The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Thank you Ruphus and thank you for reading the posts
Tesla's magazine Articles are a mine of info , it should be noted that in some cases where the articles are not to Tesla's liking , he does not hesitate to write letters to correct it ex : Correction By Mr. Tesla from New York Times, October 4th, 1915
so in other words he read the articles written about him ( not all ... certainly those published in New York )
when you look at the Turbine , the Electrolytic Clock , and the Rotating Machine ( see Asymmetric Machine thread ) / Resonant Coil ... you realize that the shapes are one and the same .... Armature / Rotation / Fluid
The coil resting on three legs and observed in the immediate foreground is the primary of a Resonant Tesla transformer which collected energy from an oscillatory circuit encircling the laboratory, no matter in what position the transformer was placed
an oscillator / Capacitor within an Oscillator / Capacitor
Most generally I employed receiving circuits
in the form of loops, including condensers, because the discharges of my high-tension transmitter
ionized the air in the hall ( which is encircled by an oscillatory circuit ... most probably ) so that even a very small aerial would draw electricity from the
surrounding atmosphere for hours
The loop form of receiver was not sensitive to such a disturbance
and it is curious to note that it is becoming popular at this late date. In reality it collects much less
energy than the aerials or a long grounded wire,
you can even interchange the parts ( think going Voltron on these Three Inventions : "combining-robot" cartoon )
The Telegraphone (pronounced with the emphasis on the second syllable) was the first device capable of recording sound magnetically, and it did so on a thin steel wire; Poulsen and others called it piano wire, and it was apparently a single strand of commercially available wire made of ordinary steel. His very first machine, intended only to demonstrate the concept, employed a relatively short length of wire, wrapped around a metal cylinder, which was hand-cranked. This avoided the need to design a functional wire-transport system. Within a short time, Poulsen also demonstrated a steel "ribbon" or tape recorder and then a machine to record magnetically on a steel disk. All three types were promoted as alternatives to phonograph-type dictating machines, such as the recently introduced phonograph and graphophone (in the 1880s these were still sold mainly for dictation). Poulsen saw as the chief advantage of the Telegraphone its ability to record directly from the telephone lines, which the phonograph could not do. Such a machine might, for example, provide a sort of remote dictation capability. It was a humble beginning for a technology that would eventually replace its rival, the phonograph, and become amazingly common today.
The Telegraphone generated a lot of excitement and was hailed as a scientific breakthrough (the recording process seemed to contradict contemporary theories of magnets). As a commercial product, the history of the Telegraphone was less than successful. It was manufactured in at least two versions, one by Poulsen's workers in Denmark, and another by the American Telegraphone Company of Wheeling, West Virginia and later Springfield, Massachusetts.
I have read with great interest the report in your issue of to-day that the Danish engineer, Waldemar Poulson, the inventor of the interesting device known as the “telegraphone,” has succeeded in transmitting accurately wireless telephonic messages over a distance of 240 miles.
I have looked up the description of the apparatus he has employed in the experiment and find that it comprises:
(1) My grounded resonant transmitting circuit;
(2) my inductive exciter;
(3) the so-called “Tesla transformer”;
(4) my inductive coils for raising the tension on the condenser;
(5) my entire apparatus for producing undamped or continuous oscillations;
(6) my concatenated tuned transforming circuits;
(7) my grounded resonant receiving transformer;
(8) my secondary receiving transformer.
I note other improvements of mine, but those mentioned will be sufficient to show that Denmark is a land of easy invention.
The claim that transatlantic wireless telephone service will soon be established by these means is a modest one. To my system distance has absolutely no significance. My own wireless plant will transmit speech across the Pacific with the same precision and accuracy as across the table.
Briefly explained, the Tesla theory is that a wireless tower, such as that here illustrated and specially constructed to have a high capacity, acts as a huge electric condenser
The transmitting station is an octagonal tower, pyramidal in shape, and some 180 feet in height. It consists of huge wooden stilts, heavily braced, and reinforced, and surmounted by a cupola of interlaced steel wires, bent so as to form an arc. In the cupola there is a wooden platform occupying its entire width.
“It is true,” said Mr. Tesla, “that some of them have had to do with wireless telegraphy and that in addition to the tower and poles there is a hole dug in the ground. This is 150 feet deep and is used in these experiments.
Capacity of Electrical Conductors is Variable. Not Constant, and Formulas Will Have to Be Rewritten — Capacity Varies With Absolute Height Above Sea Level, Relative Height From Earth and Distance From the Sun.
