative to that of the positive proton the induced field of the electron should dominate the resulting field. The field produced as a result of these charges would vary proportionally to the inverse square of distance similar to gravity. The field produced by the translational motion of the charges would vary inversely as the cube of distance. This concept totally unites the electromagnetic and gravitational field theories and accounts for the strong and weak forces within the atom.
    note that the core is rotating (think Muller )
      Shawn, this is genius.....now what you did is create a primary and a secondary....principle of mentalism (all is wave )...so a miniature Tesla coil would actually collect the energy from the ice
      precisely! If You placed a telsa coil in ice it could receive as well as transmit because of the secondary coil. A rodin coil nearly has the same same ability yet it can only transmit in vibration, which I am not sure is good for the stability of the ice. I know that a roddin coil can transmit sound through water, mainly because the vibrations of the coil is not restricted. Yet in ice I would have to deduce that it will not transmit but on supersonic frequencies which have the smallest attuned vibrations yet I believe after a small period would cause the ice to explode much the same as a crystal glass cracks with the right attuned frequency of sound. Plus a secondary coil, when at the correct resonance, should be able to transmit through the ice with out damaging it.
      ,Shawn
      • I think you will like this short video:
        7 Major Tones of Light
        7 Major Tones of Light - YouTube
        Analysis of 7 Major Tones of Light
        See: The Music of Matter | Energy Research for full details
        IndianaBoys
        • Thanks IndianaBoys
          from the link you posted:
          Jelaleddin Rumi, a Persian Sufi mystic who lived from 1207 to 1273 century AD once said:
          “In the rhythm of music a secret is hidden; If I were to divulge it, it would overturn the world.”
          It was also anciently said by the great Alexandrian master Hermes Trismegistus, “As above so below”.
          see post: http://www.energeticforum.com/160291-post814.html
          when you read this page: The Periodic Table of the Light | Energy Research
          he almost enunciates all 7 principles of the Kybalion
          In other words, at an extremely high rate of vibration, in the wavelength range of perhaps 0.01 Å to 10 mÅ or shorter, light “condenses” into that which we perceive as matter.
          As the vibrations of light oscillate to ever higher rates, light extends further and further into subtler levels of the conscious field, which is to say that it extends into ever higher vibrations of consciousness.
          • Nesting Bashar Coil inside the Rodin Coil
            Hi Monsieur
            Recently, the Rodin coil has interested me a lot, as it is designed by sacred geometry, The twist it develops in the center is very beautiful:
            The force field:
            Also bashar proposed a coil that can act llike a spacetime antenna:
            The Idea I have got is to build a transformer which the primary is a rodin coil, and the secondary is a Bashar Coil, nest the Bashar Coil inside the Rodin coil so to speak:
            What do you think about this?
            Elias
            http://blog.hexaheart.org
            • Originally posted by elias View Post
              Hi Monsieur
              [CENTER]
              Elias
              I think this could make some powerful Antenna at the least....
              let us know what happens, I'm quite curious to see the results of your experiment
              • This will be one of next projects, first I want to finish my work on the Muller/Watson device.
                  Thanks IndianaBoys
                  I can see what you mean. Actually two golden mean vorteces, placed in opposite rotation would eventually form an oblong circle like the one posted. Which of course would form a nearly perfect circle.
                    Hi Monsieur
                    The force field:
                    Elias
                    I would suggest to try it with DC first. And use a neosphere/ neodymium ball just to see what happens.
                    • Originally posted by IndianaBoys View Post
                      IndianaBoys
                      WOW! This is amazing. It brings to mind God speaking the universe into being. I always thought of it as maybe a song he sang. It also brings to light songs being used to bring people out of comas, healing people, causing accelerated plant growth, causing water to be structured, etc. Makes me also wonder about overlapping frequencies. I wonder if 3,6,9 on the musical scale overlapped would have any unusual properties?
