  • #91
    Originally posted by shawnnweed View Post
    Keep in reminder that this was done inside a building. Ask yourself one question. Were these pyramids in sunlight? If not then the light was coming from below not above(as above...SO BELOW). Are these pyramids designed to catch the etheric light from above or below? It's abovious to me that if the light is emmananting/exiting from the top, then it is collecting it from below. You don't have to beleive if you don't want to? But then how can you say that the center of the earth is emmiting light and is like a small sun and truely beleive it? remember that this light does not effect anything but gold. It can melt gold but has absolutely no effect on rock(or any other material for that matter) and passes through it like gamma radiation. Given the right angle it will NOT melt gold but reflect off it and run along the surface like rain down a roof top.
    I am merely showing what has been said and tested, trying to find a hidden pattern while i am doing that, so i do believe you but with a little grain of salt, for the only reason that i have not tested it or found recent information on it...I would not have mentioned Pyramid associated with gold if it was not a clue in our research...And thank you again for your contribution, i do appreciate it, and it does make sense
    ps: All the roads lead to Rome (ROMA in reverse = AMOR )
    see also: Plasma antenna - Wikipedia, the free encyclopedia
    A plasma antenna is a type of radio antenna currently in development in which plasma is used instead of the metal elements of a traditional antenna.[1] A plasma antenna can be used for both transmission and reception.[2] Although plasma antennas have only become practical in recent years, the idea is not new; a patent for an antenna using the concept was granted to J Hettinger in 1919.[3]
    plasma has fractal properties too
    BTW: thus when you watch electric universe, whenever you hear plasma add antenna to it...enjoy
    THUNDERBOLTS OF THE GODS
    • #92
      Then again you could say that the core of the earth has some plasma in it too, due to high pressure and temperature. You see there is not one way of doing it, just remember this: the universe is a cosmic Fractal Antenna and so is what is inside it...as all antennas it can emit and receive...and it trickles down all the way down to the core of the earth and vice versa.You also have to entertain the idea that the Pyramids could have had more than one useful function (being fractal and all.... )
      • #93
        This reminds me of :
        Originally posted by Golden Mean View Post
        I plan to do some crystal experiments eventually. Just got some crystals this Spring off some land my family owns in northern MN ... and am Sun-cleansing them in my greenhouse and garden areas until I have time to work with them more in a more "concentrated" way.
        Have a great day!
        Golden Mean How goes the experiment?
        • #94
          this is a follow up on a question asked:
          Dave45
          Thank You ! You posted important question. If ozone can neutralize radiation then maybe our friends in Fukushima have a chance to recover.
          This idea really need investigation !
          I'm currently reading an article i posted here http://www.energeticforum.com/148474-post141.html and i found this info in it:
          Hydro-Magnetic Generator
          High-density charge clusters are thought by some theorists to be the basis of plasma-injected transmutation of elements and also neutralization of radioactive materials.
          back to crystal talk,water + quartz (barium titanate here ) from the same article:
          The reason for the very high voltage provided by the large Russian radar capacitors, when starting the generator, appears to be to polarize the crystals of barium titanate. One comparison is with the electronic ignition on a gas stove. Once the barium titanate crystals are polarized, the generator is running.
          now we know something new: High Frequency + Quartz = Polarized quartz then add water
          also the following description doesn't it resemble informations i published about quartz inside the earth
          The mono-crystalline barium titanate was sprayed on the internal surface of the torus; its dielectric permitivity was 6000. The thickness of the layer was about 1 micron. The water was purified to the specific resistance of 18,000,000 Ohm/cm.
          • #95
            Look what i found:
            Spray-on miracle could revolutionise manufacturing - Science, News - The Independent
            It sounds too good to be true: a non-toxic spray invisible to the human eye that protects almost any surface against dirt and bacteria, whether it is hospital equipment and medical bandages or ancient stone monuments and expensive fabrics.
            But true it is. The spray is a form of "liquid glass" and is harmless to living things and the wider environment. It is being touted as one of the most important, environmentally-friendly products to emerge from the field of nanotechnology, which deals in objects at the molecular end of the size scale
            Now all we need is a temperature resisting hollow donut
            http://www.surfacemd.com/images/Quar...tion-Guide.pdf
            updated post: http://www.energeticforum.com/148527-post144.html
            • #96
              check out my 2 last posts here
              http://www.energeticforum.com/148540-post150.html
              http://www.energeticforum.com/148543-post151.html
              Dave45, you are going to like this....
              • #97
                a little speculation on my part: feel free to answer:
                I wonder if the ley lines (Ley line - Wikipedia, the free encyclopedia) don't correspond to crystal deposits found in the ground. if so, each deposit acts as one giant crystal....
                ps: Silicon is the eighth most abundant element in the Universe; it is made in stars with a mass of eight or more Earth suns. Near the end of their lives these stars enter the carbon burning phase, adding helium nuclei to carbon to produce oxygen, neon, magnesium and silicon.
                Silicon
                Quartz: SiO2
                • #98
                  Just got an Inspiration, can't believe i did not think about it,
                  Tesla Coil + Quartz Crystal
                  From: http://www.energeticforum.com/148475-post94.html
                  • #99
                    This is brilliant and I beleive to be the most dangerous experiment next to Nuclear Fission to ever be tried. If you run that much electricity through a crystal and it should 'piggy back' on the etheric stream then it could be like directing a lightening bolt, litterally. I definately would not attempt this without a suit just in the case of random arcing or in case the cystal bends or breaks. Keep in reminder that when crystals have electricity run through them they do tend to condense and bend at the same time. But if the electricity were to come from all directions at the same time, as it would from a torroid, then they might just tend to condense instead of bending. Briliant, simply brilliant.
                    • Originally posted by shawnnweed View Post
                      Thank you shawnnweed , I could not have explained it better Now the other interesting point to make, is that you could control the points of access (where electricity contacts the crystal by changing the shape of the crystal (ie: pyramidal, spherical etc... )
                      ps: Your Safety always comes first
                        Silicon
                        Quartz: SiO2
                        It's a thought but ill conceived I think. It would make sense that if you are travelling in an open, unkown terrain that to travel from one universally recognized mountaintop to the other would seem to be common sense. This way it's impossible to get lost. Then the only thing left to do would be to stop and camp near where there was water. These camping points would eventually become settlement and and then villages, towns then cities. And the dirt paths would eventually become roads then highways. If you are suggesting that resonating crystals could be interconnecting forming a natural network of communication then that is not impossible by any means. Especially considering that these crystals do collect and transmit etheric light but to receive and transmit in all directions from all directions means that all the deposits would have to have at least on crystal in this form.
                        yet I can not conceive how men could somehow pick up on these deposits.
                        • 4 words:
                          Crystal Skull + High Frequency
                          • Looks great but put the crystal inside the core of the secondary.
                            This way the flux has to pass through the crystal, then put capacitor plates at both ends of the crystal
                            I say cap plates but they would actually be collector plates.
                            You know the old fluxcapacitor
                            • There are lots of types of crystals some can be formed
                              inside a magnetic field
                              • Hope you dont mind if I modified your pic
