The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • from: http://en.wikipedia.org/wiki/Jantar_Mantar_(Jaipur)
    The observatory consists of fourteen major geometric devices for measuring time, predicting eclipses, tracking stars' location as the earth orbits around the sun, ascertaining the declinations of planets, and determining the celestial altitudes and related ephemerides. Each is a fixed and 'focused' tool. The Samrat Yantra, the largest instrument, is 90 feet (27 m) high, its shadow carefully plotted to tell the time of day. Its face is angled at 27 degrees, the latitude of Jaipur. The Hindu chhatri (small cupola) on top is used as a platform for announcing eclipses and the arrival of monsoons.
    27 Degrees = HM 9
    90 feet = 27 m = HM 9
    being a triangle with a 90 degrees angle and 27 degrees angle then the third angle is 63 degrees
    90 degrees = 27 degrees = 63 degrees = H.M 9 (the sum of all 3 angles is equal 180 degrees = HM 9 )
    add to it a 27 degrees latitude ...Fractal indeed
    • a bit of info.... think principle of correspondence
      Heat-based recording speeds hard drives | TG Daily
      A new method of recording information to hard drives could increase their speed by hundreds of times.
      An international team has found, astonishingly, that it's possible to record information using only heat – making future magnetic recording devices not only faster, but more energy-efficient too.
      "Instead of using a magnetic field to record information on a magnetic medium, we harnessed much stronger internal forces and recorded information using only heat," says University of York physicist Thomas Ostler.
      "This revolutionary method allows the recording of Terabytes (thousands of Gigabytes) of information per second, hundreds of times faster than present hard drive technology. As there is no need for a magnetic field, there is also less energy consumption."
      The discovery is all the more of a surprise given that, until now, it's always been believed that heat would simply destroy the magnetic order.
      Modern magnetic recording technology is based on the fact that the north pole of a magnet is attracted to the south pole of another, and that two like poles repulse.
      Recording a bit of information involves magnetizing a tiny part of the magnetic medium either 'up' or 'down' – and it's always been assumed that to do this, it's necessary to apply an xternal magnetic field.
      The stronger the applied field, the faster the recording of a magnetic bit of information.
      However, the new research shows that the positions of both the north and south poles of a magnet can be inverted by an ultrashort heat pulse.
      The pulse manages this by harnessing the power of much stronger internal forces of magnetic media. In the material the team used - an alloy of gadolinium and iron - the two types of atom are magnetized in opposite directions.
      The laser light heats the material up so fast that, at first, only the iron atoms lose their magnetization, and align theimselves with the gadolinium. When the material cools, the iron atoms reverse their magnetism again.
      Eliminating the need for an electromagnet makes it a much more efficient technique.
      • It is an interesting pattern when you research all the Great Men Of Science throughout history some patterns emerges as you notice their scientific interest , and search for understanding, where it has led them...the following are quotes made by one of them:
        Paracelsus: ; I'm sure you will recognize many subjects mentioned and discussed that go along the same line of thought
        : “Magnetism is the king of all secrets”
        Although Alchemy has now fallen into contempt, and is even considered a thing of the past, the physician should not be influenced by such judgments.
        But is not He who created it for the sake of the sick body more than the remedy? And is not He who cures the soul, which is more than the body, greater?
        Dreams are not without meaning wherever thay may come from-from fantasy, from the elements, or from other inspiration.
        Dreams must be heeded and accepted. For a great many of them come true.
        For it is we who must pray for our daily bread, and if He grants it to us, it is only through our labour, our skill and preparation.
        For one country is different from another; its earth is different, as are its stones, wines, bread, meat, and everything that grows and thrives in a specific region.
        From time immemorial artistic insights have been revealed to artists in their sleep and in dreams, so that at all times they ardently desired them.
        However, anyone to whom this happens should not leave his room upon awakening, should speak to no-one, but remain alone and sober until everything comes back to him, and he recalls the dream.
