  • This means the column we'v been observing is structured water molecules that are conducting and the clear ice around the column isnt structured so it doesnt conduct.
    I wonder what this would do for the Don Smith device?
    • This is what I did I ran 6volts ac through the coil to a bulb, then connected the aluminum plate to a grounding rod and let it freeze about 24 hours
      • Ok if you have two resonate coils connected using low voltage it should build a structured field between the coils then when used at high voltage the transfer should be increased this needs a lot more investigation I hope people with more knowledge and experience would take a look.
          so you have recreated this with water
          (analogy )
            could you explain the highlighted part , please
              (analogy )
              Yes its a highly efficient transformer because the ice that isnt structured acts as an insulator.
                The high voltage that usually expands in all directions from the coil will have to follow the structured path.
                • Were the two resonate coils in a Smith (caduceus) coil setup?
                    just like water when it flows...path of least resistance (usually fractal )
                    did you take into account gravity when you placed the water when frozen, like your previuos experiment
                    • Ok if we take the Don Smith coils freeze them in water at low ac voltage it should build a structured path between the coils then when hit with high voltage the voltage will have to follow the structured path, increasing transfer.
                        i'm all for it, in my last experiment with the smith coil wrapped around a plastic needle filled with water hooked to battery , the white part of the structured water looked like a frozen vortex (will have to retest it )....so I do think there is something to it
                        the original smith coil link:
                        Wilbert B. Smith: The New Science
                          No I was just theorizing about the Don Smith setup, the setup Im using has one coil and one aluminum plate.
                          • The Advantage of the Smith Coil is that it has Infinite resonance
                            The caduceus coil illustrated in Fig.1, basically consists of ordinary insulated copper wire wound in a double-helix around a ferrite core. THIS COIL HAS REPEATEDLY BEEN FOUND TO VIOLATE ESTABLISHED LAWS OF ELECTROMAGNETICS AND HERTZIAN WAVE THEORY WHEN A HIGH FREQUENCY CURRENT IS INJECTED INTO IT....
                            ....First. This apparatus has zero impedance - unlike an ordinary coil. when fed electrical energy the wire in the Tensor coil does not get hot.
                            Secondly. It has infinite resonance - unlike an ordinary coil which will resonate chiefly at its natural fundamental frequency and weakly on the second or third harmonic, the Tensor coil is capable of resonating strongly on any number of frequencies randomly spaced in the spectrum. The signal pumped into such a coil strangely enough cannot be quantified (detected) by standard RF (radio frequency) detection apparatus ( see: http://www.energeticforum.com/renewa...tic-field.html .) Many "Ham" radio operators and electronic technicians who have used these coils, are completely baffled by them
                            Caduceus Wound Coil Experiments
                            • I should be able to make a poormans superconductor out of a toroid
                              • my high voltage setup is really simple I have an ignition coil from a ford bronco run to a spark plug I connect the cell to the spark plug when I tap the positive and negative leads to a battery I get a pulse to my cell, the lead from the plate in the cell is shooting a spark about 1/4 inch to a ground wire.
                                Ice does not conduct electricity, this proves that structured ice will carry electricity
