The Golden Tractate of Hermes Trismegistus applied to electromagnetism
This is extremely interresting but how can we incorporate this knowldege into our idea? And what gave him the idea that this could be an engine for flight?
The present invention provides an apparatus which uses electromagnetic waves to identify and then quantifiably affect matter at the atomic and/or molecular level. The present invention generates frequencies (note the plural used ) that may range from DC to light waves and above, and then analyzes the transmitted, reflected, and absorbed interactions of said frequencies on any form of matter. The invention then defines and generates optimized combinations of said frequencies to create specific effects on said matter with a minimum of energy input and output.
Electromagnetic Egg (formed by overlapping waves of various frequencies )
if you read my previous posts, you'll recognize some of the info
hint:
Piezoelectricity ( /piˌeɪzoʊˌilɛkˈtrɪsɪti/) is the charge which accumulates in certain solid materials (notably crystals, certain ceramics, and biological matter such as bone, DNA and various proteins
FIELD OF INVENTION
[0002] The present invention relates to frequency generators, spectrum analyzers, frequency amplifiers, lasers, microwave generators, transducers, spectrometers and other frequency generating and analyzing equipment. [0003] Description of Prior Art
[0004] various devices are used to determine the atomic and molecular makeup of organic and inorganic substances. Gas chromatographs, gauss meters, emf meters, spectrum analyzers, magnetic resonance imaging systems, frequency counters, and thermal imaging systems, all fall into this field of prior art. It has also long been understood that frequencies in ranges from subsonic, ultrasonic, microwave, lasers, and all other segments of the audio and electromagnetic spectrum can have profound effects on matter. Wind moving over bridges at specific speeds and oscillations can cause the bridges to come apart. Atomic explosions have shown that the radiated electromagnetic waves can shut down electrical devices from great distances. Microwave ovens, magnetic resonance imaging, laser beam effects on biological tissues, and the classic example of a high "C" note shattering a glass are examples of other frequency effects can have on matter. [0005] In the animal kingdom, dolphins use ultrasonic "sonar" senses to find hidden prey in the sea floor, as well as allegedly penetrate human bodies with healing frequencies. Recent evidence suggests that dogs may have the ability to "smell" cancer in humans.
[0006] Simpson's U.S. Pat. No. 5,377,163 describes a broadband acoustic sonar system designed to determine the species of various underwater life forms. Though Simpson's system embodies several of the elements of the present invention, it operates in a very narrow acoustic frequency range only, and is only designed to recognize various types of fish. In U.S. Pat. No. 5,343,443, Merewether discloses a broadband acoustic transducer which is used in various examples of prior art, and is exemplary of the types of sensors used in material recognition technologies. In U.S. Pat. No. 5,325, 703, Magori discloses an apparatus and method for identifying the concentration of fuels or gases in air, by directing ultrasound through a mixture in the measuring section, and determining the speed of sound through the air/vapor mixture.
[0007] In the area of nuclear materials processing, General Electric Corporation has invested significant financial resources in its "SILEX" project which uses specific laser frequencies to enrich uranium.
[0008] In the area of food and medicinal plant cultivation, it has been advantageous to control the rate of growth of various parts of plants and their roots. The use of frequencies to produce these effects is gaining popularity. [0009] Inducing a magnetic field in media that are normally non-magnetic is known in several areas of prior art. Eddy
current generators use a spinning magnet to induce magnetic fields in aluminum and other metals. Static electrical generators, the principle of which can be simply demonstrated by combing one's hair and having the hair be attracted to the comb as it is pulled away—provide other means to induce attractive and repulsive forces.
[0010] In an article entitled, "Effects of Magnetic Fields on Germination and Plant Growth", by K. Namba, A. Sasao, and S. Shibusawa, they described experiments with electromagnetic coils pulsed with frequencies on 'Komatsuna' plants. The frequency was varied from 1 to 1000 Hz, at a fixed intensity of 4 or 5 Gauss. Measured parameters were germination rate, growth rate and yield of the plant. The results indicated that frequency induced magnetic fields do influence plant growth and germination. Maximum germination rates, which were 20% higher than control rates, were obtained at around 10 Hz. An alternating magnetic field of 10 Hz was shown to have a statistically significant effect on plant growth, as measured by leaf area. The difference in growth rate between treated and control plants decreased after the field was removed.
