The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Flexible Mica Sheets, which are manufactured from natural Muscovite mica splittings bonded with polyester or silicone resins. These Flexible Mica Sheets possess excellent flexibility and adhesiveness to permit winding or wrapping of the sheets without heating room temperature. Our range of Flexible Mica Sheets can be formed or bent readily to any shape and will not become brittle and stiff. High Flexible Mica Sheets can be applied to unusual configuration without tear.
Our highly durable Flexible Mica Sheets remain flexible at low room temperature, rigid at high temperature, develops increased tenacity and is fully oil resistant. Our range of Flexible Mica Sheets does not react with copper. It has high moisture and heat resistance, high dielectric strength, excellent chemical resistance and electrical insulating properties.
Usage
Suitable for F & H Class Insulation
HT motors
Traction Motor Armatures & Generators
High Tension Coils Suitable for upto 11KV
Induction furnace
------ Mica Donut also called Micanite ‘V’ Cone
this is the National Beijing stadium, just for illustration purpose
in the words of Mother Nature: not all nests are the same
WOW! These are magnificient. And they do not react with copper.
did you see in the video they use in the searl experiment DC current on one coil and AC current on the other...You could test it on the ice with you Smith Coil Set up (if it is possible )
it does respect the principle of polarity: ac vs dc current
ps: notice the scarab beetles standing on a "singing bowl" inside emf egg holding a ball 14 min 23 and also pause video at 13 min 32
I wonder if this does not apply too to the Rodin coil, polarity at all dimensions ...
“Signs and symbols rule the world, not words nor laws.” -Confucius.
Remarkable and unusual water feature at Erdigg, Nr Wrexham, N Wales (National Trust property) - created many years ago to push water upwards for supply to nearby house.Reverse Fountain - water goes down ! - YouTube
come to think of it in the video of DNA sequencing the Band is the exact equivalent of the pulse of the two currents mixed. That is a fine question what would happen to polarity if the two were mixed. Would it cancel out or cause an entire shift of polarity on a sub atomic level or would they support one another causing a significant increase in the spin ratio causing a double overlap of the golden mean ratio spiral or helix if you will. My money is on the last of these choices.
Let me show you something, look closely at the peter Davey set up compare it with the Ankh set up
all the element present in the Ankh Set up are present in the Peter Davey setup
the Egg
The Coil / Ring (i would recommend quartz ring coated with mica or ceramic coil )
a Pole
Water
It's all about Perspective...Principle of Mentalism
That is pretty awesome observation. I bet it has everything to do with sound resonating off the 'bell' shaped domes then creating multiple overlaps of vibration causing the waters waves to crash into each other which causes the vibration of the molecules and BAM instant sonic friction causing the water to boil. cascade effect anyone.
You have to check this one out. In this video when he used a DC current with his rodin coil there were two discernible differences than when using ac. 1) the is no spin on the ball or orbital rotation of the ball to the right / clockwise. and 2) you can clearly see the neodymium ball being picked up from the table. So DC causes lift while AC causes spin and orbit. We need both of these effect.
if you look at the animation i posted when AC runs Parallel to DC current. You have a cycle of dc current on both coils when AC runs in the same direction and opposite when AC runs in the opposite direction + maybe some counter EMF happening too