Sir: Your issue of the 14th inst. contains a report relative to an experimental demonstration at the Pittsfield plant of the General Electric Company in which a pressure of one million volts was used for transmission of power by alternating currents. This is said to be the result of more than thirty years’ work and to constitute a dramatic advance in electrical development so much, indeed, that it was deemed proper to record the time of its consummation with greater precision than that when Joshua commanded the sun to stand still over Gibeon and the moon in the Valley of Ajalon. But the prosaic fact is that I have long ago perfected and patented the invention instrumental in this achievement and applied it successfully in the production of pressures amounting to many millions of volts. It may not be amiss to state furthermore that a license was offered to the General Electric Company under my basic patent which bears the No. 1,119,732 and was granted December 1, 1914, the original application having been filed January 16, 1902.
.... An idea of the underlying principle of the invention and its practical significance may be conveyed by an analogue. Alternating currents transmitted through a wire can be likened to pulses of some liquid, as water, forced through a woven hose So long as the pressure is moderate the fluid entering one end will be integrally discharged at the other, but if the pressure is increased beyond a certain critical value the hose will leak and a large portion of the fluid may thus be wasted. Similarly in electric transmission, when the voltage becomes excessive the prison walls of the dielectric yield and the charge escapes ( see also : http://www.energeticforum.com/renewa...ystem-106.html )
The beauty of Tesla's writings .... the simplicity by which you can envision his Discoveries
He does not go into technical Wordings .... it is not the purpose ... Truth is to be found in simplicity
Many "Free Energy" Researchers tend to forget that ... the reason is simple ... formated by an industrial Education System ... and the need for recognition by "scientific peers" .... Ego
As a Famous Dowser once said : ( paraphrasing )
It works and i don't care about the Math
The trouble with Nikola Tesla is that he lives a century ahead of his time. He has often been denounced as a dreamer even by well informed men. He has been called crazy by others who ought to know better. For Tesla talks in a language that most of us do not as yet understand. But as the years roll on Science more and more appreciates his greatness, and begins to pay him tribute more and more
a word Tesla uses often : ( in the presentation also )
“In the propulsion of aerial vessels problems are involved entirely different from those presented in the navigation of the water,” said Tesla. “The atmosphere may be likened to a vast ocean, but if one imagines a submarine vessel constructed like an aeroplane one immediately realizes how inefficient it would be. The energy used in propelling a body through a medium of any kind is wasted in three different ways; first, by skin friction; second, wave making; third, production of eddies. On general principles, however, the resistance can be divided into two parts: one which is due to the friction of the medium and the other to its stickiness, or viscosity, as it is termed. The first is proportionate to the density; the second to this peculiar property of the fluid.
“Everybody will readily understand that the denser the medium the harder it is to push a body through it, but it might not be clear to every person what this other resistance — this viscosity — means. This will be understood if we compare, for instance, water and oil. The latter is lighter, but much more sticky, so that it is a greater obstacle to propulsion than water. Air is a very viscous substance and that part of resistance which is due to this quality is considerable ( see dielectric ) . We must take this latter resistance into account in calculating how fast an aeroplane could fly in the upper reaches of the air.
We have here a very general fact which is in no way limited to the case of metal filings. This is that fragments of metal in contact with one another and presenting considerable resistance -- 30,00 ohms, for example -- to the passage of electricity, become conductors under the influence of very weak electric waves, and lose this conductivity by a simple shock. These variations indicate a great variability in the aggregation of atoms under the influence of infinitely weak but appropriate forces.
The energy flowing within the earth generates a field in the atmosphere. It was tapped by large buried laminated metallic structures which Rota called blocks. The energy could light lamps, power machines, inhibit electromagnetic propagation such as radio waves and stop or control electromagnetic induction
It is easy to illustrate what has just been said by a curious experiment due to M. Branly. A column of metal of 30 or 40 cm in height is formed by placing one upon the other a series of polished discs of bismuth, aluminum, etc., of the dimensions of a 5-franc piece. The column may even be made merely of polished steel balls placed in a test tube. The resistance of this column to the passage of an electric current is still considerable. If we make a small electric spark near it, the resistance becomes almost nil. To cause it to reappear, it suffices to give a tap to the upper part of the column.
