The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Dividing 1 by 1/3 and 2/3 leaves 1/1 which is the 9 (this is a really weird part that is hard to understand. but it defines the polarity(duality) while treating each piece as a whole)
Its like the flow is always broken into a specific number of flows three defining one side, six defining the other. Each individual flow being treated a whole number as it is a different whole flow.
1/1 = 1 (9 is likely used to notate that it occured after the division, or signifies a looping back to the original one)
1/3 = 3
2/3 = 6
the 3 and 6 are the duality, the inverted equal opposites.
My apologies ...... but could you go into further details on the above quote as ... I am having a hard time picturing it .... the rest I got it and makes sense
Signs and symbols rule the world, not words nor laws. -Confucius.
I would like to but time is short. A better description will likely come to mind during today and will post it this evening. But it appears like addition, division and multiplication are happening at the same time. Really weird.
The shortage of time early caused a very lack luster description of what became clear to me after working with the harmonics of the Solfeggio. With luck this will do a much better job.
The conclusion below is reached from the reference to 3, 6 and 9 by both Rodin and Tesla.
In relation to the phrase:
One becomes Two becomes Three
Tree Analogy
consists of trunk, branch, primary-branch and secondary-branch etc.
one = trunk
two(a) = primary branch
two(b) = primary branch
three(a) = two(a)
three(b) = two(b)
three(c) = the portion of two(a) & two(b) that both two(a) and two(b) use to connect with one.
Rodin Analogy
one = 0(zero) central starburst
two(a) = 3
two(b) = 6
three(a) = two(a)
three(b) = two(b)
three(c) = 9; the portion of two(a) & two(b) that both two(a) and two(b) use to connect with one.
One
In the phrase mentioned above, the word 'One' is the point from which vibration arises, instead of the number 1 it could be considered 0(zero) in reference to sine waves.
A vibration requires connection to the point from where it arose to maintain its existence.
Two
Is not the number 2 but an indication of two parts.
The 'One' is not able to be completely divided into two parts. This does not allow a connection to exist from which it arose, the 'One'.
So complete equal division of parts is not possible.
Tesla and Rodin provide the numbers 3, 6 and 9. (these I believe are harmonic ratios that are probably based in pythagorean math)
Rodin shows that the 3 and 6 represent the oscillating duality. (origin/cause of rotation)
3 and 6 are our 'Two'.
Three
This leave a single number remaining, 9.
This is the connection for both 3 and 6 back to the 'One'.
9 also hints at being a limiter to the extent that 3 and 6 can oscillate from thier point of origin.
From my perception this describes the birth of a fractal and the branches that arise from it after.
Does it sound correct?
- Ben Rich, the Father of the Stealth Fighter-Bomber and former head of Lockheed Skunk Works
When Rich was asked how UFO propulsion worked, he said, Let me ask you. How does ESP work? The questioner responded with, All points in time and space are connected? Rich then said, Thats how it works!
What do you think is connection in this statement "All points in time and space are connected?"....Water
water has memory, quantum water has been proven to exist, the fact that for every fractal structure present in nature you'll find the presence of water etc...
Part 01 - General View
Part 02 - Origin of Polar States Part 03 - Polarity Manifests as Rotating Vortex
Part 04 - Rotation on Three Planes
Part 05 - Three Rotating Planes Become Spheres Part 06 - Formation of Cubes Part 07 - Origin and Formation of Matter Part 7B - Formation of Matter
Part 08 - Sympathetic Streams and 3-D Matter Part 09 - What Vibration Is. Part 1 & Part 2
Part 10 - What Sympathy Is
Part 11 - SVP Music Model Part 12 - Russell's Locked Potentials Part 13 - Rotation from Vibration/Oscillation
Part 14 - Keely's Mysterious Thirds, Sixths and Ninths Part 15 - Dissociating Water Acoustically
Part 16 - Electricity and Magnetism
Part 17 - Gravity Part 18 - Mind, an Engineerable Force
Part 19 - Musical Dynasphere, Historical
Part 20 - Musical Dynasphere, Current Development Part 21 - Pantone's GEET Reactor Dynamics
3.4 - Power Accumulation - Each of the lines represents a center line or line of attraction around which will aggregate the particles. The lines centralize together meaning proportional increase of attraction as they approximate each other. Which results in greater attraction in the center and less attraction at the periphery.
Leon Sprink was a Russian engineer who operated a cement manufacturing plant in France circa 1950. He received several patents for a simple method to create a type of electric field that accelerates chemical reactions.
In one example given by Sprink, One month after the setting in operation of the apparatus, the duration of the reaction, which normally is 24 hours, had fallen down to 3 hours and the saving in calories to be supplied for the reaction was 50% The field also affects the states of matter such as solubility and crystallization, distillation, reduction of metallic ores, etc..."
In the simplest form of the invention, Sprink used a grounded container placed in an electrostatic field. More control and power was obtained with geometric arrays of positive electrodes mounted diagonally from grounded electrodes.
The form (e.g., a cube) was mounted upright and aligned East-West. 1000 to 5000 KV of positive charge (per meter of electrode separation) was applied for two weeks or longer to establish a zone of activation, spreading up to 60 meters :
The revisit to SVP has lit my mind on fire.