                      • Originally posted by shawnnweed View Post
                        you got it and together they form:
                        It is also called a Fermat's Spiral -- from Wolfram MathWorld
                        The Fermat Spiral Also respects 936
                        Fermat's spiral (also known as a parabolic spiral) follows the equation
                        in polar coordinates (the more general Fermat's spiral follows r 2 = a 2θ.) It is a type of Archimedean spiral.[1]
                        In disc phyllotaxis (sunflower, daisy), the mesh of spirals occurs in Fibonacci numbers because divergence (angle of succession in a single spiral arrangement) approaches the golden ratio. The shape of the spirals depends on the growth of the elements generated sequentially. In mature-disc phyllotaxis, when all the elements are the same size, the shape of the spirals is that of Fermat spirals—ideally. That is because Fermat's spiral traverses equal annuli in equal turns. The full model proposed by H Vogel in 1979[2] is
                        where θ is the angle, r is the radius or distance from the center, and n is the index number of the floret and c is a constant scaling factor. The angle 137.508° is the golden angle which is approximated by ratios of Fibonacci numbers.[3]
                        • And the above will allow you to do the following
                          Transmutation patents
                          US2003226401
                          Atomic structure recognition and modification method and apparatus Inventor: LETOVSKY HOWARD
                          Also published as: US2005145031 // US2005155340 (A1)
                          Abstract -- The present invention provides methods and apparatus for determining the precise makeup of atomic and molecular structures, as well as providing the capability of modifying said structures. The invention uses induced resonant frequency wave effects to define and modify the electromagnetic, electrical, radioactive, atomic weight, and co-valent bonding characteristics of matter. One embodiment of the present invention may produce directionally controllable magnetic fields in gaseous media that interact with magnetically polarized vehicle surfaces to allow high-speed, highly energy efficient inter-planetary space travel. Another embodiment of the invention may neutralize waste products remaining from nuclear fission power production. The invention utilizes controlled multi-spectrum frequency induction to catalyze changes in atomic structures that may include: focused and dramatically amplified release of energy relative to natural states of matter; production of new alloys; transmutation of dangerous organic compounds into non-toxic media; and controlled polarization of matter. The benefits of the invention may include highly efficient interstellar spacecraft propulsion systems, hazardous waste elimination systems, efficient electricity production, and health enhancement of biological organisms.
                          patent: Atomic structure recognition and ... - Google Patents
                          Spiral coils generate very powerful electromagnetic fields by operating with two different but simultaneous resonant behaviors. Quarter-wave resonance is established by adjusting the frequency (and wavelength) of a radiofrequency (RF) voltage source until the length of the spiral conductor is equal to 1/4 of the wavelength of the alternating voltage. This generates an electromagnetic standing wave with at least one peak node and at least one null node. Inductive-capacitive (L/C) resonance is established by optimizing the thickness and width of the wire ribbon used to make the spiral coil. When inductance and capacitance are balanced, the current response will synchronize with the voltage input, creating in-phase behavior, minimal total impedance, and maximal power output. If two such coils are placed near each other, they will create an extremely powerful electromagnetic field between them, which can promote chemical and plasma reactions involving charged particles such as ions or plasma particles, possibly including nuclear fusion reactions (Leon Sprink got the Same results .
                          ELECTROMAGNETIC SYSTEMS WITH DOUBLE ... - Google Patents
                          • The rodin coil is brilliant.
                            I don't know if Marko Rodin fully understands the applications of his coil or how we could use it -- I have listened to him speak, and I cannot comprehend exactly what he is "getting at". He does not give very concrete examples, nor does he explain the practical applications of the number system. (I.E -- plug in different configurations, and look for certain results.)
                            I do not have much time, so I hope you guys follow me on this -- this is a brief conceptual overview -- you need to use your VISUAL imagination to unfold this similarly.
                            Think of a rodin coil like a 'o' -- that exact visual shape.
                            v
                            o
                            The doughnut with the two equal, opposite magnetic fields = o
                            This is the regular 6(3)9, all of them equal in respect to each other.
                            I will call this the "balanced rodin".
                            I can only unfold this briefly -- but the rodin coil does not need to always be wound around the same mold.
                            You can still follow the same pattern of number windings to get the dense flux fields -- but with a different output.
                            What I mean by this I can articulate in different words -- you can compress one end to expand the other end with respect to the same still center.
                            MM went briefly over this concept -- this is my unfolding that exact principal in a use-able fashion.
                            6(3)9
                            Bolded is the compressed side -- Italics is the expanded side.
                            I will call this the "9 biased rodin"
                            Stay with me -- this is winding the rodin coil around a cone which is in the shape of a funnel. Cutting off a part of the bottom portion, so that the windings can fit through.
                            You can still wind around the funnel in the same pattern, with the same number of winds as you did with the [equally] balanced coil, and receive a stronger magnetic flux on the '9' end.
                            Instead of "charge" as the input -- transfer this understanding into a "pressure". Think about a vortex tube.
                            The top "hot" end is the 6, the bottom "cold" end is the 9. The input "charge" level is the pressurized air which enters from the side.
                            Gotten from this link: Vortex Trap
                            This tube, will also help us understand the ORME's, when we connect that "Still charge center" of a coil, with the transition between opposites. In order for a positive to become a negative, it must pass through "0". In order for the same air, of the same charge density to become cold, after being rejected from the "hot" end -- it must pass through "zero". Magnetic fluxes behave the same way -- they need to pass through a "still center" to become their opposites.
                            Also, for the future -- Keep in mind, the vortex tube does the same thing with water, as it does with air. This might help you view the Tractates instructions in a different light.
                            Air Trap
                            We can throttle the air flow pressure, and heat temperature coming out of the hot end, by making the "cold" end more narrow. We can also achieve the same effect, by increasing the pressure which enters the tube -- while keeping the same balanced "flow" rate on the cold end.