The bismuth-based ceramic dielectrics have excellent electrical resistivity greater than 1014 ohm-cm
Most discontinuous conductors can exhibit these variations. Now we hardly handle any other than discontinuous conductors. A continuous conductor, such as a metal wire, becomes discontinuous immediately we connect it to the terminals of a battery
The device is called an "electromagnetic detector and amplifier" and consists of a series of bismuth plates stacked in a pile and interlaced with copper wires. The bismuth plates are protected by a coating of sulfur because bismuth, a very brittle substance, is likely to crumble
the way leaves are arranged on plant stems in nature — as inspiration to arrange an array of solar panels in a way that generates 20-50% more energy than a uniform, flat panel array.
what do you see :
It is preferable that the dielectric 16 be in the form of a closed tube or envelope, as shown, and be exhausted to vacuum condition. The multitude of sparking prongs 17a produce a brush discharge.
Where the dielectric 16 is not a closed tube or envelope, it is preferred that it be of quartz.
In accordance with the invention, provision is made for enveloping the patient in a high potential and, in certain instances, a high frequency electric field, and for applying to the patient, while so enveloped in the electric field, radiations and emanations having therapeutic value.
Suppose some one should discover a new mechanical principle--something as fundamental as James Watt—s discovery of the expansive power of steam—by the use of which it became possible to build a motor that would give ten horse power for every pound of the engine—s weight, a motor so simple that the veriest novice in mechanics could construct it and so elemental that it could not possibly get out of repair. Then suppose that this motor could be run forward or backward at will, that it could be used as either an engine or a pump, that it cost almost nothing to build as compared with any other known form of engine, that it utilized a larger percentage of the available power than any existing machine, and, finally, that it would operate with gas, steam, compressed air or water, any one of them, as its driving power.
It does not take a mechanical expert to imagine the limitless possibilities of such an engine.
In the simplest form of the invention, Sprink used a grounded container placed in an electrostatic field. More control and power was obtained with geometric arrays of positive electrodes mounted diagonally from grounded electrodes.
Excerpt: Preface (by Raymond Abellio ) in Armand Babault: Gold of a Thousand Mornings
...To speak of activation of space gets one decidedly nowhere. It is simply a picturesque and handy term, yet one which is heard more and more often. I first encountered it in the description of the patent taken out in 1950 by the Russian engineer Sprink, who runs a cement-manufacturing company in France. In it, he states that the creation of an electric field nearby greatly speeds up reactions inside his ovens. He is unable to explain why...
http://en.wikipedia.org/wiki/Stanley_Meyer's_water_fuel_cell .... "fuel cell water capacitor"
Abstract
An injector system comprising an improved method and apparatus useful in the production of a hydrogen-containing fuel gas from water in a process in which the dielectric property of water and/or a mixture of water and other components determines a resonant condition
Leon Sprink was a Russian engineer who operated a cement manufacturing plant in France circa 1950. He received several patents for a simple method to create a type of electric field that accelerates chemical reactions.
In one example given by Sprink, “One month after the setting in operation of the apparatus, the duration of the reaction, which normally is 24 hours, had fallen down to 3 hours and the saving in calories to be supplied for the reaction was 50%… The field also affects the states of matter such as solubility and crystallization, distillation, reduction of metallic ores, etc..."
same set up : A Capacitor / Oscillator within A Capacitor / Oscillator
1. In an alternating-current motor, the combination, with the armature and field-cores, of stationary energizing-coils enveloping the said cores and adapted to produce polarities or poles in both, the field-cores extending out from the coils and constructed so as to exhibit the magnetic effect imparted to them after the fall or cessation of current impulse producing such effect, as set forth.
My protector, by contrast, is founded on principles diametrically opposite. Its terminal has a large surface. It secures a very low density and preserves the insulating qualities of the ambient medium, thereby minimizing leakage, and in thus acting as a quasi-repellent to increase enormously the safety factor.
In the first experiment a drum-armature was provided with two coils at right angles to each other, and the ends of these coils were connected to two pairs of insulated contact rings as usual. A ring was then made of thin insulated plates of sheet iron, and wound with four coils, each two opposite coils being connected together so as to produce free poles on diametrically opposite sides of the ring. The remaining free ends of the coils were then connected to the contact rings of the generator armature so as to form two independent circuits, as indicated in Fig. 9
The subject of my present application is a new and improved electrical condenser constructed with a view of obviating certain defects which I have observed to exist in the ordinary forms of such apparatus when employed in the system devised by me of producing light and other effects by means of currents of high frequency and high potential.
I have found that insulating material such as glass, mica, and, in general, those bodies which possess the highest specific inductive capacity are inferior as insulators in such devices when currents of the kind described are employed to those possessing high insulating power, together with a smaller specific inductive capacity, and I have also found that it is very desirable to exclude all gaseous matter from the apparatus, or any access to the same to the electrified surfaces, in order to prevent heating by molecular bombardment and the loss or injury consequent thereon. I have found that I may accomplish these results and produce highly efficient and reliable condensers by using oil as the dielectric, and in this my invention resides.
