The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Here is a quotation by Walter describing some early experiments:
In September, 1927, I demonstrated this principle of dual polarity control by
arranging two pairs of solenoids - one pair with more windings than the other - in
such a manner that the dual polarity of Nature was simulated.
The same Applies to the shape of an Egg
The South Pole (female ) of an Egg (ie the smaller tip) is smaller than the North Pole (ie: the bigger tip / male)
see the Male part of the periodic Table and Female Part
I just wanted to mention this for the curious mind and important ...For most of the research done on medical use of electromagnetic waves; one aspect has been overlooked and that is to obtain optimal results such as in the use of Violet rays....the Antenna / the patient has to have followed an Alkaline Diet...In this research I have found that Alkaline Water and Diet enhances the healing aspect of the body.
“This structuring is best assayed with a UV spectro-photometer where one finds an increase in UV absorption due to an increase in the water bonding from the water forming chains on itself. The magnetic moment of this structured water is increased by 0.07 gauss and there is also an increase in the pH and dielectric conductivity.
sorry for the repetition;
key word quartz
Edgar Cayce often recommended animated ash and ultra-violet light therapy for persons suffering from cancer. The readings stated that the animated ash would increase the oxygen in the body and assist the immune system in fighting the cancer.
" Animated ash was a form of bamboo that was reduced to activated charcoal by means of a partial vacuum electrical carbon arc process. The resulting ash (alkaline ) was taken internally
Cayce’s dietary recommendations for cancer tended to follow several key themes:
• Eat a diet that tends to produce a balanced pH in the system with
a tendency towards alkalinity.
Imagine a medical tool where you take a UV laser pointer or violet ray and place a healthy cell , like stem cells, contained in a quartz lens and then shoot the UV laser through it, which would carry the healthy information in the beam, to heal sick people .
so to increase the UV effect, an Alkaline diet would be recommended
Based on the previous posts and using the Principle of Correspondence....You realize that a Male Dominated World tends to Be an Acidic World...and if you look around.....that is the case on so many levels
put a bit ofAlkaline in our way of thinking...to stop the Cancer
I wish I had the english subtitles too ...but the images in this 20 min doc.....will suffice to make you understand what happens in a Male dominated world ....to the Female Element....
the doc title is the Women Body and its portrayal in Italian Tv....hopefully it will come out with english Subs
if you are familiar with the movie Brazil you will understand:
Brazil is a 1985 British science fiction fantasy/black comedy film directed by Terry Gilliam. It was written by Gilliam, Charles McKeown, and Tom Stoppard and stars Jonathan Pryce. The film also features Robert De Niro, Kim Greist, Michael Palin, Katherine Helmond, Bob Hoskins, and Ian Holm. John Scalzi's Rough Guide to Sci-Fi Movies describes the film as a "dystopian satire".
The film centres on Sam Lowry, a man trying to find a woman who appears in his dreams while he is working in a mind-numbing job and living a life in a small apartment, set in a dystopian world in which there is an over-reliance on poorly maintained (and rather whimsical) machines. Brazil's bureaucratic, totalitarian government is reminiscent of the government depicted in George Orwell's Nineteen Eighty-Four,[1][2] except that it has a buffoonish, slapstick quality and lacks a Big Brother figure.
An acid (from the Latin acidus/acēre meaning sour[1]) is a substance which reacts with a base. Commonly, acids can be identified as tasting sour, reacting with metals such as calcium, and bases like sodium carbonate. Aqueous acids have a pH of less than 7, where an acid of lower pH is typically stronger. Chemicals or substances having the property of an acid are said to be acidic.
Common examples of acids include acetic acid (in vinegar), sulfuric acid (used in car batteries), and tartaric acid (used in baking). As these three examples show, acids can be solutions, liquids, or solids. Gases such as hydrogen chloride can be acids as well. Strong acids and some concentrated weak acids are corrosive, but there are exceptions such as carboranes and boric acid.
There are three common definitions for acids: the Arrhenius definition, the Brřnsted-Lowry definition, and the Lewis definition. The Arrhenius definition states that acids are substances which increase the concentration of hydronium ions (H3O+) in solution. The Brřnsted-Lowry definition is an expansion: an acid is a substance which can act as a proton donor. Most acids encountered in everyday life are aqueous solutions, or can be dissolved in water, and these two definitions are most relevant. The reason why pHs of acids are less than 7 is that the concentration of hydronium ions is greater than 10−7 moles per liter. Since pH is defined as the negative logarithm of the concentration of hydronium ions, acids thus have pHs of less than 7. By the Brřnsted-Lowry definition, any compound which can easily be deprotonated can be considered an acid. Examples include alcohols and amines which contain O-H or N-H fragments.