My understanding of ether/aether was inverted.
As well as the elements... yeah the elements was the duh! moment.
Annnnnd, why it is a potential spike that does the trick.
and it's still clicking away...
Sir Oliver Lodge once said that the physicist's type of mind could never fathom the mystery of the universe, and the great story, if it ever came at all, must be "the great inspiration of some poet, painter, philosopher or saint."
Walter Russell - The Universal One
"Through keenly developed intuition, everything can be known."
The Myth Of Invariance, (The Origin of the Gods, Mathematics, and Music From The Rg Veda to Plato) by Ernest G. McClain, on pg. 69, refers to the Vedic reference to "the Thirty-Three Gods," and suggests that this refers to music, representing a system of intervals shown in a diagram [Chart 13] entitled, "Mandala of the 33 Gods in 60 degrees." (pg. 67)
Harmonical analysis is a technique for synthesizing the tonal, arithmetical, and
geometrical imagery of ancient civilizations. It aims at the reconstruction of the
esoteric diagrams which gave the sacred symbols of particular cultures their
enduring and magical powers and furnished philosophy with a ground of
certainty. The technique is applicable to all cultures which considered tone and
number twin keys to the secrets of the universe, and practicable wherever a
sufficient mythology and cosmology have survived. I have made explicit the
objective elements of that harmonic technique ; it is based on the habits of
ancients like Plato, Plutarch, Ptolemy, and Nicomachus, and on principles
enunciated anew in our time by men like Brumbaugh, de Nicolαs, Levarie, and
Levy. There is in addition to those elements the personal interpretation which I
have proposed in this book : such an interpretation is tested by the intuitions of
others and by its fertility in suggesting further interesting integrations. The
musical imagination required to employ the technique of harmonica) analysis in
uncovering ancient meanings encoded in music, number, poetry, and metaphor
will not lead to certainty, but used wisely it should lead to a likely story, one
more likely than interpretations that have been musically uninformed.
For Antonio de Nicolαs the great lesson of the Ṛg Veda and perhaps of the
whole Indian tradition is centered on the Ṛta, Body of Law (from the root ṛ
, to go, meaning that which has already been gone through, that which has
already been formed), the guide for action of all that can be formed, and a
norm.5
The Ṛta, as . . . the accumulations of practices, customs, goals, and rules of survival
for a community within which individuals are born and foreigners accepted . . . is
the body of the social group, or the embodied community.6 (Emphasis added.)
Ṛta is the world created by the sacrifice of all limiting and partial perspectives,
a ceaseless activity whose rationality is protected by respect for plural norms.
Its fruit is the Embodied Vision (Ṛta dhīḥ) which Western philosophical
rationality cannot dissect successfully. Its radiant musicality resonates
powerfully in all the great religions of the world. We in the West are capable of
feeling these resonances because our souls have finally been emptied of the
belief, that for a long time constrained the Western imagination, that one and
only one path can lead to truth
side note :
3 6 9 is also 3 3 3 9 / 3 6 6 3 / 3 3 3 3 3 3 ( 3 different perspectives )
James Clerk Maxwell of Glenlair[1] FRS FRSE (13 June 1831 5 November 1879) was a Scottish[2] physicist and mathematician. His most prominent achievement was formulating classical electromagnetic theory. This unites all previously unrelated observations, experiments, and equations of electricity, magnetism, and optics into a consistent theory.[3] Maxwell's equations demonstrate that electricity, magnetism and light are all manifestations of the same phenomenon, namely the electromagnetic field. Subsequently, all other classic laws or equations of these disciplines became simplified cases of Maxwell's equations. Maxwell's achievements concerning electromagnetism have been called the "second great unification in physics",[4] after the first one realised by Isaac Newton.
Maxwell demonstrated that electric and magnetic fields travel through space in the form of waves and at the constant speed of light. In 1865, Maxwell published A Dynamical Theory of the Electromagnetic Field. It was with this that he first proposed that light was in fact undulations in the same medium that is the cause of electric and magnetic phenomena.[5] His work in producing a unified model of electromagnetism is one of the greatest advances in physics.
Maxwell also helped develop the MaxwellBoltzmann distribution, which is a statistical means of describing aspects of the kinetic theory of gases. These two discoveries helped usher in the era of modern physics, laying the foundation for such fields as special relativity and quantum mechanics.
Maxwell is also known for presenting the first durable colour photograph in 1861 and for his foundational work on the rigidity of rod-and-joint frameworks like those in many bridges.
Maxwell is considered by many physicists to be the 19th-century scientist having the greatest influence on 20th-century physics. His contributions to the science are considered by many to be of the same magnitude as those of Isaac Newton and Albert Einstein.[6] In the millennium polla survey of the 100 most prominent physicistsMaxwell was voted the third greatest physicist of all time, behind only Newton and Einstein.[7] On the centennial of Maxwell's birthday, Einstein himself described Maxwell's work as the "most profound and the most fruitful that physics has experienced since the time of Newton."[8] Einstein kept a photograph of Maxwell on his study wall, alongside pictures of Michael Faraday and Newton.[9]
now let's have a look at his writings .... you maybe surprised :
Publications
"On the description of oval curves, and those having a plurality of foci". Proceedings of the Royal Society of Edinburgh, 2 (1846). "Are There Real Analogies in Nature?" (February 1856)
Illustrations of the Dynamical Theory of Gases. 1860.
