  • Glad i did
    You are starting to see it, that's what counts....
    besides a picture is worth a thousand words
    you know the Bi cone i showed you, well Tesla made it the same way you are doing yours
    • Notice the A vector field isnt completely flat but is irregular(wavering) I noticed the same in the ice.
      • See the A vector field around the coil
        • old experiment with mobius caduceus coil, look at the fractures (if you can see them )
          the black part is were it shorted
          • synchronicity or what
            • If you notice in this pic the A vector field is shielded by the copper screen it wont form where the screen is, it moved above it.
              If we can move it above the cone shaped coil it should collapse into the core instead of the windings=no bemf
              • Excellent you can shape it and concentrate it
                • The superconducting column and the A vector field created by the coil and ice
                  • OMG, Dave you know what you are doing....you are recreating the Tesla Coil....with the vortex coil as your primary and your result is the secondary.....I only thought of it when i saw your picture with the copper screen..
                    forget about the ball
                    • The A vector field moves into the coil, it feeds the magnetic field
                      When you pull energy from a permanent magnet this field replaces it, this is where the magnet is tapped into the either.
                        Lets just hope we can bring it down to a useable form of energy. Once I get it working I have a transformer that steps down from 800 volts to 120 volts will give it a go.
                        • This is a work in progress, I hope that once the energy is flowing through the ice the freezer will not be needed, it should cool itself by magnetic evaporation, time will tell and Im not in control.
                          Iv always thought I dont have to know how it works I just need to know how to build it, but we may get both
                          • note there is a direct relationship between the volume of water and the vortex coil...(search cones and cylinders golden ratio )
                              Yes the cone coil should be made to the specs of the golden ratio, I used a funnel that I had, it should work for experimentation but in the final version it needs to be made in the golden ratio.
                                It would be interesting to see a rodin coil in ice, but the A vector field runs inside the core of the rodin coil,inside the doughnut, now to make a superconducting ring for antigravity
                                But for free energy we must us a vortex coil wound like Tesla's bifilar pancake coil. Im building one now and it easier said than done, one failed attempt so far, but I'll get it.
                                This hit me as soon as I woke this morning, if the A vector field runs through the core of the toroid We should be able to tap it with the ice cored toroid.
                                Now I tried this back when I was using dc to form the ice, I will try it using ac.