In chemistry, the Lewis definition of acidity is frequently encountered. Lewis acids are electron-pair acceptors. Examples of Lewis acids include all metal cations, and electron-deficient molecules such as boron trifluoride and aluminium trichloride. Hydronium ions are acids according to all three definitions. Interestingly, although alcohols and amines can be Brřnsted-Lowry acids as mentioned above, they can also function as Lewis bases due to the lone pairs of electrons on their oxygen and nitrogen atoms.
“Signs and symbols rule the world, not words nor laws.” -Confucius.
Nickel ( /ˈnɪkəl/ ni-kəl) is a chemical element with the chemical symbol Ni and atomic number 28. It is a silvery-white lustrous metal with a slight golden tinge. Nickel belongs to the transition metals and is hard and ductile. Pure nickel shows a significant chemical activity that can be observed when nickel is powdered to maximize the exposed surface areaon which reactions can occur, but larger pieces of the metal are slow to react with air at ambient conditions due to the formation of a protective oxide surface. Even then, nickel is reactive enough with oxygen so that native nickel is rarely found on Earth's surface, being mostly confined to the interiors of larger nickel–iron meteorites that were protected from oxidation during their time in space. On Earth, such native nickel is always found in combination with iron, a reflection of those elements' origin as major end products of the nucleosynthesis process in supernovas. An iron–nickel mixture is thought to compose Earth's inner core.[3]
The use of nickel (as a natural meteoric nickel–iron alloy) has been traced as far back as 3500 BC. Nickel was first isolated and classified as a chemical element in 1751 by Axel Fredrik Cronstedt, who initially mistook its ore for a copper mineral. The element name comes from a mischievous sprite of German miner's mythology, Nickel (similar to Old Nick), that personified the fact that copper-nickel ores resisted refinement into copper. Nickel's most important modern ore minerals are laterites, including limonite, garnierite, and pentlandite. Major production sites include Sudbury region in Canada (which is thought to be of meteoric origin), New Caledonia in the Pacific and Norilsk in Russia.
Because of nickel's slow rate of oxidation at room temperature, it is considered corrosion-resistant. Historically this has led to its use for plating metals such as iron and brass, to its use for chemical apparatus, and its use in certain alloys that will retain a high silvery polish, such as German silver. About 6% of world nickel production is still used for corrosion-resistant pure-nickel plating. Nickel was once a common component of coins, but has largely been replaced by cheaper iron for this purpose, especially since the metal has proven to be a skin allergen for some people.
Nickel is one of the four elements that are ferromagnetic around room temperature.Alnico permanent magnets based partly on nickel are of intermediate strength between iron-based permanent magnets and rare-earth magnets. The metal is chiefly valuable in the modern world for the alloys it forms; about 60% of world production is used in nickel-steels (particularly stainless steel). Other common alloys, as well as some new superalloys, make up most of the remainder of world nickel use, with chemical uses for nickel compounds consuming less than 3% of production.[4] As a compound, nickel has a number of niche chemical manufacturing uses, such as a catalyst for hydrogenation. Enzymes of some microorganisms and plants contain nickel as an active center, which makes the metal an essential nutrient for them.
There are rocking chairs made of rock, weighing thousands of pounds, but so delicately balanced that they move at the touch of a finger. Great crescents (Moon) top walls in the garden which rise to twenty feet in height; there is a 28.5 ton (HM 6 ) obelisk reaching for the sky. There is also a polaris telescope carved from coral rock, rising to twenty-five feet and weighing nearly thirty tons. There is a circular hole bored through it, near the top, within which are wires crossing at right angles. Several feet away is a lower stone with a similar hole and a similar “gun-sight”. By lining up the crossed wires in the lower stone with those in the obelisk, a direct sighting of the North Star is obtained.