What I claim is—
1. An electric condenser composed of plates or armatures immersed in oil.
2. An electrical condenser composed of plates or armatures adjustable with respect to one another and immersed in oil.
EVERY day, tonnes of uncooked meat in our supermarkets, restaurants and hotels are destroyed before reaching their recommended shelf life.
Mr Sebestian Chua (left) and his brother, DrRichard Chua, hope the EsmoSphere will add another level of protection over food storage. -- Picture: KELVIN CHNG
Even with refrigeration, meat still spoils easily because the temperature is not always consistent and has to be thrown away.
Last year alone, almost half-a-million tonnes of food waste were incinerated.
Now, thanks to a local company, Esmo Technologies, the amount of spoiled raw meat can be cut by about a third, simply by placing a specially modified magnet next to it in the refrigerator.
Magnetic Interference CloudTM technology was developed by its chief founder and inventor, Dr. Richard Chua, who created a unique method of causing magnetic interfered fields to swirl around perishable or liquid objects in a manner that changes the binding force that hold them together, thereby improving cell rigidity, hydration and structure.
... While Freezing inside a Capacitor / oscillator ( ie Fridge )
To carry out this invention I employ a motor embodying the principle of construction of a motor described and claimed in an application filed by me January 8, 1889, No. 295,745, to the extent that both the armature and field receive their magnetism from a single energizing-coil or a plurality of coils acting as one.
If a delicately and pivoted and well-balanced metal disc or cylinder be placed in a proper plating solution ( electrolyte ) midway between the anode and cathode, one half of the disc becomes electro positive and the other half electro negative. Owing to this fact metal is deposited on one, and taken off from the other half, and the disc is caused to rotate under the action of gravity. As the amount of metal deposited and taken off is proportionate to the current strength, the speed of rotation, if it be small, is proportionate to the current.
It has heretofore been announced and demonstrated by me that, under ordinary conditions, the efficiency of an electrical condenser is greatly increased by the exclusion of air or gaseous matter in general from the dielectric. In a patent granted to me December 8, 1891, No. 464,667, I have shown and described a convenient and practicable means of accomplishing this result by immersing the conducting-plates or armatures of the condenser in an insulating fluid, such as oil.
My present invention, while based upon this important feature of the practically complete exclusion of air or gas from the dielectric, is an improvement on the forms of condenser heretofore described and used by me.
According to my present invention I employ an electrolyte, or, in general, a conducting liquid in lieu of a solid, as the material for the armatures of the condenser, under conditions more fully hereinafter described, whereby air or gas will be practically prevented from exercising upon the condenser or the more active portions of the same the detrimental effects present in such devices as heretofore made. Such condensers are especially advantageous when used with circuits of great rates of electrical vibration because of the high conducting capacity of such fluids for currents of this character. There is, however, a general advantage derived from the fact that the conducting fluids have a high specific heat, so that the temperature remains constant, a condition in many cases highly advantageous and not met with in condensers of ordinary construction.
The high frequencies and pitch found in pop and rock music cause vibrations that enhanced energy generation in solar cells containing a cluster of 'nanorods', leading to a 40 per cent increase in efficiency of the solar cells.
Crystals is the Key to Harvesting energy from the enviroment.
All semiconducter electronics components are based on different types of crystals, different sizes, different geometries, each quality can be optimized to tune into different frequency.
With the new development in nano crystals, there's a handful of people conducting nano piezoelectric research at home, I hope that We can also take advantage of this development and use this new technology as a way of obtaining Energy Freedom.
There are many applications for these piezoelectric crystals, the technology is over 100 years old but not much was done until recently.
I hope that we some of you will come together and start developing devices such as Nokia Self Charging Phone Battery, Piezo Cells for Self Charging small batteries AAA-C size etc.
Current Project.Piezoelectric production of Atomize water with HHO for ICE water fuel.
I have been trying to come up with a simple low temperature method to growing micro size single crystals at low temperature that is simple enough for anyone to perform. the mainstream ZnO single cystals are fused at high temperature and vapor deposited requiring complicated setup and technical expertise.
This is a simplified version for home use.
Please use all precaution, I am not responsible for anything that may occur.
Hot plate with Magnetic Stirrer
teflon coated stir bar.
