Fusion Jr. Home Energy Reactor
I just thought I would share something I've been tinkering around with
The “Fusion Jr.” Home Energy Reactor is in essence a mini-generator that derives its power off of combustible waste material (like paper, wood, yard clippings, and even some plastics) inspired by “Mr. Fusion” as seen in the movie “Back to the Future II”. The potential for energy generation is great, and, in fact, this technology was used to power many cars during World War II and is a suggested energy source for developing countries (to provide gas to power stoves mainly). This is a truly unique project (never been done before), and, if completed, you can say that you have successfully converted garbage into electricity!
This is a green technology that derives power from an alternative fuel source that can be built by mostly salvaged components (well, not everything).
The Gasifier unit cleanly converts garbage into a burnable gas often called “syngas” or “woodgas,” then burns it creating heat which can be used to cook food (I have personally used this to cook a pot of soup) or Peltier Cells can convert the heat directly into electricity. The current produced by the Peltier Cells is sent to a Charging Module. The Charging Module charges a rechargeable Storage Battery. The Storage Battery supplies energy to run a Power Inverter. The Power Inverter can be used to run electrical appliances. Later we will see that after setting up the battery, inverter, and charger, turning this into a solar project is as easy as substituting the Fusion Jr. with any solar panel.
The minimum energy expected from one unit is dependant on how many peltier cells are used. Each cell contributes about 3 continuous watts. Potential energy from a Fusion Jr. system is well over 2000 watts, but harnessing all of that energy is difficult, especially since peltier cells are at less than 3% efficient.
Appliances with high watt ratings can be run even with low input because energy is stored in the Storage Battery.