Let us See what Maimonides had to say about these Talking Figures, in the twelfth century, in his Ethical Writings:
"The worshipers of the teraphim claimed that when the clarity of the stars
spread out on the statue,They saw as bein in relations with the Celestial Intelligences that were using the object as an instrument. Thus the teraphim taught the Hebrew people a lot of useful art and science
the author's comment:
Note that the gold teraphim were consecrated [actually "Tuned" so as "terrestrial" subspace, ie to instantaneous propagation 36] especially in a star or a planet determined.
now you understand why some of maimonide's books disappeared and why Gold is found close to Spiritual Gold close to mountains and Large Water BodiesPrinciple of Correspondence
He's considered to be one of the greatest scientists of all time. But Sir Isaac Newton was also an influential theologian who applied a scientific approach to the study of scripture, Hebrew and Jewish mysticism.
Now Israel's national library, an unlikely owner of a vast trove of Newton's writings, has digitized his theological collection-- some 7,500 pages in Newton's own handwriting --...
I recommend you listen to C2C am show on Cathie and Ufo...much to learn...for instance Edward Leedskalnin may have been in his past life an Atlantean Priest.....
the idea is to make it than wrap a caduceus coil around it and use the wimhurst to pass electricity trough the coil...tried it with the coil alone works well...you see it passing throught both ends
then will see what comes out ...the plants will tell
this is fun ............later for energy production
-----------------here is the model i have ....please note the design of the wheel, does it not remind you of a particular design
when you look at the facade of the Cathedral...it does kind of look like a "cousin" of a Wimhurst Machine
The Wimshurst influence machine is an electrostatic generator, a machine for generating high voltages developed between 1880 and 1883 by British inventor James Wimshurst (1832–1903).
It has a distinctive appearance with two large contra-rotating discs mounted in a vertical plane, two cross bars with metallic brushes, and a spark gap formed by two metal spheres.
Nicolas Poussin (pronounced: [ni.kɔ.lɑ pu.sɛ̃]; 15 June 1594 – 19 November 1665) was a French painter in the classical style. His work predominantly features clarity, logic, and order, and favors line over color. His work serves as an alternative to the dominant Baroque style of the 17th century. Until the 20th century he remained the major inspiration for such classically oriented artists as Jacques-Louis David, Jean-Auguste-Dominique Ingres and Paul Cézanne.
He spent most of his working life in Rome, except for a short period when Cardinal Richelieu ordered him back to France to serve as First Painter to the King.
forgot to add....if you watch the vid (beautiful song )...pay attention to the postal stamps
"Et in Arcadia ego" is a Latin phrase that most famously appears as the title of two paintings by Nicolas Poussin (1594–1665). They are pastoral paintings depicting idealized shepherds from classical antiquity, clustering around an austere tomb. The more famous second version of the subject, measuring 87 by 120 centimetres (34.25 x 47.24 in), is in the Louvre, Paris, and also goes under the name "Les bergers d'Arcadie" ("The Arcadian Shepherds").
The literal word-for-word translation of the phrase is "Even in Arcadia I (am there)," "I" being death, and "Arcadia" being understood as a utopian land. It is usually interpreted as a memento mori. In Greece, during Antiquity, Greeks lived in cities close to the sea, and led an urban life. Only Arcadians, in the middle of Peloponnese, lacked cities, were far from the sea, and led a shepherd life. For urban Greeks, especially during the Hellenistic era, Arcadia symbolized pure, rural, idyllic life, far from the city.
Poussin's own first version of the painting (now in Chatsworth House) was probably commissioned as a reworking of Guercino's version. It is in a far more Baroque style than the later version, characteristic of Poussin's early work. In the Chatsworth painting the shepherds are actively discovering the half-hidden and overgrown tomb, and are reading the inscription with curious expressions. The shepherdess, standing at the left, is posed in sexually suggestive fashion, very different from her austere counterpart in the later version. The later version has a far more geometric composition and the figures are much more contemplative. The mask-like face of the shepherdess conforms to the conventions of the Classical "Greek profile"
Poussin was thirty when he arrived in Rome. At first he lodged with Simon Vouet.[4] Through Marino, he had been introduced to Marcello Sacchetti who in turn introduced him to another of his early patrons, Cardinal Francesco Barberini. Financial difficulties arose with the departure to Spain of Barberini, accompanied by Cassiano dal Pozzo, the antiquarian and the Cardinal's secretary, who later would become a great friend and patron. However, their return from Spain in 1626 stabilized Poussin’s position, with renewed patronage by the Barberini and their circle
if you look closely at the painting , you'll see two cracks one is big (at the bottom ) and one is small (on top)...it could be interpreted as the Male /Female , Positive/ Negative poles....
