  • Study Finds New Properties in Non-Magnetic Materials
    A team of Penn State researchers has shown for the first time that the entire class of non-magnetic materials, such as those used in some computer components, could have considerably more uses than scientists had thought. The findings are important because they reveal previously unknown information about the structure of these materials, expanding the number of properties that they potentially could have. A material's properties, such as electrical conductivity and mechanical strength, are what determine its usefulness. The research will be published in the journal Physical Review Letters.
    The non-magnetic materials that Gopalan and his colleagues studied were thought to have one of the 32 different crystal symmetries--called point group symmetries--known to exist in nature. On the other hand, magnetic materials have 90 different point group symmetries because their atomic particles have magnetic spins, which can be imagined as tiny loops of current. "Motion is an extremely important aspect of magnetism," said Gopalan. "Magnetism develops in nature as soon as charged particles start moving or spinning."
    Scientists long have believed that symmetry allows magnetic materials to have more properties than non-magnetic materials because flipping the direction of spin creates an additional symmetry. But Gopalan's team has shown that non-magnetic materials, theoretically, can have just as many properties as magnetic materials. According to Gopalan, some non-magnetic materials have groups of atoms that distort by twisting or rotating. This slight movement is equivalent to a tiny loop of current and is enough to give the material some additional properties that previously were thought to belong only to magnetic materials.
    • Got back into town today, if you use a solenoid type coil with distilled water you can see the field lines but you have to let it freeze for three to four days.
      Also Iv noticed if you put the water inside say a pvc pipe you would expect it to freeze and bust the pipe but if its wrapped with a coil that produces a magnetic field it wont bust the pipe.
      To me looking at the field lines in the ice it looks as though the field is borrowing through the ice like small circular holes, very interesting.
      Hopefully now that Im back home I'll have a chance to do more experiments, the Smith coil has me curious I want to compare the mag field to another normaly wound coil with the same number of turns, you see I wound the Smith coil I have because of the way the mag field runs. I had never heard of the Smith coil before I wound one.
      I dont like the reference that calling it a caduceous raises, I shy away from anything that has references to a serpent.
      I guess Im old school in that I believe that there is only One God our creator, and He can be learned about in the written Word the Holy Bible.
      In the old days the demons were called what they were demons not aliens, there is a great deception coming they will land they will make contact, but they have been here all along they are inter dimensional beings and they dont have your best interest in mind.
      right hand twist -------------->
      <----------------left hand twist
        small update on the caduceus air core in frozen normal water, i talked about a little bump, i re-did the experiment using another air core , I still got a bump so i took a picture of it....
        nice little mountain...
        MonsieurM,
        Do you have a cover on top of the water to rule out the freezer fan blowing the water?
        Also, create some colloidal silver and add it to your water, should allow the lines of force to be more visible.
        IndianaBoys
          Nothing wrong with old school, you know what they say the best soup are made in old pots (not referring to age, but an appreciation of old school )
          Smith Coil it is then... looking forward to hearing your tests on it
          • Hi all,
            there is another interesting way to harvest energy from Sun, and using it for supplemental heating of your home. You can make you own solar air heater by recycling pop cans. Check this step-by-step manual an net: Solar panel made of pop cans for home solar heating
            • Good to see people trying to replicate John Hutchinson crystal power cell
              • I just reposted some info on another thread and it occured to me that these are just as relevant to our topic... ready for it
                .Think of a fractal antenna for what it is: a tuned LC circuit
                replace the word antenna with defect
                from:http://www.energeticforum.com/150302-post264.html
                from a 2002 article. Unlike so many other promising breakthroughs this is one that has been widely implemented.
                To further quote from the article: "The innovation, called Fractal Structure Circuit(TM) (FSC), uses fractalized conductor paths to replace the capacitors, inductors, and resistors in "RLC" circuits."
                And another quote: ""Virtually every electronic device uses coils and capacitors to form RLC circuits. These discrete components are arranged by tried and true rules to get the circuit to perform as needed. What we've done is ask: can a fractal pattern, with its self-capacitance and self-inductance, be used to eliminate components and still get the equivalent RLC circuit? We've found that the answer is yes; and in most uses, especially at microwave frequencies, all components can be replaced by conductive fractal patterns or 3D structures."
                And one more blurb from that article: " Looking at the Fractal Structured Circuit(TM) one sees, for example, a beautiful etched copper pattern replacing the usual traces connecting button or canned shaped capacitors and coils (or their SMT counterparts). "
                Here is the link to that article.
                Fractal Antenna Systems, Inc.
                enjoy...
                Dave45, How is your testing of the Smith Coil going?
                  MonsieurM,
                  IndianaBoys
                  I will try your suggestion and cover the experiment, don't have colloidal silver unfortunately, maybe a simple colorant would do the job?
                  ps: so what do you guys think of the previous post, you realize what it means and its implication...
                  • Originally posted by Armagdn03 View Post
                    I wish I knew exactly what he was talking about, ill have to look into that statement. Reminds me of something I am currently working on (although very slowly)
                    http://www.energeticforum.com/renewa...capacitor.html
                    Armagdn03, i have some info about your set up (this is applicable to a capacitor too ) ;
                    Graphite-Water Battery – Instant Charging Super-Batteries
                    Now, Dr Li and his team have discovered the key to maintaining the remarkable properties of separate graphene sheets: water. Keeping graphene moist – in gel form – provides repulsive forces between the sheets and prevents re-stacking, making it ready for real-world application. “The technique is very simple and can easily be scaled up. When we discovered it, we thought it was unbelievable. We’re taking two basic, inexpensive materials – water and graphite – and making this new nanomaterial with amazing properties,” said Dr Li.
