The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Additionally, because of the geometry of the way carbon works as the backbone of organic molecules, it is possible to create molecules that are right- or left-handed. This ability is called chirality. It should be noted that not all organic molecules are chiral: some can be symmetrical. The chiral molecule, however, has properties that are crucial to the working of the chemistry of life. As far as life on Earth is concerned, all normal chiral molecules associated with life processes are left-handed.
In terms of basic chemistry, left- and right- chiral molecules are identical, but their behavior can be vastly different. This is because the chemistry of life depends on the ability of molecules to form atomic bonds at several points simultaneously, to create new compounds. The molecules, however, are three-dimensional structures and to make the bonds work they must be turned round and fitted, much as a jigsaw puzzle would be put together. The consequence is that molecules must be the correct shape, in order to form the required bonding, as well as being chemically correct.
Players of the computer jigsaw puzzle game, Tetris, will appreciate the problem. Some pieces are handed - they are chiral - and however they are turned around and manipulated, they will not fit into the available slots. In fact Tetris would soon become incredibly and boringly easy, if the chiral pieces were not present.
So, in terms of bio-chemistry, you can see that it is impossible for the "wrong-handed" molecule to be used in a particular process, even if it is chemically correct. This characteristic of some organic molecules is key in the processes of life, particularly in replication, such as in the behavior of DNA.
Let us now return to the humble carbon atom and think about its role when considering life elsewhere, off planet Earth. The unique characteristics of carbon give it a versatility and functionality like no other atom in the periodic table. These are why carbon is the basis of life here. Additionally, carbon is only beaten in abundance by hydrogen, helium and oxygen, at least within the Solar System. It is ten times more abundant than silicon and a million times more abundant than boron, which have also been suggested as alternative base elements for living molecules.
P73
The Dwellings of the Philosophers
by Fulcanelli
As for us, our conviction is firm; we are
certain not to be mistaken in front of so many categorical assertions: we indeed have before
our eyes a baphomet, renewed from the one of the Templars. This image, about which we
possess but vague indications or simple hypotheses, never was an idol, as some believed, but
rather a complete emblem of the secret traditions of the Order, especially used outwardly as
an esoteric paradigm, a seal of chivalry, and a sign of recognition. It was composed of an
isosceles triangle, its apex pointed down, hieroglyph for water, first created element,
according to Thales of Miletus, who maintained that "God is the Spirit which has formed all
things from water" (similar to Vedic Science ) (1). A second similar triangle, inverted in relationship to the first, but
smaller, was inscribed in its center and seemed to occupy the position reserved for the nose on
the human face. It symbolized fire and more precisely, fireenclosed in water, or the divine
spark, soul incarnate, life infused in matter. ( a unity device ) On the inverted base of the large triangle of water,
there was a graphic sign similar to the Latin letter H or Greek [*158-1] (eta), but wider whose
central bar was cut with a median circle. This sign in hermetic steganographiy indicates the
universal Spirit, the Creative Spirit, God. Inside the large triangle, slightly above and on each
side of the triangle of fire, one could see on the left the lunar circle with an inscribed crescent
and on the right the solar circle with a visible center. These small circles were arranged in the
manner of eyes. Finally, welded to the base of the small inner triangle, the cross, placed on the
globe, thus realized the double hieroglyph of sulphur, active principle, associated to mercury,
passive principle and solvent of all metals. A longer or shorter segment often located at the
apex of the triangle was carved with lines of a vertical tendency where the layman could
recognize not the expression of luminous radiation but a sort of goatee.
“Signs and symbols rule the world, not words nor laws.” -Confucius.
(Phys.org) -- Scientists from Stanford's Department of Bioengineering have devised a method for repeatedly encoding, storing and erasing digital data within the DNA of living cells.
Under ultraviolet light, petri dishes containing cells glow red or green depending upon the orientation of a specific section of genetic code inside the cells' DNA . The section of DNA can be flipped back and forth using the RAD technique. (Norbert von der Groeben)
Researchers at The University of Texas at Austin and Washington State University have seen an increased reaction to stress in animals whose ancestors were exposed to an environmental compound generations earlier. The findings, published in the latest Proceedings of the National Academy of Sciences, put a new twist on the notions of nature and nurture, with broad implications for how certain behavioral tendencies might be inherited.
(Phys.org) -- The discovery of planets around other stars has led to the realization that alien solar systems often have bizarre features - at least they seem bizarre to us because they were so unexpected. For example, many systems have giant planets closer to their star than Mercury is to the Sun, while other have the opposite - giant planets more than ten times farther way from their star than Jupiter is from our Sun. Astronomers think they understand how planets could end up close to the star: they gradually drift in from more customary orbits. But how can planets end up so far away?
Dancing droplets reveal physics at work
by Science News 5 days 3 hours ago
An oxygen droplet floating on its vapor (approaching from left at 12 centimeters per second) can be deflected by a small magnet (moving from bottom center at 7 centimeters per second) held beneath a sheet of glass. Such movies reveal the elusive behavior of droplets subject to what’s known as the Leidenfrost effect.
can't believe it skipped my mind the experiment with the drill Scalar Faraday Disc & Magnetic Spin - YouTube
.... is close to a Tesla Turbine .... remember the post on the stacked battery + Tesla Turbine ..... just thought of it
(Phys.org) -- The laws of classical electromagnetism that were developed in the 19th century are the same laws that scientists use today. They include Maxwell’s four equations along with the Lorentz law, which describes the force exerted by electric and magnetic fields on charged particles. But Masud Mansuripur, a professor of Optical Sciences at The University of Arizona in Tucson, is now arguing that the Lorentz law of force is incompatible with special relativity and momentum conservation, and should be abandoned. In a recent issue of Physical Review Letters, he has suggested replacing the Lorentz law with a more general expression of electromagnetic force density, such as one developed by Albert Einstein and Jakob Laub in 1908.