        If we want to make a statement about a man's nature on the basis of his physiognomy, we must take everything into account; it is in his distress that a man is tested, for then his nature is revealed.
        Many have said of Alchemy, that it is for the making of gold and silver. For me such is not the aim, but to consider only what virtue and power may lie in medicines.
        Medicine is not only a science; it is also an art. It does not consist of compounding pills and plasters; it deals with the very processes of life, which must be understood before they may be guided.
        Paracelsus
        Medicine rests upon four pillars - philosophy, astronomy, alchemy, and ethics.
        Paracelsus
        Nature also forges man, now a gold man, now a silver man, now a fig man, now a bean man.
        Paracelsus
        Often the remedy is deemed the highest good because it helps so many.
        Paracelsus
        Once a disease has entered the body, all parts which are healthy must fight it: not one alone, but all. Because a disease might mean their common death. Nature knows this; and Nature attacks the disease with whatever help she can muster.
        Paracelsus
        Poison is in everything, and no thing is without poison. The dosage makes it either a poison or a remedy.
        Paracelsus
        The dose makes the poison.
        Paracelsus
        The dreams which reveal the supernatural are promises and messages that God sends us directly: they are nothing but His angels, His ministering spirits , who usually appear to us when we are in a great predicament.
        Paracelsus
        The interpretation of dreams is a great art.
        Paracelsus
        The physician must give heed to the region in which the patient lives, that is to say, to its type and peculiarities.
        Paracelsus
        This is alchemy, and this is the office of Vulcan; he is the apothecary and chemist of the medicine.
        Paracelsus
        This process is alchemy: its founder is the smith Vulcan.
        Paracelsus
        Thoughts create a new heaven, a new firmament, a new source of energy, from which new arts flow.
        Paracelsus
        We do not know it because we are fooling away our time with outward and perishing things, and are asleep in regard to that which is real within ourself.
        Paracelsus
        What sense would it make or what would it benefit a physician if he discovered the origin of the diseases but could not cure or alleviate them?
        Paracelsus
        What the eyes perceive in herbs or stones or trees is not yet a remedy; the eyes see only the dross.
        Paracelsus
          thank you blackchisel97, very instructive
          147 = HM 3
          90 = HM 9
          you may not have noticed it but the female and male principle are expressed in the 2 windows
          Here is a quotation by Walter describing some early experiments:
          In September, 1927, I demonstrated this principle of dual polarity control by
          arranging two pairs of solenoids - one pair with more windings than the other - in
          such a manner that the dual polarity of Nature was simulated.
          The same Applies to the shape of an Egg
          The South Pole of an Egg (ie the smaller tip) is smaller than the North Pole (ie: the bigger tip )
          • from the same book:
            It is noteworthy that the orbital speed of planets is in inverse proportion to
            the square root of their distance from the Sun. Since the intensity of light
            diminishes in inverse proportion to the square of its distance, we can add
            further that the orbital speed of planets is in proportion to the square of the
            square of the intensity of sunlight falling on them. Like cells, men, and
            apparently every other living creature, their speed depends upon the stimulus
            they receive
            . see the previous info posted from physorg
            THE THEORY OF CELESTIAL INFLUENCE:Man, The Universe, and the Cosmic Mysteryby: RODNEY COLLIN
            PHILOSOPHICALLY, MAN CAN SUPPOSE AN ABSOLUTE. SUCH AN Absolute would include all possible dimensions both of time and space. That is to say:It would include not only the whole universe which man can perceive or imagine,but all other such universes which may lie beyond the power of his perception.It would include not only the present moment of all such universes, but also their past and their future, whatever past and future may mean on their scale.It would include not only everything actualised in all the past, present and future of all universes, but also everything that potentially could be actualised in them.It would include not only all possibilities for all existing universes, but also all potential universes, even though they do not exist, nor ever have.Such a conception is philosophical for us. Logically, it must be like that, but our mind is unable to come to grips with the formula or make any sense of it.
            from: The Heart, Mind and Spirit by Professor Mohamed Omar Salem
            Discussion
            It has long been thought that conscious awareness originates in the brain
            alone. Recent scientific studies suggest that consciousness emerges from the
            brain and body acting together (Popper & Eccles, 2000). As has been shown, a
            growing body of evidence now suggests that the heart plays a particularly
            significant role in this process
            . The above findings indicate that, the heart is far
            more than a simple pump. In fact, it is seen now as a highly complex, self-
            organizing information processing centre with its own functional ‘brain’ that
            communicates with, and influences, the cranial brain via the nervous system,
            hormonal system and other pathways.