[0011] A 2007 study presented at the sixth International Conference of the Balkan Physical Union entitled "The Effect of Electric Field Intensity on Bean Sprout Growing" by P. Kiatgamjorn, V. Tarateeraseth, W. Khan-ngern and S. Nitta. of the Research Center for Communications and Information Technology, Faculty of engineering, King Mongkut's Institute of Technology, Ladkrabang, Bangkok 10520, Thailand, showed that when bean plants were exposed to static magnetic fields, the plants grew larger and at a faster rate than without the magnetic fields. The bean sprouts were subjected to identical conditions without an electric field and with an electric field at 10 kV/m and 25 kV/m, respectively. The growing rate of the bean sprouts was observed every day for 5 days. The results also indicated that the bean sprouts under high electric field intensity showed better growth in comparison to the lower electric field intensity. [0012] The limitations of all relevant prior art is that although certain systems can identify the atomic and/or molecular components of matter, and other systems can effect subtle changes in matter, no prior art system or apparatus can analyze the key characteristics of matter and subsequently generate frequency combinations and transmissions in real time to effect changes at the atomic and molecular level of said matter. The present invention provides that capability.
“Signs and symbols rule the world, not words nor laws.” -Confucius.
[0016] Another objective of the present invention is to stimulate the healing process in humans and animals. Scientists at the University of Alberta in Canada have successfully regenerated teeth from the root by the application of 1.5 megahertz pulses. Electrical bone growth stimulation is now common throughout the world using frequencies at 76.6 hertz, 40 kilohertz, and 1.5 megahertz to increase the speed of bone growth after a fracture or surgery. The present invention may provide a broad new range of frequency choices to further enhance the effectiveness of both tooth and bone regeneration devices.
[0017] Another objective of the present invention is to provide an improvement on microwave ovens. Currently, microwave ovens use a frequency of 2.45 gigahertz. By adding certain other frequencies, the power needed to operate said ovens could be dramatically reduced. [0018] Recent research shows that radioactive decay rates, considered to be unique physical constants—and counted on in such fields as medicine and anthropology—may actually be variable. A team of scientists from Purdue and Stanford universities has found that the decay of radioactive isotopes fluctuates in sync with the rotation of the sun's core. The fluctuations appear to be very small but in the opinion of the research scientists—could lead to predictive tools for solar flares and may have an impact on medical radiation treatments. The researchers have ruled out the possibility of experimental error or an environmental influence on the detection systems that track the rate of decay as being responsible for the fluctuations and they have published a series of papers in the journals Astroparticle Physics, Nuclear Instruments and Methods in Physics Research, and Space Science Reviews.
[0019] The sun's rays that reach the earth that are considered responsible for these half-life change effects, contain light and electromagnetic energy, therefore, it is reasonable to surmise that the correct, controlled, application of light and/ or electromagnetic energy can effect the behavior of radioactive materials in different, more extreme ways that the subtle effects of relatively steady solar radiation. The present invention provides an apparatus which may create and optimize these desired effects.
[0020] Uranium Enrichment is a technically difficult process, and is essential to producing fuel for the global Nuclear Power industry, which currently provides approximately 16% of the world's electricity. The SILEX Uranium Enrichment Process technology utilizes lasers to separate or enrich the naturally occurring isotopes of an element to create 'new' materials with different qualities (This statement is from GE). Separation of Isotopes by Laser Excitation (SILEX) is an Australian development that GE Hitachi Nuclear Energy (GEH) is preparing for commercialization. SILEX has been
indicated to be an order of magnitude more efficient than existing production techniques but the exact figure is classified.
