The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • from the Tractate:
    the Dragon inhabits in all these, and his houses are the darkness and blackness that is in them and by them he ascends into the air, from his rising (high frequency) , which is their heaven
    • did a little search on Thomas Townsend BROWN + "quartz"
      here is what i found ( KOWSKY & FROST Gravity Nullification )
      The Avalon Foundation :|: Research - Examination of Apparent Transient Weight Changes In Accelerated Chiral Crystals
      by Nicholas A. Reiter
      13 October 2002
      ABSTRACT: Previous experiments with optically active enantiomeric substances such as granular sucrose, corn syrup, and L-tartaric acid occasionally produced evidence for a surprising and unknown phenomenon. In samples weighing up to several tens of grams, milligram level temporary or transient alterations in the value of apparent weight were noted. These transient weight changes occurred following either mechanical agitation or directed electrical stressing of said substances. In this document, we continue characterizing this effect by careful examination of alpha quartz crystals and other chiral crystals following known mechanical translations and stresses. Relationships are found which include handedness of the crystal, crystal axes, direction of mechanical stressing, amplitude, and orientation with respect to the earth's surface. We conclude with a discussion of our characterization and possible useful candidate models invoking molecular level vorticity of physical space / aether, or interactions with the quantum vacuum
      The anomalous condition appears to be a temporary or transient alteration of the apparent weight (given the abbreviation TAW) of the chiral mass, following a specific period of mechanical excitation. We can say:
      TAW has been observed in single crystals of sucrose, L-tartaric acid, alpha quartz of both natural and cultured forms, and tourmaline. In no case has the absolute magnitude of TAW exceeded about 5 milligrams, for masses between a few grams and 85 grams. The period of time needed for the decay of the TAW appears to be on the order of five to ten minutes, and is still being studied. The TAW can appear as either a loss or a gain of apparent weight.
      The effect is influenced by unknown factors that appear to be related to prevailing weather conditions and specific times of the day or night.
      The most powerful stimulation of the TAW has occurred when the crystal is subjected to either reciprocating acceleration (shaking) or oscillation by an electromechanical vibrator.In these cases, the magnitude of the TAW seems proportional to, or at least dependent on, the power applied to the crystal as a function of the amplitude and frequency of oscillation.
      There appears to be a complex relationship between the axis of excitation / acceleration, the optical axis of the crystal, the handedness or chirality of the crystal and the orientation of said factors with respect to the earth's surface.
      TAW appears to be stimulated by centrifuging of crystals.
      Cursory evidence suggests that more powerful or dramatic changes in inertial properties of chiral crystals may be occurring under dynamic conditions.
      Application of high voltage potentials parallel to the optical axis of some chiral crystals may also induce a TAW condition, however on-going work is needed to eliminate Coulombic and ionic artifacts.
      • Principle of Correspondence to be applied here,
        from Thomas Townsend Brown: Scientific Notebook, Vol. 4
        The literature on the subject is extensive, but there is still some uncertainty as to the factors which affect the behavior of piezoelectric materials. In the following paragraphs, I shall point out some interesting observations which may (or may not) be related to gravitational radiation.
        (1) In the first place, these materials are truly massive high-K dielectrics. Barium titanate (see also hydro magnetic generator/Nazi Bell ) is one of the heaviest. Its dielectric constant, in some cases, is over 20,000! And it has very high electrical resistivity.
        (2) The polarization life is quite long, and for practical purposes virtually steady. Minimum decay.
        (3) It is an ideal material for intercepting gravitational radiation over a broad band, converting the energy of the gravitational radiation into an emf.
        (4) Each constituent dipole acts as a gravito-electric converter, resulting in an increase in dipole gradient and total charge.
        (5) The total charge of each dipole is additive along the alignment of dipoles so that total polarization (emf) is increased by the incident gravitic radiation.