For instance, the inner dimensions of the chapel form a double square measuring 36 by 72 feet with a diagonal distance of 80.5 feet that is proportional to the square root of five. Since the famous golden ratio constant is derived from the square root of five and every orbital intersection of the Venus rose-line creates a golden ratio, the chapel seems built to harmonize with Venus. Add to this the fact that the choir loft height of 44.5 feet forms another golden ratio to the total interior length (as 72’ / 44.5’ = 1.618) and it seems hard not to conclude the Lady Chapel was built as a temple to Venus.
Acoustically speaking ( probably also electromagnetically speaking too ) , these dimensionsmake Rosslyn chapel a natural resonance chamber that propagates sound evenly while suppressing reverb and echo. It does this because of the damping effect of the golden ratio, long used in the design of “anechoic” musical instruments, auditoriums, recording studios and speaker enclosures. As an ideal acoustical damping enclosure, Rosslyn reflects the same damping effect Venus had on Earth during the harmonic formation of the solar system.
a Harmonic Cascade Effect
COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways. a harmonic cascade effect
The Fibonacci sequence appears in Indian mathematics, in connection with Sanskrit prosody.[4][9] In the Sanskrit oral tradition, there was much emphasis on how long (L) syllables mix with the short (S), and counting the different patterns of L and S within a given fixed length results in the Fibonacci numbers; the number of patterns that are m short syllables long is the Fibonacci number Fm + 1.[5]
Susantha Goonatilake writes that the development of the Fibonacci sequence "is attributed in part to Pingala (200 BC), later being associated with Virahanka (c. 700 AD), Gopāla (c. 1135), and Hemachandra (c. 1150)".[3] Parmanand Singh cites Pingala's cryptic formula misrau cha ("the two are mixed") and cites scholars who interpret it in context as saying that the cases for m beats (Fm+1) is obtained by adding a [S] to Fm cases and [L] to the Fm−1 cases. He dates Pingala before 450 BCE.[10]
However, the clearest exposition of the series arises in the work of Virahanka (c. 700 AD), whose own work is lost, but is available in a quotation by Gopala (c. 1135):
Variations of two earlier meters [is the variation]... For example, for [a meter of length] four, variations of meters of two [and] three being mixed, five happens. [works out examples 8, 13, 21]... In this way, the process should be followed in all mAtrA-vr.ttas (prosodic combinations).[11]
The series is also discussed by Gopala (before 1135 AD) and by the Jain scholar Hemachandra (c. 1150).
In the West, the Fibonacci sequence first appears in the book Liber Abaci (1202) by Leonardo of Pisa, known as Fibonacci.[2] Fibonacci considers the growth of an idealized (biologically unrealistic) rabbit population, assuming that: a newly born pair of rabbits, one male, one female, are put in a field; rabbits are able to mate at the age of one month so that at the end of its second month a female can produce another pair of rabbits; rabbits never die and a mating pair always produces one new pair (one male, one female) every month from the second month on. The puzzle that Fibonacci posed was: how many pairs will there be in one year?
At the end of the first month, they mate, but there is still only 1 pair.
At the end of the second month the female produces a new pair, so now there are 2 pairs of rabbits in the field.
At the end of the third month, the original female produces a second pair, making 3 pairs in all in the field.
At the end of the fourth month, the original female has produced yet another new pair, the female born two months ago produces her first pair also, making 5 pairs.
At the end of the nth month, the number of pairs of rabbits is equal to the number of new pairs (which is the number of pairs in month n − 2) plus the number of pairs alive last month (n − 1). This is the nth Fibonacci number.[12]
The name "Fibonacci sequence" was first used by the 19th-century number theorist Édouard Lucas.[13]
0 1 1 2 3 5 8 13 21 34 55 89 144 233 377 610
do you think we could come up with a new hidden meaning by just following Nature applied to sacred Books / Poems / alchemical treaties
In nature
Fibonacci sequences appear in biological settings,[6] in two consecutive Fibonacci numbers, such as branching in trees, arrangement of leaves on a stem, the fruitlets of a pineapple,[7] the flowering of artichoke, an uncurling fern and the arrangement of a pine cone.[8] In addition, numerous poorly substantiated claims of Fibonacci numbers or golden sections in nature are found in popular sources, e.g., relating to the breeding of rabbits, the seeds on a sunflower, the spirals of shells, and the curve of waves.[49] The Fibonacci numbers are also found in the family tree of honeybees.
The storage of light-encoded messages on film and compact disks and as holograms is ubiquitous---grocery scanners, Netflix disks, credit-card images are just a few examples. And now light signals can be stored as patterns in a room-temperature vapor of atoms. Scientists at the Joint Quantum Institute have stored not one but two letters of the alphabet in a tiny cell filled with rubidium (Rb) atoms which are tailored to absorb and later re-emit messages on demand. This is the first time two images have simultaneously been reliably stored in a non-solid medium and then played back.
Invisibility, once the subject of magic or legend, is slowly becoming reality. Over the past five years mathematicians and other scientists have been working on devices that enable invisibility cloaks – perhaps not yet concealing Harry Potter, but at least shielding small objects from detection by microwaves or sound waves.
The remains of the world's oldest musical instruments and human figurines suggest that music and artistic depictions of the human form may have first developed in Germany around 40,000 years ago, say researchers.