[0021] The SILEX technology uses specific frequencies of laser light, and does not incorporate the self adjusting and multiple frequency functionality of the present invention. However, the SILEX usage of electromagnetic frequency (laser Light) to affect radioactive energy output essentially validates the disclosures in my patent application #11059012, of which this application of the present invention is a continuation in part. The SILEX research also validates the suppositions and disclosures in my original parent patent application Ser. No. #10/165,648 where I contended that transformations of atomic structures were possible with frequency application. The present application is a continuation in part of my application Ser. No. #11/059,012, which is a divisional application of my application Ser. No. #10/165, 648.
[0022] DNA electrophoresis is an analytical technique used to separate DNA fragments by size. DNA molecules which are to be analyzed are set upon a viscous medium, the gel, where an electric field forces the DNA to migrate toward the positive potential, the anode, due to the net negative charge of the phosphate backbone of the DNA chain. The DNA fragments of different lengths are visualized using a fluorescent dye specific for DNA, such as ethidium bromide. This is another example of the interaction between electric fields and biological tissues.
[0023] Cold lasers are used everywhere from bar code scanners to CD players. Laser light therapy has a 40 year proven track record throughout the world. Canada has been using cold lasers for pain management and smoking cessation for over 22 years. In 2002, the Erchonia lasers received the first cold laser FDA clearance for pain and since then up to 26 different cold laser and light emitting devices have received FDA clearance.
[0024] Lasers are used in eye surgery for vision correction, the laser scalpel is used in general surgery, gynecological, urology, laparoscopic, and photobiomodulation procedures, the removal of tumors—especially of the brain and spinal cord, in dentistry for caries removal and endodontic/periodontic procedures, tooth whitening, and oral surgery. [0025] Lasers have been proven to increase cell metabolism, increase collagen synthesis for increased healing of soft tissues, increase osteoblast production for increased healing of bone, increase circulation through increased formation of new capillaries by release of growth factors, increase T-cell production for increased immune function, increase production of neurotransmitters such as endorphins, serotonin, ACTH etc., and increase chronic pain threshold through decreased C-fiber activity. The laser energy is absorbed by metabolically active pigments of the mitochondria in various cutaneous and subcutaneous layers. The changes in the stereo-chemical conformation induced by an electro magnetic field, improves the concentration of ATP by up to 200%. In addition, an increase in oxygen and glucose metabolism occurs. The main effect is an optimized function of the Na—K pump at the cell membrane, an increased protein synthesis (prostaglandin, enzyme) and a significantly higher rate of mitosis.
[0026] NASA is currently using Laser light therapy for medical conditions in space. All of these validate the growing acceptance in mainstream medicine for the medical efficacy of laser therapy as a viable, often superior therapeutic treatment modality.
3
[0027] It is reasonable to conclude that since animal tissue is reactive to many wavelengths of laser light in numerous known ways, and laser light represents just a small segment of the frequency spectrum, other as yet unknown reactions and effects may be catalyzed by subtle and precise manipulation of various wavelengths of laser light and other frequencies. The present invention provides an apparatus to generate these frequencies for the purposes of affecting organic and inorganic substances.
[0028] The present invention integrates broadband frequency generators, transducers, sensors, frequency amplitude analyzers (spectrum analyzers), photometers, computers, and computer software, as well as other specific components, to first determine the atomic and/or molecular structure of a given organic or inorganic substance, then determine a set of "active" frequencies relevant to said substance through computer analysis of the effects of said frequencies on a given substance, and then generate an appropriate "new" set of modified frequencies to be applied to a substance to achieve a desired result.
[0029] The invention as described herein has many advantages over prior art. A more complete understanding of the present invention, as well as further features and advantages, will be obtained by reference to the following detailed description and drawings. Preferred embodiments of the present invention will be described in the dependent claims.
Crystal can be shattered with the application of a "high C" audio tone. But if the goal were to melt or vaporize the crystal, the present invention may be used to activate and transmit a base frequency other than "high C", combined with an assortment of multi-order harmonics, frequency inversions, and dissonant frequencies relative to said base frequency....