        (6) Hence, there is a certain seeming parallel between piezo-electricity and gravito-electricity. (principle of polarization/principle of correspondence )
        In a gravitocell, gravitic radiation penetrates thoughout the volume of a polar material, causing one of the constituent poles to emit electrons which are energetically driven to the other pole, leaving the first pole positive and making the second pole more negative, thus increasing the polarization or total emf.
        see post http://www.energeticforum.com/152806-post113.html
        • (g) High dielectric constant (high-K) (ie: piezoelectric materials ) may serve several functions: (1) to slow up the incident graviton so as to facilitate capture; (2) to concentrate the generated emf, or, (3) to store energy.
          so Thomas Townsend Brown thought the same thing, 3d electromagnetic fractal construct/Electromagnetic Egg (think of a 3d spiderweb )
          see http://www.energeticforum.com/153242-post170.html
          Solid-state physics: Golden ratio seen in a magnet
          The golden ratio — an exact 'magic' number often claimed to be observed when taking ratios of distances in ancient and modern architecture, sculpture and painting — has been spotted in a magnetic compound. (principle of correspondence )
          Access : Solid-state physics: Golden ratio seen in a magnet : Nature
          see: http://www.energeticforum.com/153166-post426.html
            I think there are computer simulator software that could do the work for us to visualize what is going on and get the right frequencies
            papers on Simulating Microwave Oven:
            Simulation and Experimental Method for Microwave Oven
            http://www.intl-jest.com:88/index.ph...&archive_id=45
            3D Electromagnetic Field Simulation in Microwave Ovens:
            COMSOL Access - COMSOL
            great! I think we have a winner. I am now convinced fot the EM egg.
              that is pretty cool. And it seems that copper has similar effect on weightlesness when it comes to magnetic fields. If we find the right combination of materials and frequency we might be able to acheive an anti-gravtitational effect or if not we could definately find a way to make things 'lighter'.
              • glad you like the info...
                  If this is true then the correct EMF field at the right intensity could cause objects to be tripped of their gravity or weight, as it were. Is this the intent of the EM egg; to create such a field? If it is then
                  • I think i also have the solution to our Em Egg formation, and this is the clue
                    Tesla's egg rotating in magnetic field - YouTube
                      guess i should have read this post first. This is your intent and I sa let's go for it.
                        watch these two videos ...the one above mentioned, and the one below
                        Big vortex with big egg 271109 lars csr mpeg2video - YouTube
                        hint:
                        same link as below:
                        if you watch both videos...egg in a vortex, you'll notice that it respects the following statement
                        "as above so Below, from within so without "
                        now you know ....fractal construct
                        • from: The Avalon Foundation :|: Research - Examination of Apparent Transient Weight Changes In Accelerated Chiral Crystals
                          In July of 2002, we additionally found evidence for a weight alteration effect that appeared to manifest when a high voltage gradient was imposed on either left or right handed quartz, parallel to the optical axis. By applying potentials of up to 3kVDC to a pair of foil electrodes, one at the crystal point, the other at the base, we observed steady, voltage dependent weight changes of up to 5 milligrams. For right-handed crystals with point upwards, this typically manifested as a weight loss. Interestingly, the effect appeared to be independent of voltage polarity - orientation of the crystal axis, the electrical stress, and orientation of the electrical stress seemed to be the dominant factors.
                          • some info on Enhydro Quartz also know as Elestial/Skeleton Quartz :
                            Remember TT Brown
                            Skeletal quartz occurs in vugs or pockets in granitic pegmatites associated with the feldspar varieties microline and albite, and it is occasionally found together with some of the more rare pegmatite minerals such as lepdiolite & amblygonite. Skeletal quartz also occurs occasionally together with some of the rare pegmatite gem varietie such as aquamarine, kunzite, and toumaline.
                            Elestial Quartz (Skeletal Quartz): Factsheet & Information Page
                            How many different ways can SiO2 be organized into a neutral structure? That is what the Quartz Group is all about. It might amaze some to learn that there are no less than nine different ways of organizing SiO2, referred to as silicon dioxide or silica. An alternate name for the Quartz Group is the Silica Group. Silicon and oxygen are the two most common elements in the Earth's crust, so perhaps their diverse modes of organization are not so unexpected. But in reality it is simply a matter of the temperature and pressure, especially at the time of crystallization, that determines into which form silicon dioxide will organize. Those nine different forms of silicon dioxide are listed in the table below with a few of their different characteristics.
                            Above 1300 degrees and at a pressure of approximately 35 kilobars, only beta quartz (also known as high quartz) is stable. Beta quartz is not the same as normal quartz, actually referred to as alpha quartz, low quartz or, as is mostly done here, just quartz. Beta quartz has higher symmetry, is less dense and has a slightly lower specific gravity. The conversion, from one solid substance to another solid substance, of quartz to beta quartz is quick, reversible and accompanied with a slight energy absorption. The conversion in fact is so easily accomplished that a crystal of quartz heated to beta quartz, cooled back down, heated again to beta quartz, etc and the crystal when all is done, will be the same as when it started (here is the cycle, high frequency pulsed energy ).
