    watch this 2 min video
    Water has Memory - YouTube
    Amazing vid, maybe we need to program the water beforehand.
    • so the crystal formation of the ice is perpendicular to gravity....
      excellent test Dave, Thank you
      -----if you want to expand a little on water, the following doc is an important source of info:
      Water, The Great Mystery - YouTube
      it is essential that you watch the doc, if you want us to advance....
      because you will see the potential of what i am talking about
      note: 85% of the brain is made of ....Water
      Quite different conditions exist in my system in which the electromagnetic waves or radiations are designedly minimized. the connection of one of, the terminals of the transmitting circuit to the ground having, itself, the effect of reducing the energy of these radiations to about one-half, Under observance of 'proper rules and artifices the distance is of little or no consequence, and by skillful application of the principle of "individualization," repeatedly referred to the messages may be rendered both non-interfering and non-interferable. This invention, which I have described in technical publications, attempts to imitate, in a very crude way, the nervous system in the human body.' Nicolas Tesla
      "If you only knew the Magnificence of the 3, 6 & 9; you would have a key to the universe."-Nikola Tesla
      • Once you have watched the doc, i'll propose a simple experiment, that i think would do the trick.....
          Here's another good video: Water Bottle Video
          Maybe write free energy secret revealed on it.
          Print out all the things you want and tape it to the bottle???
          • Originally posted by bhaas View Post
            Hi bhaas
            Iv thought of this but havent tried it yet
              Thats definitely a vid worth watching.
              • hint:
                Permeability of different materials - YouTube
                • I just wanted to add a little piece of info as a complement to the documentary :
                  this was posted a while back by IndianaBoys
                  Reflection of Mind Projected Thought into Water Photographed
                  LAB NOTES
                  now you know, what can be done with water
                    If you are going to print something, i would suggest printing geometric figures, just like the ancient alchemists.....
                    for instance the geometric form of a ferromagnetic ice than hit it with UV light (see http://www.energeticforum.com/renewa...gnetism-4.html starting with post#98
                    btw: if the universe is all wave, then what you write is too...think about it (also known as principle of mentalism )
                    • from a link i already mentioned: http://www.energeticforum.com/149708-post95.html ; read the post , watch the doc
                      Originally posted by petar113507 View Post
                      You have my attention with part 4, but I found parts 2 and 3 much more insightful. It seemed to be visually displaying some of the fractal functioning of some atomic structure. If you know walter russell's books, this seems to be showing atomic functions (along very similar lines). Very good share. Please let me know if you have any more info about this video series.
                      After seeing that guy play with the shape resonance of those structures -- It makes a whole lot more sense why "orgonite" in water, also affects the freezing structure of the ice -- much like your most recent coil, MM.
                      • Which reminds me Bashar's coil or Walter Russel coils
                        and
                        Third Prototype: Insulated Copper Tube Antenna « Bashar Space-Time Antenna (construction detail included )
                        in ice
                        If you look closely at these coils ....Smith (Caduceus ) Coil variation
                          This coil, which is the classic Smith coil
                          You can see how the gravity is effecting the field, Im sure it doesnt have the same effect on the field alone but Id bet it is having an effect.
                          freetoshare
                          everything is interacting with everything....if you just consider the presence of water around you and in you
                          • Now i think you guys are familiar with the power of water ,
                            read the following: http://www.energeticforum.com/136258-post21.html
                            Three Soviet scientists, S. STSCHURIN, V. P. and L. KAZNACHEJEU Michailova, confirmed after more
                            than 5 000 experiments that living cells transmit information through photons (in 1981).
                            We can describe the experiments simply as follows:
                            - Cells are bathed in a nutrient solution in two spherical flasks made of quartz. The two flasks are touching
                            each other
                            . If a cell culture is affected by a virus, or poisoned, the cells in the adjacent flask become
                            impaired every time and always have the same symptoms, whereas they should be protected from the toxic
                            influence of other cells by the quartz side
                            s.
                            - If you use glass flasks, the second cell colony is protected.
                            - The transmission between the two colonies is made by ultraviolet radiation.
                            *** These same three Soviet scientists measured the cell radiation using a photomultiplier. "Normally living
                            cells emit a constant stream of light rays. When a virus enters cells, radiation changes: it first increases -
                            then silence – then new increase, then gradual attenuation of radiation in multiple wavesuntil the cell
                            dies. This recalls the cries of pain of an animal.
                            *** In 1974, Simon STSCHURIN, said: "The cells affected by different diseases have different radiation
                            characteristics. We are convinced that photons are able to inform us long before the onset of pernicious
                            degeneration to disclose the presence of a virus ".
                            Today, scientists worldwide are exploring this phenomenon:
                            - In Australia, the correlation between cancer and ultra-hight- throuhput radiation is under study.
                            - In Brazil, fundamental studies are being conducted to understand light transport in cells.
                            - In China, the action of light on cells is currently studied.
                            - In Japan, research is trying to make an early diagnosis of cancer from cell radiation
                            link:
                            Light biology - quetanglais
                            and we know now that certain UV can transfer information to water....
                            see also Shawn's post: http://www.energeticforum.com/152432-post75.html
                              each other. If a cell culture is affected by a virus, or poisoned, the cells in the adjacent flask become
                              influence of other cells by the quartz sides.
                              I read somewhere sometime ago that scientists impregnated a frog with light thru petri dishes. Sperm in the bottom one and a frog in the top one; or frog eggs. I've been trying to find that article again. If anyone knows what I'm talking about I'd appreciate a link.
                              This of course gets me thinking. Why couldn't we put gasoline in a dish and water in another dish, shine light up thru the two and convert the water to gasoline. Once converted, couldn't we just use a few drops of the converted water to make large quantities of gas by mixing it into barrels of water???
                              I may be dreaming here.
                                Apply the Principle of Correspondence, and you'll find a way to run your experiment (here is your tool: Gnostic.Org: The Kybalion )
                                Francis E. WILKINSON: High-Frequency Transformations
                                Dancing electrons, whipped to a jitterbug frenzy, are performing miracles of modern alchemy in a backyard laboratory at Glendale CA. Racing back and forth through coils of wire at frequencies up to 100 megahertz, they transform water, natural gas, cottonseed waste, and potato peelings into new and useful substances for industry.
                                More on this:
                                Francis E. WILKINSON -- High Frequency Transformations