...Said receiving and transmitting transducers 6, 8, and 10 are mechanically coupled to the interior of material analysis chamber 2, and are well known in prior art as magnetic, piezo-electric, photo sensitive, acoustic, or mechanical vibration sensing devices, so there is no need to go into specific detail of their makeup herein. [0035]
By manipulating all segments of the frequency spectrum, and applying open (no feedback sensing and responsive frequency tuning) and closed loop frequency feedback generation and modulation effects to the transmitted, reflected, absorbed, and especially active natural resonant frequency set 16 frequencies as they pass through atomic structures, atomic electromagnetic and structural changes may take effect. By classifying the changes—and rate of changes—in the reflected and transmitted frequencies, it may be possible to adjust the applied active frequencies to catalyze continuous, partial, or compound atomic and molecular changes (see also: Leon Sprink)
basically create a 3d electromagnetic fractal construct (think of a 3d spiderweb ); and its properties are as any fractal construct:
they carry a load of information ....
Because such Construct have an 'efficient function', they have, a fractal ergonomy to them,they function on multiple levels and in multiple dimensions:
An Egg Shaped Enhydro Quartz placed within An Electromagnetic Egg to excite an "Egg shaped" Molecule ( Tetrahedron :Water, Methane, Ammonia )
about the water molecule see posthttp://www.energeticforum.com/153341-post175.html
from the patent
... Additionally, many matter transformation effects may also be achieved including negative or positive electrostatic or electromagnetic polarization in a solid, liquid, or gaseous specimen
If you may allow me to propose a simple exercise of visualisation, to show you that these ingredients we propose to use played a major part in most of the OU experiments realized until this day:
Water is ""As Above so below, from within so without " Quartz/Silicate are all around you in the form of dust/around stars/in the core of the earth
and High Intensity that comes from the Sun /cosmic rays/ your power plant/underneath your feet
and these are your 3 6 9 that can be turned into:
same ingredient different type combination
nano silicate with high frequency sound break water up ( Huifang XU, PiezoElectroChemical Effect ) high frequency applied to quartz and water present in the air and the experimenter ( KOWSKY & FROST Gravity Nullification) UV light with water and quartz container to obtain genetic transfer of information ( MONTAGNIER : DNA Teleportation /S. STSCHURIN, V. P. and L. KAZNACHEJEU Michailova, living cells transmit information through photons )
------ Why does blood taste salty?
A sodium test checks how much sodium (an electrolyte and a mineral) is in the blood. Sodium is both an electrolyte and mineral. It helps keep the water (the amount of fluid inside and outside the body's cells) and electrolyte balance of the body. Sodium is also important in how nerves and muscles work.
Most of the sodium in the body (about 85% this number keeps popping up remember your brain has about 85% of water)is found in blood and lymph fluid. Sodium levels in the body are partly controlled by a hormone called aldosterone, which is made by the adrenal glands. Aldosterone levels tell the kidneys when to hold sodium in the body instead of passing it in the urine. (See a picture of the adrenal glands or the kidneys .) Small amounts of sodium are also lost through the skin when you sweat.
The sun is our primary natural source of UV radiation
I hope this makes it more apparent for the principle of 3 6 9
NASA Researchers: DNA Building Blocks Can Be Made in Space
08.08.11
NASA-funded researchers have evidence that some building blocks of DNA, the molecule that carries the genetic instructions for life, found in meteorites were likely created in space. The research gives support to the theory that a "kit" of ready-made parts created in space and delivered to Earth by meteorite and comet impacts assisted the origin of life.
"People have been discovering components of DNA in meteorites since the 1960's, but researchers were unsure whether they were really created in space or if instead they came from contamination by terrestrial life," said Dr. Michael Callahan of NASA's Goddard Space Flight Center, Greenbelt, Md. "For the first time, we have three lines of evidence that together give us confidence these DNA building blocks actually were created in space." Callahan is lead author of a paper on the discovery appearing in Proceedings of the National Academy of Sciences of the United States of America.
