  • They can tell how much electricity is in a thunderstorm by the ice content, starting to see the picture yet
    They think its a piezoelectric effect but I think the ice crystals are interacting with the earths magnetic field.
    Job 38:22
      Job 38:22
      like the Heliospheric current sheet: I was wondering where its smaller version on earth was , i think you are unto something
      according to USGS there is 3094 miles cube of these potential crystals floating in the air (not all but there is a hidden fractal engine that keeps feeding these clouds with water crystals)
      see post: http://www.energeticforum.com/147486-post197.html
      “Signs and symbols rule the world, not words nor laws.” -Confucius.
      • There are many forms or structures of ice one that is very interesting is ice VI,water mixed with Koh forms ice six a ferroelectric .
          i'll search it and see what i can come up with; in the meantime you mention ferroelectric and i found this which could be combined to your idea of using crystal ice as power source:
          Ferroelectric Capacitors (ice crystals VI ) and the Magnetic Resonance Amplifier
          In a nonlinear (another term for fractal ) ferroelectric capacitor there are three major nonlinear processes involved, so it is possible to carefully choose and arrange conditions so that the current through the capacitor moves against the voltage across its terminals.
          The Tom Bearden Website
          • Ok the cats out of the bag, if you want to see something very interesting get a clear container put an air cored inductor with water freeze it with 12 volts running through the inductor you can see the mag field.
            Iv tried the koh with some interesting results, but Iv been so busy with work I havent had the time to follow through, very soon though.
            HH
            • Ok guess Ill sign off till next weekend, will try an read the progress on my phone till then happy hunting as we say on the treasure hunting websites.
              I also metal detect and gold pan, when I have time which has been very limited here lately.
              Oh by the way speaking of gold = electrodes
              • In a nonlinear (another term for fractal ) ferroelectric capacitor there are three major nonlinear processes involved, so it is possible to carefully choose and arrange conditions so that the current through the capacitor moves against the voltage across its terminals.
                I wish I knew exactly what he was talking about, ill have to look into that statement. Reminds me of something I am currently working on (although very slowly)
                http://www.energeticforum.com/renewa...capacitor.html
                  Sorry Dave, it was quite late for me last night, i had to catch some z's
                  I'll go treasure hunting today, to learn more about ice VI
                  • Originally posted by Armagdn03 View Post
                    I am so glad Armagdn03 you mentioned your post, It was driving me crazy i could not remember where i read your post, because i knew it was relevant to this research...
                    thank you
                      HH
                      I have air core from old pc, i got a freezer, what i don't have is 12V battery, I'll see what i can replace it with...I have a water ionizer so i could play with all three normal , acid and alkaline
                        HH
                        Thanks again for the test, i had an idea a while ago about making a special coil, but i did not know how to test it
                        you may like, i have not tested it yet but here goes nothing:
                        What do you think would happen if i used.......a Caduceus Air Core as an inductor?... within the frame of the water experiment see post http://www.energeticforum.com/143400-post85.html for more info on the caduceus
                        http://i1206.photobucket.com/albums/...usaircore1.jpg
                        check this one out too: http://www.energeticforum.com/143990-post101.html
                        let me know what you think
                        I did try your experiment Dave, i think i got hooked to it , as you said the magnetic field does appear....
                        • Preliminarily results on the caduceus air core in frozen normal water: there is definitely a difference in the formation of crystals within the container, i took some picture (hooked the coil to 2 * 5v batteries )
                          used the sun in background:
                          the clear center is not yet frozen (which kind of surprised me, i left it long enough to completely freeze, i'll have to repeat it to make sure )...
                          I forgot to mention a little detail, there was a "hump" of frozen water on the opposite side of the coil...
                            MonsieurM,
                            You must watch this video.
                            ‪How to build a Hutchison Power Cell !!!!‬‏ - YouTube
                            It is not the same one. It shows ingredients. One of which is rochelle salt mixed with epsom salt to forms its own natural cystaline structure.. He also used sodium silicate, which when dried, is compatible with the epsom& rochelle mixture. He also used Iron Pirite as a doping agent. Once cooked and dried he ran 12 volts of DC through it. He simply cut the end of a 12 volt power supply and stripped the wires then plugged it into the wall. Now he doesn't have to use batterries. Of course this is for alligning the flow of the voltage in the crystal power cell by polarizing the substance mixture. He goes into great detail.
                            I know this might sound a little crazy or expensive but you could mix iron pirite in with the suggested 2 tablespoons of silicon dioxide mineral, which forms quartz crystals, and once you add a little bit of the hot water to the silicon dioxide powder, stir the mixture vigorously, then drop that into the same type of metal cylinder that John Hutchinson crystal power cell use, then drop it into liquid hydrogen to speed up the freezing process. If you stir the iron pirite and then drop it in it should freeze the mineral in place which should evenly distribute the electricity. Then polarize it with the 12 volt power supply. Of course this is just conjecture but I think it should work and possibly be more powerful. Imagine iron pirite mixed into an M-state quartz crystal! Once polarized it should pass electricity far more efficiently than John Hutchisons crystal power cell. I might be wrong but if I'm right this mixture should be 1000 times more efficient.
                            ,shawn
                            • Originally posted by shawnnweed View Post
                              MonsieurM,
                              ,shawn
                              I'm on it, downloading it right now
                              If you guys have the time read this post, i posted a Russian vid that is quite interesting, it relates to the Coral Castle key (http://www.energeticforum.com/148673-post110.html ) but in an interesting way it relates also to symbols found in Russia...quite interesting, read the comment i made too
                              http://www.energeticforum.com/146447-post63.html
                              • Caught me off guard when i saw him all dressed up an "electrifying" as he puts it
                                did a quick search while it is still downloading (connection a bit slow), i found this:
                                The Indian alchemical literature in Sanskrit and Tamil refers to the multi-dimensional use of a wide variety of minerals. The most important are: (A) mica, calamine, copper-pyrite, tourmaline, iron-pyrite, copper-sulphate, bitumen and lapis lazuli, called superior minerals and orpiment, alum. sulphur, realgar, tinstone or cassiterite, red-ochre. antimony and iron-sulphate. caIled subsidiary minerals.
                                tourmaline
                                Alchemy And Alchemists: September 2010
                                great website about The Magic of Rocks and Stones its a compilation of info about rocks and stones and their myth around the world:
                                Pyrite
                                Having the same chemical makeup as Marcasite but with different structure, symmetry and shape, Pyrite is thus a polymorph of Marcasite and it can be extremely difficult to distinguish between the two. The name Marcasite is derived from the Arabic word for Pyrite. The confusion between the two minerals is amplified as the jewelry trade uses the trade name of Marcasite when in reality what they are selling is Pyrite. True Marcasite cannot be used in jewelry as it has an even higher tendency than Pyrite to crumble into a powder. Pyrite also closely resembles Galena, but Galena has a higher symmetry. Another mineral, Bravoite, is very closely related to Pyrite too, but contains 20% more nickel, although some go so far as to list it a variety of Pyrite.
                                Myth & Lore:
                                Pyrite was very often used for scrying(also called seeing or peeping). The Mayans, Aztecs and Incas, at one time, all were known to polish large slabs of Pyrite to a mirror-like finish which they used for this very purpose. Native Americans believed they could look into one's very soul when peering into a polished piece of Pyrite. Their shamans used it as "a stone of power," and their medicine men used it in certain healing rituals. Pyrite has also been labeled the "Healer's Stone".
                                “Magnetism is the King of All Secrets.” Paracelus
                                ‪Carl Sagan on Tycho Brahe, Johannes Kepler, and ellipses‬‏ - YouTube