On the Theory of Compound Colours, and the Relations of the Colours of the Spectrum. 1860.
"On physical lines of force". 1861.
"A dynamical theory of the electromagnetic field". 1865.
"On governors". Proceedings of the Royal Society, 16 (18671868) pp. 270283.
Theory of Heat. 1871.
"On the Focal Lines of a Refracted Pencil". Proceedings of the London Mathematical Society s1-4(1):337343, 1871.
A Treatise on Electricity and Magnetism. Clarendon Press, Oxford. 1873.
"Molecules". Nature, 8(204) (25 September 1873) pp. 43741.
"On Hamilton's characteristic function for a narrow beam of light". Proceedings of the London Mathematical Society s1-6(1):182190, 1874.
Matter and Motion, 1876.
"On Stresses in Rarefied Gases Arising from Inequalities of Temperature". Philosophical Transactions of the Royal Society of London, 170 (1879), pp. 231256
On the Results of Bernoulli's Theory of Gases as Applied to their Internal Friction, their Diffusion, and their Conductivity for Heat. "Ether", Encyclopζdia Britannica, Ninth Edition (187589).
An Elementary Treatise on Electricity Clarendon Press, Oxford. 1881, 1888.
Below is list the whole number sub-harmonics of the Hydrogen line ( Hydrogen line - Wikipedia, the free encyclopedia ) 1420405750 Hz. The program I wrote only calculated out to the 300 millionth sub-harmonic. Excel 2k3 for some 'weird' reason doesn't allow 300 million rows.
The sub-harmonic index number is noted with a '-' preceeding it. The last whole number sub-harmonic calculated is the 284,081,150th sub-harmonic of 5 Hz. It would be a good bet that 1 hz would be the next/last one.
Note the inversion just past the mid point and the decrease/increase in distance between the whole numbers.
Just a wild guess but hydrogen appears to be the first duality on this scale. If there are others that arise before, they probably disperse the instant they arise.
I WILL arise and go now, and go to Innisfree,
And a small cabin build there, of clay and wattles made:
Nine bean-rows will I have there, a hive for the honey-bee,
And live alone in the bee-loud glade.
And I shall have some peace there, for peace comes dropping slow,
Dropping from the veils of the morning to where the cricket sings;
There midnight's all a glimmer, and noon a purple glow,
And evening full of the linnet's wings.
I will arise and go now, for always night and day
I hear lake water lapping with low sounds by the shore;
While I stand on the roadway, or on the pavements grey,
I hear it in the deep heart's core.
6:4 - line 1
6:5 - line 2
6:5 - line 3
7 - line 4
7:5 - line 5
12 - line 6
5:5 - line 7
7 - line 8
6:5 - line 9
11 - line 10
6:5 - line 11
8 - line 12
: and ; being the indicator that hints at ratios.
Ratios based on word count between commas.
Commas were replaced with ':' as well.
3 - Stanzas
9 - Being the only number mentioned
6 - Predominant number starting each line when the three Stanza are seen as ratios
There was definitely much more time for uninterrupted contemplation back when it was written. Ahhh, the true purpose of temples past.
6:4 - line 1
6:5 - line 2 6:5 - line 3
7 - line 4
7:5 - line 5 12 - line 6
5:5 - line 7
7 - line 8
6:5 - line 9
11 - line 10
6:5 - line 11 8 - line 12
3 - Stanzas
Amazing Poem ...... Beautiful New Perspective you have Discovered Llynch .... Much Gratitude ... for you have opened a new playground to play with ..... keep on rolling fellow Telestai
you realize we can do the same with all the other Sacred Writings Bible / Koran / Torah / Mahabharata etc .... Principle of Correspondence
This list came about from a question I posed to myself Monday. "What is the connection to nature in regards to the days of the month, and for the months themselves?".
So the first thing was to removed the twice removed conflict of months and days of the month. We have days and nights. So it seems natural for one of each to count as 1 day. A good starting point to count would be the one we have defined January 1st. So I called that 1. Each day from that point increments by one until 365.
The next thing that came to mind was placing the holidays on this numerical list. What I found was that December 25th falls on Day 360. The number of degrees in a circle.
Hmmm, that would mean we have a 5 day variance. I would attribute this to a slightly oval orbit.
With New Years Day defined as the number 1, the most curious holday for the U.S. is July 4th. It falls on Day 184 (fuzzy recall, may be off by a day or so).
July 4th is very close to the center line of 180 degrees of a circle. Kind of interesting to place a holiday relating to freedom when crossing the zero line.
So to validate this, I found a list of international holidays. Other that what is obvious is the not so obvious of some countries define a holiday as being so many days after a previous one and that one being 'x' number of days before another.
What I have taken from this lesson is that if viewed from a historical perspective, the trend appears to be towards organizing structure on our planet to match a much larger pattern.
