ELECTROMAGNETIC WAVE DISTURBANCE PREVENTING MATERIAL
JP2004103783
2004-04-02
Inventor(s): SATO TSUNEO; SATO AKIHARU
Classification: - international: E04B1/92; H05K9/00; E04B1/92; H05K9/00; (IPC1-7): H05K9/00; E04B1/92
Abstract -- PROBLEM TO BE SOLVED: To provide an electromagnetic wave disturbance preventing material which keeps an residence environment and an office environment free from an electromagnetic wave disturbance by using this material as an internal material in an office and a residence or external materials for various kinds of electric products and electronic appliances. ; SOLUTION: The material is composed of an electromagnetic wave absorbing and extinguishing member 1 formed by coating an unwoven fabric, paper, etc. with an electromagnetic wave absorbing and extinguishing substance formed by mixing the fine powder of tourmaline and that of bamboo charcoal into a binding material by adhesion, a decoration panel member 2 which is secured to one surface of the electromagnetic wave absorbing and extinguishing member, and composed of paper, cloth, an wood plate, a synthetic resin plate, a synthetic resin sheet, etc.; an electromagnetic wave reflection member 3 which is secured to the other surface of the electromagnetic wave absorbing and extinguishing member, and composed of a metal plate such as an aluminum plate and a stainless plate.
Device for Saving Electrical Power
WO 2008/133438
Inventor: CHOI, Sung
Abstract -- A device for saving electric power of the present invnetion comprises a case; a tourmaline insert accomodated in the case body, which is a mixture of tourmaline powder, permanent magnet powder and moisture (H2O); ionization paltes respectively positioned on the upper and lower surfaces of the tourmaline intermediate layer interposed therebetween and a conductive plate embedded in the termaline intermediate layer.
WO 2008/156489
Wireless Electrical Charging System
Abstract -- An apapratus wirelessly recharges a recahrgeable battery. The apparatus includes a wireless receiver that anmplifies radio waves, the wireless receiveer comprising a tourmaline and zeolite ceramic. The recharging apparatus also includes a patch antenna that filters the received radio waves to usable RF signals. The rechargin apparatus further includes circuits that process the usable RF signals to create refined electric power for the rechargeable battery.
METHOD OF REMOVING SILICON CONTAINED IN WATER AND EQUIPMENT FOR THE SAME
JP2004141832
2004-05-20
Inventor(s): FUKAI TOSHIHARU
Classification: - international: C02F1/42; C02F1/60; C02F1/68; C02F1/42; C02F1/60; C02F1/68; (IPC1-7): C02F1/60; C02F1/42; C02F1/68
Abstract -- PROBLEM TO BE SOLVED: To provide a method for easily removing silicon contained in water in a short time without using electric power and an equipment for the same. ; SOLUTION: A water excluding hard water containing silicon is allowed to pass through a container 12 housing obsidian 10 to add active hydrogen to the water. Thereafter, the water which has passed through the above container 12 is allowed to pass through an aluminum cartridge 28 housing tourmaline 32 and a metal 34 therein. Thereby, the silicon contained in the water is separated from the water through adhesion to the inner wall of the aluminum cartridge 28.
COATED SEED
JP2005000036
2005-01-06
Inventor(s): INADA SHINICHI
Classification: - international: A01C1/06; A01C1/00; A01C1/06; A01C1/00; (IPC1-7): A01C1/06; A01C1/00
Abstract -- PROBLEM TO BE SOLVED: To provide a coated seed having an excellent germination performance. ; SOLUTION: This coated seed is characterized in that the coating contains one or more kinds of ore powder radiating far IR light, such as tourmaline ore powder. Such the functional mineral radiates growing far IR light having wavelengths of 4 to 14[mu]m, and thereby promotes the germination of the seed. Many natural minerals contained in the ore promote the growth of crops and reinforce the disease resistance of the crops. The tourmaline ore is a porous ore, and has an electric characteristic that continuously flows a weak electric current. Therefore, the weak electric current stimulates the hair roots of plants to promote their growth. Since containing boron, the tourmaline ore can promote the absorption of water from the hair roots to prevent the fertilizer scorch of the hair roots. Therefore, the coated seed having a high germination rate and an excellent germination performance is obtained.
Tourmaline: Animal and Plant Growth promotion composition
KR20040065199
2004-07-21
Inventor: LEE HAE WANG
Classification: - international: A23K1/16; A23K1/175; A23K1/16; A23K1/175; (IPC1-7): A23K1/16; A23K1/175
Abstract -- A composition for promoting animals and plants containing tourmaline, loess, a loess solution(jijangsu), kaoline and other minerals is provided. It promotes the growth of plants while preventing disease and insect pest of the plants. It also promotes the growth of animals and fishes when fed thereto. CONSTITUTION: The animal and plant growth promoting composition contains tourmaline, loess, a loess solution (jijangsu), kaoline and minerals. The tourmaline is prepared by agitating tourmaline in a solution containing sulfuric acid, nitric acid and oxalic acid, washing and drying in a natural state or at 100deg.C or less. The kaolin is prepared by heating kaolin for 20min at 400 to 500deg.C and grinding to 100 to 325 meshes. The loess solution is prepared by heating loess at 200 to 300deg.C, grinding to 150 to 325 meshes, mixing with purified water in a ratio of 1:20 and then agitating.
tourmaline
JP2004103783
2004-04-02
WO 2008/133438
WO 2008/156489
JP2004141832
2004-05-20
COATED SEED
JP2005000036
2005-01-06
KR20040065199
2004-07-21
tourmaline