1 liter boiling flask with rubber stopper.
reflux condenser if available.
water bath.
thermometer
Dissolve 30 grams of ZnO in each 300 ml of 30% ammonium chloride/ hydroxide. This is best done by filling 300 ml of 30% amonnium hydroxide into the flask and place on stirrer with teflon bar. Turn on the heat to medium, Turn on Stirrer to low speed, #3. Slowly add zinc oxide to solution. When all ZnO is dispensed, cap flask and turn up stirrer to maximum, bring the heat up to 60 deg C and let it mix for 30 minutes.
Place flask in the Freezer and freeze solution to -0 degrees C.
When you reach this temperature, allow an additional 1 hr.
Before reflux, bath flask in a bowl of room temperature water for 5 minutes to avoid thermal shock and breakage of flask.
Set up water bath, large boiling glass bowl with water. Put your flask of cold solution in the water bath and set up reflux condenser with water tube, if you don't have one then just cap your flask tightly and turn on heat. Allow solution to heat up to 60 degrees C, maintain 60 deg C temperature for 2 hours, crystals will grow during this time.
Let solution cool to room temperature, Filter solution and recover crystals.
the crystals are self seeding. these crystals are not the typical large crystals that most people grow at home. the single crystals are very small, nano size, at this size, they are able to pick up all induced waves and convert waves into electrolysis of water.
There is already a thread on HHO, we can discuss HHO piezoelectric application there,
and discuss Growing of Crystals here, there are many different types of crystals, and many different method of utilizing them.
Our solar cell is made from cuprous oxide instead of silicon. Cuprous oxide is one of the first materials known to display the photoelectric effect, in which light causes electricity to flow in a material.
Mysterious cosmic rays constantly bombard Earth from outer space. Now scientists find these energetic particles could limit where life as we know it might exist on alien planets
Cosmic rays continue to baffle scientists more than a century after they were first discovered . These charged subatomic particles zip through space at nearly the speed of light, a few strangely with energies up to 100 million times beyond what is possible from the most powerful particle accelerator on Earth. Cosmic rays are believed to be atomic nuclei, with the vast majority being protons, or hydrogen nuclei.
When cosmic rays hit Earth's atmosphere, they generate a shower of other particles, including muons, which are essentially much heavier versions of their cousin the electron. Some of these particles reach Earth's surface, potentially damaging life on land and in the oceans—muons can even penetrate hundreds of feet below a planet's surface.
The researchers concentrated on two factors that might influence the cosmic ray dose a planet gets—the strength of its magnetic field, and the depth of its atmosphere.
Read more at:
I have harnessed the cosmic rays and caused them to operate a motive device.
N. Tesla
Electrical and Magnetic Properties of Sulfides
Carolyn I. Pearce, Richard A.D. Pattrick, David J. Vaughan
School of Earth, Atmospheric and Environmental Sciences, and Williamson Research
Centre for Molecular Environmental Science
University of Manchester
Manchester, United Kingdom
e-mail: carolyn.pearce@manchester.ac.uk
INTRODUCTION
The metal sulfides exhibit a great diversity of electrical and magnetic properties with both
scientific interest and practical applications. These properties apply major constraints on mod-
els of the electronic structure (or chemical bonding) in sulfides (Vaughan and Rosso 2006, this
volume). The pure and doped synthetic equivalents of certain sulfide minerals have actual or
potential applications in the electronics industries (optical devices, photovoltaics, photodiodes
and magnetic recording devices). Sulfides are also components of many thin film devices and
have been extensively investigated as part of the nanotechnology revolution. Certain electrical
and magnetic properties of sulfide minerals mean they contribute to geomagnetism and paleo-
magnetism, and provide the geophysical prospector with exploration tools for metalliferous
ore deposits.
I have found that, be enveloping a patient in a high potential, high frequency field in such a manner that no closed circuit is completed through his body, radioactive and other electronic and radiation phenomena can be used therapeutically with considerably greater effectiveness than if used alone. The exact reason for this is not known, nor is it known definitely which, the electric field or the radioactive phenomena, acts upon the other to produce the advantageous results. It is thought, however, that the electric field permeating the body of the patient as it does attracts the radioactive emanations or radiations and enables them to penetrate considerably deeper into the tissues and vital organs of the patient than would otherwise be the case. In any event, remarkable therapeutic results have been achieved by use of the invention in the treatment of malignant tumors. Arthritis, sinus infections, and various other diseased conditions.
... Mu ON
Because muons have a very large mass and energy compared with the decay energy of radioactivity, they are never produced by radioactive decay. They are, however, produced in copious amounts in high-energy interactions in normal matter, during certain particle accelerator experiments with hadrons, or naturally in cosmic ray interactions with matter. These interactions usually produce pi mesons initially, which most often decay to muons.