            The involvement of the heart with intuitive
            functions is another interesting piece of information. However, as persons with
            transplanted hearts can function normally, the heart can be considered here as a
            medium or tool, for an underlying more sophisticated integrating system that has
            the capacity to carry the personal identity of the individual. These new visions
            might give better understanding to the concept of mind as a multi-component unit
            that is not only interacting with the physical environment through demonstrable
            means, but also has the capacity to communicate with the cosmic universe
            through non-physical pathways (Lorimer, 2001). This gives rise to the concept of
            the spirit as the non-physical element, or the field, of the mind that can
            communicate with the cosmos outside the constraints of space and time. The
            evidence for such communication comes from the reported phenomena of extra-
            sensory perception (telepathy, precognition, and clairvoyance), psycho-kinesis,
            psychic healing and religious experiences (Radin, 1997 & Henry, 2005).
            Possibly further advancement in quantum physics may one day give us
            further insight into how we can formulate this new model of the heart, mind and
            spirit.
            • so through some re-reading some of the links posted and discussed, found the following:
              Notwithstanding this, a good deal of truly early folklore was actually based upon the Grail and Dragon traditions. The very concept of ’fairies’ (’fair folk’) was born directly from this base, being a derivative of fée or ’fey’ and relating especially to ’fate’. In the Celtic world, certain royal families were said to carry the ’fairy blood’ - that is to say, the fate or destiny of the Grail Bloodline - while the Grail Princesses of romance and history were often called ’elf-maidens’. They were the designated guardians of the earth, starlight and forest, as beguilingly replicated by the elven race in Tolkien’s Lord of the Rings.
              In the old language of southern Europe, a female elf was an ylbi, and from this word derived the town name of Albi, the Languedoc centre of the Gnostic Cathars (Pyrenees ) (the Pure Ones) in the Middle Ages. When Pope Innocent III launched his brutal thirty-five-year military assault upon the Cathars from 1208, his campaign was called the ’Albigensian’ Crusade because it was set against the supporters of the albi-gens (’elven blood’).
              Melatonin enhances and boosts the body’s immune system, and those with high pineal secretion are less likely to develop cancerous diseases. High melatonin production heightens energy, stamina and physical tolerance levels and it is directly related to sleep patterns, keeping the body temperately regulated with properties that operate through the cardiovascular system. It is, in fact, the body’s most potent and effective antioxidant and it has positive mental and physical anti-ageing properties. It is manufactured by the pineal gland through the activation of a chemical messenger called serotonin. This transmits nerve impulses across chromosome pairs at a point when the cell nuclei are divided and the chromosomes are halved (a process called meiosis), eventually to be combined with other half-sets upon fertilization.
              Pine resin was long identified with pineal secretion and was used to make frankincense (the incense of priesthood). Gold, on the other hand, was a traditional symbol of kingship. Hence, gold and frankincense were the traditional substances of the Priest-Kings of the Messianic Bloodline, along with myrrh (a gum resin used as a medical sedative) which was symbolic of death.
              In the ancient world, higher knowledge was identified as daäth (from which comes our word, ’death’). In fact, as we know very well, the New Testament describes that these three substances (gold, frankincense and myrrh) were presented to Jesus by the Magi, thereby identifying him beyond doubt as an hereditary Priest-King of the Dragon succession.
