Car Engine Powered by Lasers
Mon May 2, 2011 08:50 AM ET
Car Engine Powered by Lasers : Discovery News
THE GIST
* Japanese researchers have created an automotive laser system to replace spark plugs.
* Tiny ceramic lasers ignite the air and fuel mixture with concentrated optical energy.
* The durable laser system has the potential to improve fuel efficiency and engine performance.
Also found this:
A Survey of Laser Lightning Rod Techniques
http://www.teslaradio.com/pages/AD-A239_988.pdf
The concept of using a laser to create an ionized path in the atmosphere to act as a lightning rod is not new. Over the past four decades since the invention of the laser, there have been many documented investigations into the ionization of atmospheric gasses with an eye towards creating a laser lightning rod. Initial experimental attempts using lasers operating in the IR were not successful. Although some ionization was attained, it was found that the laser beam was selfquenching so that distances of only tens of meters were obtained in the atmosphere near sea level...
Anyone have knowledge in this area?
Looking to use deep UV direct diode lasers to ionize a path that is 12 inches apart between electrodes.
IndianaBoys
THE GIST
Also found this:
IndianaBoys