DNA could act as an antenna in electromagnetic communications
A theoretical physicist has presented research that shows bacteria might transmit electromagnetic signals to produce species-specific wavelengths.
According to research presented by Northeastern University physicist Allan Widom, based on existing knowledge of DNA and electrons, bacteria can indeed communicate.
Luc MONTAGNIER DNA Teleportation
A Nobel Prize winning biologist has ignited controversy after publishing details of an experiment in which a fragment of DNA appeared to 'teleport' or imprint itself between test tubes.
According to a team headed by Luc Montagnier, previously known for his work on HIV and AIDS, two test tubes, one of which contained a tiny piece of bacterial DNA, the other pure water, were surrounded by a weak electromagnetic field of 7Hz.
Eighteen hours later, after DNA amplification using a polymerase chain reaction, as if by magic the DNA was detectable in the test tube containing pure water.
--------which leads us back to:
principle of Correspondence:
Imagine a medical tool where you take a UV laser pointer and place a healthy cell , like stem cells, contained in a quartz lens and then shoot the UV laser through it, which would carry the healthy information in the beam, to heal sick people .
In the version of the Ogdoad creation myth used by the Thoth cult, Thoth created Ra-Herakhty, via an egg, and so was said to be the father of Neferhor.
(Both Thoth and Hermes were gods of writing and of magic in their respective cultures. )
- Ben Rich, the “Father of the Stealth Fighter-Bomber” and former head of Lockheed Skunk Works
When Rich was asked how UFO propulsion worked, he said, “Let me ask you. How does ESP work?” The questioner responded with, “All points in time and space are connected?” Rich then said, “That’s how it works!”
I have longed beleived that heaven and hell are both interdimensional and connected physically with an area on earth that is most attuned to their frequency. Which is why hell when described as fire and brimstone is often described as being in the middle of the earth, which we both know is molten iron and nickel. It is not that hell is literally in the center of the earth but that interdimensionally is is most like that dimesnion and therfore the only place that can connect with that dimesion as physical / interdimensional doorway. Much the same way Heaven is also another dimension or percieved reality in which there once was a place on earth made so that it could connect to it. This place was referred to as the garden of Eden which has obviously long been destroyed. But if we could find the exact location of the orignial garden and rebuild it we could possibly reopen that interdimensional doorway between heaven and earth. We might find their half guarded by an angel with a flaing sword, which would not allow us to enter, especially in our degraded state but it would be interresting non-the-less to have a re-established open forum with a higher intelligence that could at least cross through to / on our side. Yet this is just what I beleive their ir really not much to support this assumption other than belief. And probably a really dangerous thing knowing that we could connect with a higher plane of more devious consequences such as hell. I'm not really sure we are ready for either.
,Shawn
,Shawn
,Shawn
,Shawn
It is not up to us to decide....
"Everything flows, out and in; everything has its tides; all things rise and fall; the pendulum-swing manifests in everything; the measure of the swing to the right is the measure of the swing to the left; rhythm compensates."
the Hermetic Philosophy considers that the Universe may be divided into three great classes of phenomena, known as the Three Great Planes, namely:
I. The Great Physical Plane. II. The Great Mental Plane. III. The Great Spiritual Plane.
These divisions are more or less artificial and arbitrary, for the truth is that all of the three divisions are but ascending degrees of the great scale of Life, the lowest point of which is undifferentiated Matter, and the highest point that of Spirit. And, moreover, the different Planes shade into each other, so that no hard and fast division may be made between the higher phenomena of the Physical and the lower of the Mental; or between the higher of the Mental and the lower of the Physical.
sounds interesting but how could we tell what was going on within. And wouldn't a microwave have a similar effect.
I think there are computer simulator software that could do the work for usto visualize what is going on and get the right frequencies
papers on Simulating Microwave Oven:
Simulation and Experimental Method for Microwave Oven