                    When used in energy devices, graphene gel significantly outperforms current carbon-based technology, both in terms of the amount of charge stored and how fast the charges can be delivered. High-speed, reliable and cost-effective energy storage systems are critical for the future viability of electricity from renewable resources. These systems are also the key to large-scale adoption of electrical vehicles. Graphene gel is also showing promise for use in water purification membranes, biomedical devices and sensors.
                    Graphene capacitors might replace batteries- The Inquirer
                    Obviously graphene ultra capacitors are some ways from hitting the shelves but when they do they are expected to rival Li-ion batteries in capacity. However the characteristics where the graphene ultra capacitor technology already surpasses Li-ion are the time it takes to charge and cyclical longevity.
                    Apparently the majority of batteries operate in the 20 to 50 per cent capacity range, and graphene ultra capacitors take just minutes to reach those levels
                    see my posts on graphene used in Mobius Resistance here:
                    http://www.energeticforum.com/143990-post101.html
                    http://www.energeticforum.com/144235-post111.html
                    I still have to find a way of making graphene homemade style...if anyone knows how besides the scratching method see video below , we would be grateful
                    Home-made graphene « A quantum of science
                    I'll try it
                    • Originally posted by petar113507 View Post
                      How would you control those "defects" with a frequency? what freq. would it be? Would it be in the growing phase of the crystalline structure? Or after th crystal was grown, to be bombarded with a certain "resonant" frequency which would spontaneously induce super conduction?
                      I think that super-conduction has to do with a certain shape. So, for instance migrating atoms, or leaving an empty part
                      That was the original point of looking at superconductivity -- was with the intent to be able to build it. So, I've been looking a little bit at silicon recently, as that is very easily obtainable for me near the beach.
                      Why is silicone interesting? Because we are made of carbon. Carbon is one half octave away from silicone.
                      http://www.reocities.com/capecanaveral/8989/russtbl.gif
                      Can you elaborate a little more on M-state water and "quantum water"? I do not like to ask too many questions without sharing my understanding, to make sure we are on the same page.
                      Seeing as how our nervous system would become more sensitized after consuming this type of water, I beleive that my body would give me a "good" response (the water tastes sweeter) when I drink it.
                      It seems to make moss, and grass grow very vigorously (resilient to drought), and greener than the other, faucet-watered areas.
                      MM, you post very rapidly. I would love to continue "thinking out loud" in an open group, but it takes a bit longer than I'd like to fully articulate my thoughts. I will reply when I can -- you have my full attention.
                      Thank you for the brainfood
                      I hope that when you read my post on Graphene, you realize that if you add "one half octave" you can apply the same to silicone
                      our nervous system is Fractal in its architecture, I'll give you a pointer, read post http://www.energeticforum.com/150313-post232.html
                      I am under the impression that water (the fractal antenna) briefly possesses a structure which induces very small windows of "superconductivity" near the center contracting axis of the vortex shape. I am under this impression that the magnets might "knock" the little superconductors out of position -- impregnating the water with a more electric property.
                      This has at least been supported by my experience with using one of these simple devices.
                      http://i31.photobucket.com/albums/c3.../Waterspin.jpg
                      When you vortex water you increase the level of oxygen present in water, and thus i refer you to this post http://www.energeticforum.com/149911-post213.html
                      Fractal Vortices
                      ps: I would still love to see someone try the peter davey crystal power cell
                      post updated: http://www.energeticforum.com/150030-post222.html
                      LEARN TO SEE THE CIRCUIT IN NATURE
                      • @ Dave45
                        Hi Dave, In your post #227 you speak of non-bursting of pvc pipes with coils. Have you done much experimenting along these lines? I live in the northwoods of Wisconsin, and many people here are faced with controlling pipe freeze problems in our harsh winters. The usual method is by using electrical heat tapes and insulation. These heat tapes are glutinous energy consumers. Might the use of coils and magnetism be a more efficient means of solving our pipe freezing problems?
                        I would be interested in doing some experimenting with this, and would appreciate any help in where and how to start.
                        Thanks, Gene
                        I hope this is not to far off topic.
                        • Check this thread out, i think Michael John Nunnerley has shown us the missing piece of the puzzle
                          http://www.energeticforum.com/renewa...tml#post150684
                          • Originally posted by gene gene View Post
                            Thanks, Gene
                            Hi gene the pvc pipe i used was an open ended tee, Ill try and post some pics, Im not sure it would be economical to wrap a long pvc pipe in copper besides the water is your system is under pressure Im sure that would make a difference.
                            But you never know till you try.
                            • This could be feasible using ice.
                              Maybe I should clarify that statement, the structure would be feasible.
                                you'll need a mold to build it ....am i correct...
                                the point that Mike was making is that the 3D field exist (proof being the experiments i posted in the thread) and it is a component of electromagnetic that has been ignored...if we understand it, we can play with it...
                                Dave, have you tested the Smith Coil ?