              Yoga teachers suggest that the pineal gland (which they call the ’third eye’ or ’eye of wisdom’) is significant in the process of becoming ’aware’, for it is the ultimate source of the Light. Illuminists and other Rosicrucian adepts have long referred to the pineal as the secret ayin (arabic word also )- an ancient word for ’eye’. This spelling (a-y-i-n) is actually quite important because the original spelling of Cain (whether with a ’C’, a ’K’ or a ’Q’) was not ’C-a-i-n’ as we now know it, but ’C-a-y-i-n’. The name Cain, in its various forms, actually denoted One of the Inner Eye. Hence, from Kayin with a ’K’ derived the word ’King’, and from Qayin with a ’Q’ derived the word ’Queen’. Indeed, Cain’s father Enki-Samael was himself the Sumerians’ designated Lord of the Sacred Eye.
              It is said that a truly spiritual person can automatically perceive with the third eye (the subtle eye of insight), rather than be duped by mundane eyes which reveal only physical presences. Such presences are defined by their place within arbitrary time; but to pineal graduates there is no time to calculate, for they live in a dimension where time and space are of no consequence. This dimension is not a new discovery of modern science: it was known about thousands of years ago as the Plane of Sharon, the Plane of the Orbit of Light.
              as mentioned previously
              Believing is Seeing
              Medicine (of the heart and soul...a harmonic cascade effect ) rests upon four pillars - philosophy, astronomy, alchemy, and ethics.
              Paracelsus
              http://www.energeticforum.com/renewa...netism-23.html
              Within a coherent system, the range of the coherence (coherence length) becomes the constant quantity instead of the velocity. This makes frequency proportional to velocity apparently without restriction, so long as one remains within the coherence length. There can be many velocities each with a proportionate frequency; there can be as many frequencies as there are possible velocities. Frequency no longer has an absolute value, the system has become fractal in frequency.
              As a consequence, effects can occur in many different parts of the electromagnetic spectrum all originating from the same source which might be chemical, biological or electromagnetic. It is this which links effects of frequencies characteristic of chemicals to technological frequencies and through to the frequencies of biological systems ( see my post#20 through 22 http://www.energeticforum.com/136257-post20.html ). It is also the reason why environmental frequencies can mimic a chemical exposure for hypersensitive patients carrying a toxic body-load of a matching chemical. Table 1 shows the fractal frequencies generated by imprinting the optical spectrum from a mercury discharge lamp into water.
              COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
              An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways. This harmonic cascade of inter-connected-ness is the structure of our hologramic universe
              • sometimes the coherence can take the shape of a conspiracy
                check out this presentation, full of interesting info:
                Peter Levenda: Secret Space Program Conference Amsterdam 2011 - YouTube
                Bio: Peter Levenda is a native of the Bronx, New York, and has been investigating and writing about the connections that exist between politics, religion and history since the 1970s. His first book, Unholy Alliance: A History of Nazi Involvement with the Occult, was published in 1994 and bears a foreword by Norman Mailer. Since then, he has published Sinister Forces: A Grimoire of American Political Witchcraft, a three-volume magnum opus that searches for the meaning behind some of the most famous historical events in American history, from the Salem witchcraft trials to Jonestown, from Operation Paperclip to the weaponizing of the paranormal, from the serial killer phenomenon to the Manson Family and beyond, and exposes some of the strangest aspects of American political assassinations and their relation to a shadowy -- yet well-documented -- group known as "The Nine". His research has taken him to Chile during the Pinochet regime to investigate Nazi war criminals, to China, India, all over Southeast Asia, and throughout Europe and Latin America. His work has been praised by Paul Krassner, Jim Hougan, Dick Russell, Jim Marrs, Whitley Strieber, Katherine Neville, and many others. He has appeared numerous times in television documentaries on the influence of occult beliefs on the development of the Nazi Party: on the History Channel, the National Geographic Channel, TNT, Discovery, etc.