                            Quartz Group
                            for the purpose of explaining the idea, i'll consider 1300 degree as the tipping point when Alpha Quartz become Beta Quartz.
                            so if you oscillate between 1300 degrees and 1299 degrees (still high frequency ), you have a cycle of alpha turning into Beta which according to the above text:
                            repeated over a rapid cycle, and slight becomes big (singing bowl )
                            The reason that the conversion is so easily accomplished is that the difference between quartz and beta quartz is relatively slight. The bonds between the oxygens and silicons are "kinked" or bent in quartz and are not so "kinked" in beta quartz. At the higher temperatures the atoms move away from each other just enough to allow the bonds to unkink or straighten and produce the higher symmetry. As the temperature is lowered, the atoms close in on each other and the bonds must kink in order to be stable and this lowers the symmetry back down again.
                            all quartz at temperatures lower than 573 degrees Celsius is low quartz or Alpha Quartz (so is Enhydro quartz)
                            now please read this post as complement of info: http://www.energeticforum.com/153804-post476.html
                            • In light of all the info, i posted , you could also view the Ankh differently
                              Ankh - Wikipedia, the free encyclopedia
                              The Ankh ( /æŋk/ or /ɑːŋk/; U+2625 ☥ or U+132F9 𓋹), also known as key of life, the key of the Nile or crux ansata, was the ancient Egyptian hieroglyphic character that read "eternal life",
                              "eternal life", according to the Kybalion the only entity that is eternal, is the All (principle of mentalism ), the divine source of energy that powers all in the universe ....
                              inspired by the last ancient alien episode:
                              Aliens and Mysterious Rituals
                                hint:
                                same link as below:
                                I think this as above so below describes the equal forces of pressure exherted by magnestism inside the center of the torroid. I like the whole egg idea but let me present another and tell you why I think its better. The egg did spin and stand up stood up because it had pressure exerted from one side. Remember the double coils and the plasma effect between them. I realized that in a crude way the spiral of the coils immitates the spinning torrus, just in a stanchionary way. and when you place two of them in approximation to the other it creates the as above so below torrus. If the coils are too far apart and out of symetry it is dangerous and causes spontaneous combustion of plasma and other strange effects. To explain. A torrus has two halves. Each side spinning in symetry but not separately. I truely beleive that each half is pushing toward the center and integrating much the same as two hands with interlacing fingers. Only it osscilates, interweaves and is spinning at the same time. One person tried to describe the movement of the energy through torrus as the effect of a black hole. I do not beleive this because if this were true then when you place a ball near the middle, it should suck it in from one side and shoot it out the other at an accelerated rate. But this did not happen. Instead a ball was trapped in the center of the torrus and that can only happen if the two conditions are met. Equal pressures from opposite directions and the EM field to inspire weightlessness. One coil only equals half the effect of the torrus and can not sustain the effect because the middle is plugged. Notice an acctiveted torrus, that was unplugged still caused the metal ball to spin when near it? SO what am I saying? The egg only spinned because the plate was on but once the plate is off the eggdrps down and stops. It would keep going even with the plate off: 1) if the plate had a hole in the center, to approximate the torrus effect and 2) if there were a second plate above at the right distance to complete the, as above so below effect, torrus effect. Keeping in mind that the second plate would also have to have a hole in the center. Technically the ball when placed under perfect pressure from both plates should rise up weightlessly and spin between the two plates in the center naturally. If you placed an egg in the center of this it would become off center and probably spin on its side and wobble. Remember that the pressure being exherted from one plate would be the equivalet of a spinning tornado or whirlpool. The pressures from both plates should create two magnetic whirlpools that would interlace much the same as the double sided coil. That coil once activated should pick up a neodymium ball and hold it in the center much the same as a torroid does because this coil is the physical representation of the forces created in the center of the torroid; two opposing electromagnetic whirlpools that are connected exactly as the double whirlpool coil. Of course for this effect to work you might have to play with the ammount of electricty being fed into the coil and maybe the distance between the coil springs.