                            By modifying the rodin coil -- we have done the same thing on the "hot" end, as we have done with the magnetic field on the "9 biased rodin".
                            So -- how can we multiply the "aparrent power" between coils? We can slam a modified an increased "9" pressure, against an increased "6" pressure. (Think: winding a coil opposite to the "9 biased Rodin", to cancel it) By slamming the two against each other -- we force a "still center" which appears to be greater than the input "still center" (Read: we are squeezing down on 6 and 9, to make a very big "3".)
                            If we can show that inflated "3" a "grounding" path, into a "balanced rodin" -- you would just get out the same "inflated 6 & 9". What if you showed that same "3", an un-balanced coil configuration -- like a bigger "6 or 9 biased rodin" coil?
                            Remember -- john bedini and bearden talk about the importance of Asymmetry -- so I'm not looking to just re-create the same things I started with. We can use the apparently larger "9" to do more work, than the original "9" could have done. We can use the asymmetry to do work.
                            We can give the same pressure an improvement in efficiency of transfer, by giving it the same shape which it wants to flow in.
                            Distort the mould which a rodin coil is wrapped around -- so that it resembles a portion of PVC pipe. The pipe has thin walls, and is longer than a "doughnut" rodin coil. instead of an "o" -- 0.
                            The purpose of this is to create a larger (still center) "3" pillar in the center of the pipe. Compress the 6 and 9, you inflate the 3.
                            If you guys still follow me -- here is an adventure of the imagination which has occupied my focus today entirely.
                            This brings me to the outline of an invention which Walter Russell outlines as the "optic-dynamic generator" -- stating that if instead of transforming the magnetic flux inefficiently by cutting the flux field lines at 90 degrees -- we could more directly tap the source of energy to put to our use.
                            Look at how this "flux" appears --
                            So, instead of spinning the magnet to cut the flux lines at 90 degrees, we can spin a coil to tap the flux lines "in phase" the direction they want to go.
                            (In phase, is not with respect to the phase -- it is to illustrate that going "with the direction of flow" better taps the electric/magnetic pressure. This is instead of what we currently do by cutting the flux at 90 degrees, and storing its opposed reaction for use).
                            We could spin a coil, to tap a magnetic flux in its preferential direction to produce more current than usual -- I think.
                            Another way, of the ways we could tap the "flux" more efficently -- use the ice as a dielectric of a capicitor. Arrange the charge into center of a capacitor, the structured ice conducts charge a similar way that iron conducts magnetic flow. Discharge cap during the cancelling "moment" of each opposed "slam" moment.
                            I support this idea with some of tesla's drawings. The reason tesla drew his cap in the diagrams as he did was to have the dielectric store some of the charge which cancelled between his coils polarity (N/S).
                            What I have outlined, is the direction I am aimed at. With that -- look at the beginning post. Do you understand why putting the smith coil inside the rodin coil is such a good idea? The smith coil produces exactly the same "still center" configuration as the rodin, with different windings. Store the charge of the smith "in phase" with the rodin's center. (superimposed charge centers around each other)
                            Each magnetic flux has to go through a "still center" to produce its opposite. If it goes through a bigger, or denser "center" -- you can expect the same "density" to be added to the field.
                            This is what I expect, at least. I am still winding coils to verify this. I decided it would be good, to not keep this idea to myself.
                            If you connect both the smith, and the rodin coil to a spark gap
                            (HV pulsed Cap:>Gap anode:>Smith coil:>Rodin coil:>spark gap:>collecting cap)
                            Spark gap fires -- dielectric breakdown.
                            The smith coil fires first.
                            Creates the still center.
                            Rodin fires second
                            Superimposing its "still center" on the other "still center".
                            This is what I see -- using different "phases" we could create an aparrent gain in the output of magnetic flux from the rodin coil. (in this respect Phase is referring to timing, like a polyphase motor uses different impulses to produce rotational force at the proper moment)
                            Timing of the cancelling region of the gained rodin coil's fluxes, might lead to a gain in the energy stored in an additional cap, to funnel back to the first.
                            I will expand on these ideas later, in more detail.
                            Peace,
                            ==Romo
                            • Watch this petar113507 , you are on the good track , might give you additional Ideas
                              Watch the first part of this vid with the sound off, imagine the field around the coil is the E field,
                              Oscillators, the Basic Tank Circuit 2 - YouTube
                              do you see whats happening the E field is being reversed just like the magnetic field is.
                              This is giving you ac from both your secondary's
                              excellent vid
                              • And remember this is what you want to create: (whatever the experiment)
                                be it:
                                or Smith Coil Nested inside Rodin Coil
                                and Don's Set up...CW + CCW = your Standing Wave....the timing is important too ; as petar113507 mentioned earlier you may need an Imbalance to get the extra juice
