however the perfect shape should be a ball and not an egg so that the equal pressures can effect the object equally and spin it without the wobble. Place a neodymium in the center of a crytal ball. Think. It will be self resonate and if enough pressure is exerted on the neodymium it should pick up the entire ball and spin in a natural way. If this is placed in the middle of a torrus it should become trapped in an electromagnetic field which should technicaly keep the crystal charged at all times and shuold distribute the energy equally. Once the ball is centered and spinning simply unplug the electric torrus coil and the ball should remain spinning in the etheric field and picking up all the electromagnetic currents still being produced and hence becoming an endless battery. This is the answer we were all missing yet were so close to.
The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Originally posted by shawnnweed View Postnow is understand what you have been trying to say the whole time. It was like you walked me to this conclusion in baby steps so that i can see through your eyes. You are brilliant and I do not say this often, I truely mean it.
, Shawn
Thank you Shawn, but i did not do anything special, but offer you a seed of information and you allowed the tree of knowledge to grow inside you. If there is anyone to congratulate it is yourselffor seeing and willing to explore this universe with an open mind...now you have two methods....which one will choose to run with...I still have to grasp Hermes Tractate
Remember: the All is Mental , there isn't one way to Rome“Signs and symbols rule the world, not words nor laws.” -Confucius.
Description of the experiment
Tesla's 'Egg Of Columbus'
I've attached a photograph of the famed "Egg of Columbus" -- a rotating field experiment that was on exhibit at the World's Fair in 1893.
The Egg was created by Nikola Telsa and consisted of a complex polyphase field-coil located directly under a plate with a copper-plated egg positioned on top of it. When power was applied in sequence ( 3 6 9 )to the coils, the complex magnetic field arrangement not only inductively created a high-spin on the egg, it also made it stand up on end -- appearing to resist gravity.
rodin coil like set up under the table
all the great inventors and ancients alchemists knew the 7 principles enunciated in the Kybalion and if you look at the torus, they all apply
and now you are seeing it....
http://www.energeticforum.com/153245-post434.html
Last edited by MonsieurM; 08-28-2011, 01:02 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by shawnnweed View Posthowever the perfect shape should be a ball and not an egg so that the equal pressures can effect the object equally and spin it without the wobble. Place a neodymium in the center of a crytal ball. Think. It will be self resonate and if enough pressure is exerted on the neodymium it should pick up the entire ball and spin in a natural way. If this is placed in the middle of a torrus it should become trapped in an electromagnetic field which should technicaly keep the crystal charged at all times and shuold distribute the energy equally. Once the ball is centered and spinning simply unplug the electric torrus coil and the ball should remain spinning in the etheric field and picking up all the electromagnetic currents still being produced and hence becoming an endless battery. This is the answer we were all missing yet were so close to.)...
Principle of Correspondence:
Does a chicken lay round eggs?
Originally posted by shawnnweed View PostThis is the very epitamy of 'As above so below' and as 'within so without'. My final conclusion. As above so below represents the elctromagnetic force that is applicable due to the geometric shape of the torrus which is the as within so without becuase this shape annd force permeates and effects everything of every size from the micro the macro.
, Shawn
http://xenophilius.wordpress.com/200...-not-internal/
Earth’s Magnetic Field Is Produced By An External Dynamo System, Not An Internal Dynamo.
Researcher finds that Earth’s magnetic field is not produced by an internal dynamo. Nor is it produced by ocean current. The dynamo is outside the Planet! New findings by independent researcher, Dennis Brooks, show that Earth’s magnetic field and the planet itself are components of a complex dynamo system (fractal Engine), which surrounds the planet. The planet and its magnetic field are part of the dynamo.
food for thought: If the All is mental (ie: waves see: http://www.energeticforum.com/135748-post15.html and http://www.energeticforum.com/135680-post14.html ) so a chicken is a " complex polyphase field-coil/fractal antenna " laying a "complex polyphase field" egg.....( principle of mentalism/principle of correspondence )
Last edited by MonsieurM; 08-28-2011, 12:58 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
imagine the yolk is the Crystal Ball inside the copper egg of Tesla (maybe filled with water ) Replacing Tesla's Coils with Rodin Coil
Remember the Water properties
Originally posted by shawnnweed View Postthat is pretty cool. And it seems that copper has similar effect on weightlessness when it comes to magnetic fields. If we find the right combination of materials and frequency we might be able to achieve an anti-gravtitational effect or if not we could definately find a way to make things 'lighter'.
the best part, nature already provided us with the needed ratiosLast edited by MonsieurM; 08-28-2011, 01:31 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by MonsieurM View PostThis is one way of seeing it which i am in total agreement with, but let me ask this, I completely agree with the idea of a round neodymium, coupled with a crystal (quartz or ice etc)...
,Shawn
what happens inside the egg...with the quartz and neodymium and water encased in copper ...
you have as above and so below, how about from within
hint: the egg shape gives u imbalance, and excess energy has to come out from somewhereLast edited by MonsieurM; 08-28-2011, 02:03 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Please Compare the structure of an Egg with a Moe Joe Cell
from: http://www.energeticforum.com/149663-post200.html
for the moe joe cell replace the water with the quartz mix and let it grow inside (sounds familiar; hint: earth core )
or the egg version, biomimetics at work
A - Initially, the Moe-Joe cell was not conceived as a hydrogen producer. It was created because it concentrates orgone energy, which can be used for combustion in internal combustion engines and also for healing. However, since some people have thought of using it as a HHO producer, it has shown some considerable results.Last edited by MonsieurM; 08-29-2011, 01:17 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by MonsieurM View PostI just had a thought based on the previous posts and i think you might like it, it develops further on your thought of Placing a neodymium in the center of a Crystal ball
I would like your thoughts on this set up, i think this is almost it
Originally posted by shawnnweed View PostI think this a good setup. But it is only using one of the votices being emmited. If we dropped the plate then the egg would leviate in the center like in the video. Or we could use two a seperate setups facing each other; one pulling and the other pushing to rais the egg from the ground.
. If this is placed in the middle of a torus it should become trapped in an electromagnetic field which should technically keep the crystal charged at all times and should distribute the energy equally. Once the ball is centered and spinning simply unplug the electric torus coil and the ball should remain spinning in the etheric field and picking up all the electromagnetic currents still being produced and hence becoming an endless battery. This is the answer we were all missing yet were so close to.
no need for two coils, thanks to the excess energy coming out of the egg
why do i think it comes out of the bottom, where is the yolk naturally positioned
funny thing dawned on me: just thought of this, we end up with an egg inside a nest (fractal construct )Last edited by MonsieurM; 08-28-2011, 09:04 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