                • you may not have noticed it but the female and male principle are expressed in the 2 threads
                  http://www.energeticforum.com/renewa...magnetism.html and http://www.energeticforum.com/psychi...l-antenna.html
                  such a manner that the dual polarity of Nature was simulated Walter Russell.
                  a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
                  • Breaking News -Morocco Meteor/Meteorite News - Another New Meteorite Fall in Morocco? 4FEB2012
                    Another New Meteorite Fall in Morocco? ~4:00 pm 4FEB2012
                    Another new meteorite fall may have occurred in Morocco,
                    Over 100 cars went in the direction of Bouarfa to look for it. They this afternoon at around 4:00 pm local time there was a fireball and a boom that scared the local people. All of Morocco is after this fireball, after what they saw on TV about Tissint.
                    Habibi Aziz, Erfoud, Morocco
                    Latest Worldwide Meteor/Meteorite News: Breaking News -Morocco Meteor/Meteorite News - Another New Meteorite Fall in Morocco? 4FEB2012
                    zone del silencio.....
                    ----------------one more thing; observe the following vid...truly fascinating
                    Pendulum Waves - YouTube
                    Fifteen uncoupled simple pendulums of monotonically increasing lengths dance together to produce visual traveling waves, standing waves, beating, and (seemingly) random motion.
                    For more details see Home § Harvard Natural Sciences Lecture Demonstrations...
                    The period of one complete cycle of the dance is 60 seconds. The length of the longest pendulum has been adjusted so that it executes 51 oscillations in this 60 second period. The length of each successive shorter pendulum is carefully adjusted so that it executes one additional oscillation in this period. Thus, the 15th pendulum (shortest) undergoes 65 oscillations.
                    Our apparatus was built from a design published by Richard Berg [Am J Phys 59(2), 186-187 (1991)] at the University of Maryland. The particular apparatus shown here was built by our own Nils Sorensen.
                    see the various phases of this system
                    It has always been about perspective
                    Amazing Pendulum Wave Shadow Effect - YouTube
                    • This is beautiful Thank you for posting MonsieurM
                      V
                      General D.Eisenhower
                      http://www.nvtronics.org
                      • To cool thanks MM
                        makes both cw and ccw
                        • The one with shadows is awesome
                          Hey did you get the Wimshurst
                            Not yet...next week hopefully
                            • the following analogy is quite useful in understanding some of Walter Russell's writing on the table of elements (imo )
                              from: Theory of Celestial Influence (i highly recommend you read it )
                              Now these orbits, if we think of the atoms more realistically as solids, are in fact
                              shells. Atoms of different elements have any number of shells from one to seven. The
                              top shell in turn may have any number of electrons from one to its maximum
                              complement, with resulting variations in surface rigidity; so that if a shell with a full set
                              of electrons be regarded as made of steel, those with less might be as if made of oil,
                              rubber or plastic.
                              This picture gives a good idea of the relative densities of different elements. The
                              greater the number of shells, the more dense will the element be; while among the
                              group of elements with the same number of shells, that will be more dense whose
                              topmost shell is more rigid.
                              you can also change perspective and view each element as a snapshot of the following from wave to "matter" and back to wave:
                              so for instance hydrogen would be :
                              then the following elements would resemble this:
                              • follow up
                                There are thus seven main categories of density among the elements, which are
                                called periods
                                . But within each period, there is again a variation in activity according to
                                the number of electrons in the topmost shell. Each element is drawn to that with the
                                complementary number of electrons, as sodium with one outstanding electron naturally
                                seeks chlorine with one missing, to form salt. (male and female principle of polarity )
                                Here we see a parallel to Plato's analogy
                                of human souls seeking the complementary half from which they were severed in the
                                first creation. This is elemental male and female, electropositive elements irresistibly
                                impelled to combine with electro-negative ones, in exact proportion to their contrast.
                                Every element is by nature incomplete and seeks completion, except only those whose
                                electronic complement is entire, and who need no partner. These are the rare or so
                                called 'noble' gases - helium, neon, argon, krypton and xenon - whose shells are, as it
                                were, so hard and polished that no other element can find a hold.
