Originally posted by MonsieurM
The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Originally posted by MonsieurM View Postsome info on vortex and its properties:
found it here : Nassim Haramein Vortices « Ciencia holÃ*stica para el cambio de conciencia.
an archetypal Vortex viewed from on top looks like an Egg...Another notch for the Ankh Set Up
this might help better visualize the secondary coil and the emf egg, taken from Schauberger Engine Exhaust System
guys if you get the opportunity to watch Aliens and Ancient Engineers, you should (especially around 41 min)
[/QUOTE]
Originally posted by MonsieurM View Postgo to a higher frequency, replace wings with side view of "emf vortex" as if you cut an egg in half
Originally posted by shawnnweed View PostThat could be used to give lift through an opossing em field as it moves laterally. OUtstanding idea
Coanda effect on vortex see image below: Coanda Effect Patents
and compare with vimana , now use your imagination, and picture the vimana with only the ball and the 2 vortex around the ball + coanda effect on upper vortex
hint:
John W. Keely
...When these harmonics form unisons or direct harmonic relations the two vibrating aggregates and their chords of vibration are said to be sympathetic to each other. This unison of frequency dictates that what happens to one vibratorily happens to the other simultaneously.
other Coanda invention:
“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by shawnnweed View Postalright then I'll bite...imagine if the wings acted as coils supporting a physical representation of an em field emmanating from within the torroid to the exterior of the craft.
Last edited by MonsieurM; 09-04-2011, 01:13 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
egg shaped stones floating above a water vortex....hmmmm...seems to be that you were right in picking the geometrical shape of an egg over my idea for the ball. I tell you what...this is going to be one wild ride when we drop this emf egg in that vortex and its copper shell starts drawing energy into the crystal. I magine a surge of 12,000 volts entering our egg. We are going to need one heck of an antenna to transmit that much charged energy. For some reason i just feelI beleive i can
i beleive i can touch the
Originally posted by shawnnweed View Postegg shaped stones floating above a water vortex....hmmmm...seems to be that you were right in picking the geometrical shape of an egg over my idea for the ball. I tell you what...this is going to be one wild ride when we drop this emf egg in that vortex and its copper shell starts drawing energy into the crystal. I magine a surge of 12,000 volts entering our egg. We are going to need one heck of an antenna to transmit that much charged energy. For some reason i just feelI beleive i can
The Tesla Coil will step down the voltage for us...Zilanois doing it over at http://www.energeticforum.com/154844-post722.html...and trust me she knows what she is doing...respect
Originally posted by MonsieurM View PostCoanda effect on vortex see image below: Coanda Effect Patents
hint:
Originally posted by MonsieurM View PostThe Tesla Coil will step down the voltage for us...Zilanois doing it over at http://www.energeticforum.com/154844-post722.html...and trust me she knows what she is doing...respect
Originally posted by shawnnweed View PostYou mean the roddin/tesla coil...it is a tramsnitter and a reciever...remember.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by MonsieurM View PostI was only referring to the step down process, but you are correct the Ankh Set up has the capacity of stepping down the voltage, to a more usable level
Originally posted by shawnnweed View PostOh, I'm with you. I understand that you can use the telsa coil to step down the voltage to create usable amperage. I was just saying that it could also be done through our setup as well as hers becuase our is also a reciever.
Witricity...
Flexible Micanite Sheets
Flexible Mica Sheets, which are manufactured from natural Muscovite mica splittings bonded with polyester or silicone resins. These Flexible Mica Sheets possess excellent flexibility and adhesiveness to permit winding or wrapping of the sheets without heating room temperature. Our range of Flexible Mica Sheets can be formed or bent readily to any shape and will not become brittle and stiff. High Flexible Mica Sheets can be applied to unusual configuration without tear.
Our highly durable Flexible Mica Sheets remain flexible at low room temperature, rigid at high temperature, develops increased tenacity and is fully oil resistant. Our range of Flexible Mica Sheets does not react with copper. It has high moisture and heat resistance, high dielectric strength, excellent chemical resistance and electrical insulating properties.
Usage
Suitable for F & H Class Insulation
HT motors
Traction Motor Armatures & Generators
High Tension Coils Suitable for upto 11KV
Induction furnace
------ Mica Donut also called Micanite ‘V’ Cone
this is the National Beijing stadium, just for illustration purpose
in the words of Mother Nature: not all nests are the same
Last edited by MonsieurM; 09-04-2011, 12:47 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
